Disk space is going away
Discussion in 'System Administration' started by Sunka, Dec 12, 2015.
  1. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    8:20 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    My disk space is getting smaller and smaller with every new day.
    It is about 1 GB per day.
    I'm not using that server for backup, nor I upload something every day (nor my users too) what will eat disk space 1gb per day.
    How to list biggest folders on server?
    I upgraded nginx, php etc... in past few days, so maybe there is some left junk files on server?
    Maybe logs are eating space on hard, I am using logrotate but maybe is not configured in proper way?
    Any one knows program to see what was changed in x hours/days on server to see what is consuming a lot of disk space.
    Any one have experience with NCDU app?
    55,983
    4:20 AM
    try
    df -h
    du -h --max-depth=1 /
    du -h --max-depth=1 /home
    du -h --max-depth=1 /usr
    du -h --max-depth=1 /var
  3. Sunka
    1,150
    325
    Pula, Croatia
    8:20 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    That list biggest folders, but not show me why every day 500-1000 mb is growing inside X folder.
    I have to find what files are that and in which folder(s) they are created
  4. elargento
    elargento Member
    354
    3:20 PM
    Hi
    Did you find the reason?
  5. Sunka
    1,150
    325
    Pula, Croatia
    8:20 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    Yep, log files + database backup every day.
    Solved it with logrotator and cron for deleting database backup older than x days.
    Still hard disk space is eaten about +100MB per day
    55,983
    4:20 AM
    part of the science is choosing the right server hardware specs for your needs :D
  7. Sunka
    1,150
    325
    Pula, Croatia
    8:20 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    more money thing than science :vulcan:
  8. Sunka
    1,150
    325
    Pula, Croatia
    8:20 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    @eva2000 regarding this thread Raising minimum & recommended disk requirements for Centmin Mod LEMP installs | Centmin Mod Community
    Is it safe to delete those backup files? Maybe to leave just newest?
    I have more than 10GB of that.
    Any code to fast delete unnecessary files?
    [root@tvor-ocean ~]# du -h --max-depth=1 /usr/local/nginxbackup/
    6.6G    /usr/local/nginxbackup/nginxdirbackup
    4.0M    /usr/local/nginxbackup/confbackup
    [root@tvor-ocean ~]# du -sh /home/.ccache/
    1.1G    /home/.ccache/
    [root@tvor-ocean ~]# ccache -s
    primary config                      /home/.ccache/ccache.conf
    secondary config      (readonly)    /usr/local/etc/ccache.conf
    cache hit (direct)                 13689
    cache hit (preprocessed)           10505
    cache miss                         13974
    called for link                     1186
    called for preprocessing            1132
    multiple source files                  2
    compile failed                       339
    preprocessor error                   217
    bad compiler arguments               264
    unsupported source language          570
    autoconf compile/link               4014
    no input file                        573
    files in cache                     40346
    cache size                           1.1 GB
    max cache size                       2.2 GB
    [root@tvor-ocean ~]# du -sh /svr-setup
    3.4G    /svr-setup
    55,983
    4:20 AM
    yeah you can just delete nginx backup contents
    cd /usr/local/nginxbackup
    rm -rf /usr/local/nginxbackup/nginxdirbackup/*
    rm -rf /usr/local/nginxbackup/confbackup/*
    do ccache clean command above
    ccache -C
    and just
    cd /svr-setup/
    rm -rf /svr-setup/*
    cd commands just a precaution as rm -rf * wipes out everthing in directory you specify i.e. /svr-setup/* however some folks copy and paste mistakes and if you ran rm -rf * you could wipe out your entire server and OS !
    get into the habit of changing into directory you are going to delete even if you specifying a path to delete from rm command
  10. Sunka
    1,150
    325
    Pula, Croatia
    8:20 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    And that was an answer to first post (y)
    [root@tvor-ocean ~]# df -h
    /dev/vda1        59G   39G   18G  69% /
    devtmpfs        2.0G     0  2.0G   0% /dev
    tmpfs           2.0G     0  2.0G   0% /dev/shm
    tmpfs           2.0G   57M  1.9G   3% /run
    tmpfs           2.0G     0  2.0G   0% /sys/fs/cgroup
    /dev/loop0      3.7G   99M  3.4G   3% /tmp
    tmpfs           396M     0  396M   0% /run/user/0
    [root@tvor-ocean ~]# cd /usr/local/nginxbackup
    [root@tvor-ocean nginxbackup]# rm -rf /usr/local/nginxbackup/nginxdirbackup/*
    [root@tvor-ocean nginxbackup]# rm -rf /usr/local/nginxbackup/confbackup/*
    [root@tvor-ocean nginxbackup]# ccache -C
    Cleared cache
    [root@tvor-ocean nginxbackup]# cd /svr-setup/
    [root@tvor-ocean svr-setup]# rm -rf /svr-setup/*
    [root@tvor-ocean svr-setup]# df -h
    /dev/vda1        59G   28G   29G  49% /
  11. dorobo
    dorobo Active Member
    420
    104
    2:20 AM
    latest
    latest
    I noticed it just now because I got a disk alert email
    Running out of space "/ (90%)" on server
    and the log files doesn't have logrotate.
    should this be included by default by centminmod?
    55,983
    4:20 AM
    yes they do rotate out of the box, checked my servers
    ls -lahrt | grep access.log
    -rw-r--r--  1 root  nginx  37M May 19  2015 access.log-20150411.gz
    -rw-r--r--  1 nginx nginx  38M Jun 26  2015 access.log-20150519.gz
    -rw-r--r--  1 nginx nginx  37M Aug  1  2015 access.log-20150626.gz
    -rw-r--r--  1 nginx nginx  43M Sep 11 04:21 access.log-20150801.gz
    -rw-r--r--  1 nginx nginx  43M Oct 19 03:59 access.log-20150911.gz
    -rw-r--r--  1 nginx nginx  43M Dec  1 04:01 access.log-20151019.gz
    -rw-r--r--  1 nginx nginx  45M Jan  7 03:54 access.log-20151201.gz
    -rw-r--r--  1 nginx nginx  46M Feb  2 03:22 access.log-20160107.gz
    -rw-r--r--  1 nginx nginx  42M Feb 24 03:52 access.log-20160202.gz
    -rw-r--r--  1 nginx nginx 516M Feb 24 14:55 access.log-20160224
    -rw-r--r--  1 nginx nginx 242M Mar  6 21:59 access.log
  13. SneakyDave
    SneakyDave Member
    84
    14
    1:20 PM
    1.0.15
    I noticed my www-php.error.log in /var/log/php-fpm is quite high too. Should centminmod be logrotating that, or should I just set that up myself?
    55,983
    4:20 AM
    55,983
    4:20 AM
    edit: oh 123.08stable also has the same fix centminmod/cpcheck.inc at 123.08stable · centminmod/centminmod · GitHub
    so fixed php-fpm logrotate file at /etc/logrotate.d/php-fpm would be like
    /var/log/php-fpm/*.log {
            daily
            dateext
            missingok
            rotate 10
            maxsize 500M
            compress
            delaycompress
            notifempty
            postrotate
            /bin/kill -SIGUSR1 $(cat /var/run/php-fpm/php-fpm.pid 2>/dev/null) 2>/dev/null || true
            endscript
