Beta Branch enable Cloudflare zlib performance library by default for Nginx zlib
Discussion in 'Centmin Mod Github Commits' started by eva2000, Feb 24, 2018.
    49,877
    11,487
    9:04 PM
    - set CLOUDFLARE_ZLIB='y' by default. Very little risk as the routine now has error checking so if Cloudflare zlib library install fails, Centmin Mod will fall back to standard custom zlib 1.2.11 library install for Nginx zlib
    - with Cloudflare zlib performance library usage, Nginx HTTP gzip compressed request performance can improve up to 29% over standard zlib 1.2.11 library
    123.09beta01 branch
  2. pamamolf
    4,003
    420
    2:04 PM
    Nginx-1.17.x
    Maybe to add a notification at the end if nginx compiled with the patched zlib or not so the user will know without to check manually?
    49,877
    11,487
    9:04 PM
    end of nginx compiles usually gives a nginx -V output so visually you can see already
  4. pamamolf
    4,003
    420
    2:04 PM
    Nginx-1.17.x
    Don’ remember that output ...
    Ok thanks :)
    49,877
    11,487
    9:04 PM
    It's not very ending output it's a bit further up before the displayed log file listing
  6. Oxide
    Oxide Active Member
    531
    29
    9:04 PM
    Do I need to do anything at all to get the optimizations?
    I've updated the git base, and reinstalled nginx. Any extra configuration required?
    ginx version: nginx/1.13.9
    built by gcc 7.2.1 20170829 (Red Hat 7.2.1-1) (GCC)
    built with OpenSSL 1.1.0g  2 Nov 2017
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -march=native -DTCP_FASTOPEN=23 -g -O3 -fstack-protector-strong -flto -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wimplicit-fallthrough=0 -fcode-hoisting -Wp,-D_FORTIFY_SOURCE=2 -gsplit-dwarf' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.2 --add-module=../ngx_cache_purge-2.4.2 --add-module=../ngx_devel_kit-0.3.0 --add-dynamic-module=../set-misc-nginx-module-0.31 --add-dynamic-module=../echo-nginx-module-0.61 --add-module=../redis2-nginx-module-0.14 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-dynamic-module=../headers-more-nginx-module-0.33 --with-pcre=../pcre-8.41 --with-pcre-jit --with-zlib=../zlib-cloudflare-1.3.0 --with-http_ssl_module --with-http_v2_module --with-openssl=../openssl-1.1.0g --with-openssl-opt='enable-ec_nistp_64_gcc_128'
    49,877
    11,487
    9:04 PM
