does centminmod work on centos 8 stream?
Discussion in 'Install & Upgrades or Pre-Install Questions' started by brainlet2000, May 4, 2023.
  1. brainlet2000
    brainlet2000 Member
    42
    11:07 AM
    1.17.7
    10.3.21
    want to setup a new server and just wondering. thanks.
  2. duderuud
    duderuud Active Member
    187
    69
    The Netherlands
    11:07 AM
    1.25 x
    10.6
    Currently, some people are beta testing a new version of CMM on AlmaLinux 8 or RockyLinux 8.
    CentOS Stream is not supported (afaik).
  3. brijendrasial
    brijendrasial Active Member
    198
    143
    3:37 PM
    1.13.9
    10.0.22-MariaDB
    I think it should work but never tested it.
  4. brainlet2000
    brainlet2000 Member
    42
    11:07 AM
    1.17.7
    10.3.21
    it should or it does
    51,209
    11,897
    8:07 PM
    No CentOS 8 Stream isn't supported as it isn't being tested for - I'd stick with either Rocky Linux 8 or AlmaLinux 8 for upcoming Centmin Mod 130.00beta01 which is currently in private beta testing.
    Right now Centmin Mod still only supports CentOS 7 64bit EL7 operating system installations. CentOS 7 is still supported until 2024. I am actively working on compatibility with EL8/EL9 systems for AlmaLinux 8/9 and Rocky Linux 8/9 which are OSes replacing early EOL'd CentOS 8. EL8 OSes are supported until 2029, and EL9 OSes are supported until 2032 by Redhat Enterprise Linux upstream.
    Details for work logs for EL8 and EL9 compatibility work are at:
    Some Centmin Mod users who are very familiar with Centmin Mod and/or EL8/EL9 non-Centmin Mod OS setups have already been invited into a limited private EL8 Centmin Mod beta testing group to provide beta testing feedback and suggestions in a private forum right now. Afterwards, I'd open the EL8 beta testing to the public.
    Only EL8 beta testing is underway as EL9 testing is still a long way away from release.
