Wordpress domain directory weird problem
Discussion in 'Blogs & CMS usage' started by hitman, Mar 24, 2017.
  1. hitman
    hitman Member
    120
    11
    5:07 AM
    hello
    i had a site created with option 22 (wordpress), lets call it domain1.com.
    Later i changed the domain name of the site to domain2.com with wp-cli tool.
    Now i moved this site to another server and i noticed that althgouth in the path
    /home/nginx/domains
    the domain domain1.com should not exist, it gets created with contents
    public/wp-content/uploads/sucuri
    any idea why this happens?
    34,591
    7,653
    12:07 PM
    What's output for these commands changing /home/nginx/domains/domain.com/public/ to the path to where you installed wordpress i.e. if domain.com/blog then it would be /home/nginx/domains/domain.com/public/blog
    cd /home/nginx/domains/domain.com/public/
    wp option get siteurl --allow-root
    wp option get home --allow-root
    see an example of switching subdirectories/url for wordpress at https://community.centminmod.com/th...how-to-switch-wordpress-to-subdirectory.5603/
  3. hitman
    hitman Member
    120
    11
    5:07 AM
    the output in both the commands is the same
    domain2.com in this case, which is the proper site
    Please note that the site works flawlessly. The only weird thing is the presence of the old domain in a completely new server. Does centmin option 22 has something regarding sucuri that could interfere?
    34,591
    7,653
    12:07 PM
    So your nginx vhosts config files are at /usr/local/nginx/conf/conf.d/newdomain.com.conf and if applicable /usr/local/nginx/conf/conf.d/newdomain.com.ssl.conf. If you changed newdomain.com to newdomain2.com, you would of needed to change all references of newdomain.com to newdomain2.com in both nginx vhost files as well as change directory names /home/nginx/domains/newdomain.com to /home/nginx/domains/newdomain2.com. Other if you didn't do the last part for directory names, it will still work for accessing newdomain2.com as long as nginx vhost file server_names were changed.
