Nginx PageSpeed DO droplet would not reboot with pagespeedadmin.conf
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by josh, Dec 19, 2014.
  1. josh
    josh Premium Member Premium Member
    29
    12:15 AM
    I haven't determined why, but one of my DO droplet that is running Centmin Mod rebooted tonight and was tripping up on the pagespeedadmin.conf file.
    nginx: [emerg] unknown directive "pagespeed" in /usr/local/nginx/conf/pagespeedadmin.conf:5
    I commented out this line in nginx.conf and everything is working better now but I can't figure out how this was triggered or what the issue is or how my other droplets running Centmin Mod may be affected.
    Any insights into what's going on here?
    Thanks in advance!
    55,942
    5:15 PM
    if you check Install - Centmin Mod 1.2.3-eva2000.07 stable install | Centmin Mod Community updated posts some are related to changes in .07 stable for compatibility with ngx pagespeed 1.8.x and 1.9.x so if you're running much older Centmin Mod, make sure you have updated ngx pagespeed Nginx, PHP-FPM & MariaDB MySQL | Centmin Mod Community
    for instance Nginx PageSpeed - ngx_pagespeed 1.9.32.2 beta released | Centmin Mod Community
    best way is to update to latest .07 stable Centmin Mod if you're using <0.7 version as outlined here and then run centmin.sh menu option 4 to recompile Nginx 1.7.8
