Xenforo Enable Delayed Insert SQL Queries
Discussion in 'Forum software usage' started by rdan, Dec 28, 2015.
    1,389
    6:35 AM
    Do you guys have this option enabled?
    What are your XF database engine?
    Mine are all Innodb and few memory.
    With previous MariaDB/XF version, I have to disable this because I can't post when that option is enabled and all my tables are on innodb, Now it works fine even if it's enabled.
    50,922
    11,805
    8:35 AM
    disabled for me :)
  3. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    11:35 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Disabled
    Innodb all but few that have to be mysql
  4. rdan
    1,389
    6:35 AM
    And why?
    I enabled it, and don't have issues :).
    50,922
    11,805
    8:35 AM
    not needed with the improvements in MySQL performance especially in MariaDB 10+ and Xenforo's current usage patterns if you have InnoDB tables in use
    see INSERT DELAYED - MariaDB Knowledge Base and MySQL :: MySQL 5.6 Reference Manual :: 13.2.5.2 INSERT DELAYED Syntax
  6. Xon
    Xon Active Member
    173
    61
    6:35 AM
    INSERT DELAYED is a hack to workaround the limitations of MyISAM which does full-table locks rather than row-level locking.
    50,922
    11,805
    8:35 AM
    much better explanation :D
  8. Tien Nguyen Van
    Tien Nguyen Van New Member
    5
    5:35 AM
    Hello,
    How can I enable this option? I got this error message when importing database for my website: "DELAYED option not supported for table"
    50,922
    11,805
    8:35 AM
    Is this for Xenforo ? or other web script/app ? What version of MySQL were you coming from (source mysql backup data's MySQL version) ? How are you backing up and importing the mysql data ? exact commands used ?
    Googled - https://mariadb.com/kb/en/library/insert-delayed/
    Centmin Mod MariaDB has default max_delayed_threads = 20 so is not disabled at MariaDB MySQL global level
    mysqladmin var | grep max_delayed | tr -s ' '
    | max_delayed_threads | 20 |
    insert delayed only work with MyISAM, MEMORY, ARCHIVE and BLACKHOLE tables but MySQL 5.6.6 already deprecated insert delayed. But Centmin Mod MariaDB MySQL and Xenforo default to creating InnoDB tables by default, so you'd want to disable Xenforo insert delay option.
    check your delayed insert counts in mysql status output
    mysqladmin ext | grep -i delayed
    | Delayed_errors                                               | 0                                      |
    | Delayed_insert_threads                                       | 0                                      |
    | Delayed_writes                                               | 0                                      |
    | Not_flushed_delayed_rows                                     | 0                                      |
    But the MySQL docs left something out MySQL Bugs: #5777: InnoDB do not support INSERT DELAYED that after MySQL 5.6.6 and MariaDB 10, deprecating delayed inserts means just a warning but message you see and the query still goes through replacing DELAYED INSERT as normal INSERT. So unless your import abruptly stops, importing to completion with just that warning message should be ok I think.
    MySQL :: MySQL 5.6 Reference Manual :: 13.2.5.3 INSERT DELAYED Syntax
    50,922
    11,805
    8:35 AM
    50,922
    11,805
    8:35 AM
    Or use mysqldump in SSH command to backup database to sql file as delayed inserts is disabled by default for backups
     mysqldump --help | grep insert
      -c, --complete-insert
                          Use complete insert statements.
      --delayed-insert    Insert rows with INSERT DELAYED.
      -e, --extended-insert
                          (Defaults to on; use --skip-extended-insert to disable.)
      --insert-ignore     Insert rows with INSERT IGNORE.
                          --quick, --extended-insert, --lock-tables, --set-charset,
                          --create-options, --quick, --extended-insert,
    complete-insert                   FALSE
    delayed-insert                    FALSE
    extended-insert                   TRUE
    insert-ignore                     FALSE
    http://dev.mysql.com/doc/refman/5.6/en/mysqldump.html
    backup where /path/to/ is directory you want to save sql backup file to
    mysqldump -u mysqlusername -p mysqldatabasename > /path/to/mysqldatabasename_backup_date.sql
    restore
    mysql -u mysqlusername -p mysqldatabasename < /path/to/mysqldatabasename_backup_date.sql
  12. Tien Nguyen Van
    5
    5:35 AM
    Thanks for quick reply @eva2000 (this is one of the reason I went from EE to CMM). I exported databases using PhpMyAdmin and as your recommendation, I understand that I have to disable DELAY option when export. The problem is that I can't find: config.inc.php file location to modify it.
    If you are talking about the option when exporting from PhpMyAdmin interface, I disabled it: Pasteboard — Uploaded Image
    50,922
    11,805
    8:35 AM
    on old server try using locate command to find it
    updatedb
    locate config.inc.php
  14. Tien Nguyen Van
    5
    5:35 AM
    Wow! That's so cool. Your knowledge in this field must be at MASTER level. I now can import the database very well.
    I will submit other ticket if I face other problems. Thanks again for your kindly support.
    50,922
    11,805
    8:35 AM
    You're welcome. FYI, my reply in your intro thread has alot of juicy info and tips to get the most out of Centmin Mod LEMP - guaranteed you'd learn something new everyday Introduction :D
