Early Data was not sent
Discussion in 'Introductions' started by Akansha, Dec 20, 2018.
  1. Akansha
    Akansha New Member
    9:58 PM
    1.15.6
    We are using nginx 1.15.6 and we have enable TLS 1.3 also enabled early data using the following command in our nginx configuration file.
    ssl_early_data on;
    proxy_set_header Early-Data $ssl_early_data;
    But it is showing that Early data was not sent.
    we are getting the following
    No client certificate CA names sent
    Server Temp Key: ECDH, P-256, 256 bits
    SSL handshake has read 367 bytes and written 1349 bytes
    Verification: OK
    Reused, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
    Server public key is 2048 bit
    Secure Renegotiation IS NOT supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    Verify return code: 0 (ok)
    Post-Handshake New Session Ticket arrived:
    SSL-Session:
        Protocol  : TLSv1.3
        Cipher    : TLS_AES_256_GCM_SHA384
        Session-ID: 2B26FE64F5BDA3986B4E754B1A1C981C4F32F8619997DD8F022476E91E606F9A
        Session-ID-ctx:
        Resumption PSK: C2740B4CEEED78B5FDEBBE43104BF20016B544BEB09792509B0E647D7CCE3789B7D6769945535CCDE0BA5FF443FA9BEC
        PSK identity: None
        PSK identity hint: None
        SRP username: None
        TLS session ticket lifetime hint: 3600 (seconds)
        TLS session ticket:
        0000 - c2 6e 0c c7 f4 95 69 c7-09 87 7c f8 39 f7 a7 bb   .n....i...|.9...
        0010 - 4e d2 ce 82 de 2f bf ac-6d ad 20 72 0e be 16 0c   N..../..m. r....
        0020 - 3f e6 43 c8 bf 4e 05 bc-94 2e 17 b4 99 8a 1d d9   ?.C..N..........
        0030 - 0f 58 e4 dc 79 08 72 14-74 5d 3f 16 09 d7 82 33   .X..y.r.t]?....3
        0040 - b3 27 b4 c7 7d 73 e8 73-24 fb f6 a6 c3 1e 94 e2   .'..}s.s$.......
        0050 - 33 84 59 5b 9d 7c c4 fe-36 45 e4 9d cc 05 20 e7   3.Y[.|..6E.... .
        0060 - ba 48 42 83 88 0e 27 92-30 19 19 67 80 63 c7 31   .HB...'.0..g.c.1
        0070 - ab e5 19 fb ff 87 c2 c6-9e b2 9c 0c be cc 32 28   ..............2(
        0080 - ee d6 85 65 1e 47 bb 2a-61 69 96 b0 52 b1 b2 93   ...e.G.*ai..R...
        0090 - 09 d5 f6 27 c5 b7 bc f5-70 b3 22 df 2a c4 f8 51   ...'....p.".*..Q
        00a0 - 7f 3a 02 c5 82 f6 43 49-4f 9c 2f e3 7c 2e 03 ab   .:....CIO./.|...
        00b0 - 7d 5a ca 37 67 04 7f b9-8f e3 7e ee e3 32 a8 f6   }Z.7g.....~..2..
        00c0 - 60 af 7c 19 10 c5 24 52-11 23 c0 2e 36 39 0a 69   `.|...$R.#..69.i
        00d0 - 18 08 cb 49 c3 73 4b c8-c4 4e bc 57 33 c6 9d 8e   ...I.sK..N.W3...
        00e0 - de dd 17 ec 5e 30 44 a0-7a 94 18 e5 55 8f 0b 0a   ....^0D.z...U...
        Start Time: 1545297256
        Timeout   : 7200 (sec)
        Extended master secret: no
        Max Early Data: 16384
    read R BLOCK
    Where am i getting wrong?
    Any help will be appreciated.
    44,165
    10,066
    2:28 AM
    welcome @Akansha to Centmin Mod Community. There's 6 steps to learning more about Centmin Mod ;)
    You might want to post the question in a more appropriate forum at https://community.centminmod.com/forums/nginx-and-php-fpm-news-discussions.18/ now that you have introduced yourself and can post elsewhere :) edit: I see you posted at https://community.centminmod.com/threads/nginx-announce-nginx-1-15-4.15672/page-4#post-69538, so will reply there.
    Might also be interested in reading up on latest LEMP stack comparison benchmarks tagged here.
    You might want to try the 123.09beta01 build as it will be next stable release and well has alot of improvements if you check 2nd post change log at Beta Branch - Centmin Mod .09 beta branch Testing. And you can share your initial install times here.
    Threads you might want to participate in ;)
    Quick Tips
    Threads & Info To Bookmark
    Threads to read, pages to bookmark and threads to watch/subscribe to get to know Centmin Mod would include:
    Centmin Mod Insights Forum
    The Centmin Mod Insights forums digs deeper into the inner workings of Centmin Mod so some useful threads in this forum include:
    Security Related Developments
    A few security related developments you might be interested reading about
    Premium Membership
    Centmin Mod Donations
    You now can show your love and support for Centmin Mod via
