PHP-FPM Does PHP-FPM have connection pooling for MySQL?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by jeffwidman, Oct 28, 2015.
  1. jeffwidman
    jeffwidman Active Member
    152
    27
    12:12 AM
    Saw this commit: update mysql my.cnf templates · centminmod/centminmod@1c10458 · GitHub
    I was surprised @eva2000 bumped it so high... does PHP-FPM have MySQL connection pooling where you don't want connections to be closed after every pageview?
    Most googling showed that PHP apps should have wait_timeout between 60-90 seconds max, but those were assuming PHP wasn't being served through an app server that could manage a connection pool.
  2. pamamolf
    4,101
    428
    10:12 AM
    Nginx-1.26.x
    I was thinking the same as it is a huge value !
    55,896
    12,281
    5:12 PM
    you're confusing php timeout and mysql wait_timeout which can occur without any php involvement i.e. classic 'MySQL server has gone away' issues MariaDB - DB problems, daily freezes
  4. jeffwidman
    152
    27
    12:12 AM
    No, I was thinking about MySQL wait_timeout in production systems that are serving PHP apps.
    55,896
    12,281
    5:12 PM
    well mysql wait_timeout applies to all connections not just PHP ones so not a good idea to restrict it's value specifically for PHP usage hence why i raised it's value and well PHP has it's own timeouts to restrict PHP specific usage anyway :)
  6. Xon
    Xon Active Member
    173
    61
    3:12 PM
    You can use persistent connections with php-fpm and MySQL. Assuming you are using mysqli connection connector, and php 5.3+
    For the database host string, enter 'p:127.0.0.1' instead of '127.0.0.1'. Make sure to test that your implementation works as expected.
    55,896
    12,281
    5:12 PM
    database host string in web app's config.php file ? like xenforo library/config.php ?
  8. Xon
    Xon Active Member
    173
    61
    3:12 PM
    Yup. For example:
    $config['db']['host'] = 'p:127.0.0.1';
    $config['db']['port'] = '3306';
    55,896
    12,281
    5:12 PM
    Oooh nice.. learnt something new :D
  10. jeffwidman
    152
    27
    12:12 AM
    Hmm... I just tried this on a wordpress wp-config.php using PHP 5.6.17 and MariaDB 10 and '127.0.0.1' works, but 'p:127.0.0.1' fails to establish db connection, even after restarting php with 'nprestart' (centminmod shortcut).
    @eva2000 were you able to get this to work? Can you confirm centminmod by default using mysqli? I'm not sure how to check which db driver it's using (or is this specified by the app itself?)
    55,896
    12,281
    5:12 PM
    i believe that is something specific to Xenforo/Zend Framework ?
    see PHP-FPM - CentminMod.com LEMP Nginx web stack for CentOS
    PHP: Introduction - Manual
    php --ri mysql
    mysql
    MySQL Support => enabled
    Active Persistent Links => 0
    Active Links => 0
    Client API version => mysqlnd 5.0.11-dev - 20120503 - $Id: 15d5c781cfcad91193dceae1d2cdd127674ddb3e $
    mysql.allow_persistent => On => On
    mysql.max_persistent => Unlimited => Unlimited
    mysql.max_links => Unlimited => Unlimited
    mysql.default_host => no value => no value
    mysql.default_user => no value => no value
    mysql.default_password => no value => no value
    mysql.default_port => no value => no value
    mysql.default_socket => /var/lib/mysql/mysql.sock => /var/lib/mysql/mysql.sock
    mysql.connect_timeout => 60 => 60
    mysql.trace_mode => Off => Off
    mysql.allow_local_infile => On => On
    php --ri mysqli
    mysqli
    MysqlI Support => enabled
    Client API library version => mysqlnd 5.0.11-dev - 20120503 - $Id: 15d5c781cfcad91193dceae1d2cdd127674ddb3e $
    Inactive Persistent Links => 0
    Active Links => 0
    mysqli.max_links => Unlimited => Unlimited
    mysqli.max_persistent => Unlimited => Unlimited
    mysqli.allow_persistent => On => On
    mysqli.default_host => no value => no value
    mysqli.default_user => no value => no value
    mysqli.default_pw => no value => no value
    mysqli.default_port => 3306 => 3306
    mysqli.default_socket => /var/lib/mysql/mysql.sock => /var/lib/mysql/mysql.sock
    mysqli.reconnect => Off => Off
    mysqli.allow_local_infile => On => On
    But yes whatever the web php app is configured to use as Centmin Mod supports them all out of the box :)
    55,896
    12,281
    5:12 PM
    55,896
    12,281
    5:12 PM
    and #31018 (Persistent database connections with mysqli) – WordPress Trac
  14. jeffwidman
    152
    27
    12:12 AM
    Thanks for the links... looks like I'll need to read up a bit to understand what all is happening behind the scenes here. I'm much more comfortable with connection pooling in the Python web framework/SQLAlchemy world.
    @Xon - have you tried this with WP at all? Or just with Xenforo?
    Does the locks not being released issue that @eva2000 mentioned in the post right above this one a potential issue with XF/Zend?
  15. Xon
    Xon Active Member
    173
    61
    3:12 PM
    Looks like Wordpress explicitly blocks persistent connections.
    Just with XenForo.
    If the php-fpm process seg-faults and dies, the connection should die and any locks be released. Otherwise php-fpm should still call the mysqlnd extension's cleanup function when the request ends. Regardless of the php script throws/dies/exits.
    I suspect Wordpress is guarding against old and shitty php versions where mysqlnd didn't not have that cleanup function so it could hit the case they talk about. And just haven't read or studied the latest behaviour.
    55,896
    12,281
    5:12 PM
    indeed MySQL :: MySQL PHP API :: 6.9.3 MySQL Native Driver Plugin Architecture
  17. abs0lut3
    abs0lut3 New Member
    7
    Kiev, Ukraine
    10:12 AM
    1.9.12
    MariaDB 10.1
    Me too :)
  18. rdan
    1,412
    3:12 PM
    So you guys already using this on your Live XF Forum? :)
    55,896
    12,281
    5:12 PM
    not using it myself
  20. Xon
    Xon Active Member
    173
    61
    3:12 PM
    Yes, used on SpaceBattles and Sufficient Velocity without an issue.
    Persistent Redis connections however are buggy as fuck.
