Cloudflare Disable SSL and keep using Let's Encrypt
Discussion in 'Domains, DNS, Email & SSL Certificates' started by R0rke, May 11, 2019.
  1. R0rke
    R0rke Member
    139
    Iran
    8:55 PM
    1.11.1
    10.1
    hi, looking for a way to completely disable Cloudflare SSL on my Centminmod.
    but keep using Forced HTTPs (https://mysite.net) via Lets Encrypt
    I tried by disabling Cloudflare SSL from the panel but fail.
  2. pamamolf
    3,456
    331
    6:55 AM
    Nginx-1.17.x
    If you want to use Cloudflare then you must have it enabled or it will not work.
    If you disable Cloudflare then you can use Let's encrypt alone.
  3. R0rke
    R0rke Member
    139
    Iran
    8:55 PM
    1.11.1
    10.1
    u mean? just fully pausing the Cloudflare and just use let's encrypt alone?
    @eva2000 please take a look at this thread! #1
  4. Khairul
    Khairul New Member
    7
    11:55 AM
    1.13.6
    MariaDB 10
    @R0rke
    What @pamamolf mean is that you have to disable Cloudflare features (that orange cloud icon, make it turn to grey) and use Cloudflare as DNS only, then you can use your own SSL (including Letsencrypt).
    41,375
    9,288
    1:55 PM
    +1 this is the way to let letesencrypt ssl show by disabling Cloudflare orange cloud on the host DNS record in CF dashboard. But I'd advise you don't do that let CF accelerate your site with their SSL cert and use CF Full SSL so CF connects to your origin using HTTPS too as you have letsencrypt ssl cert on your origin Centmin Mod Nginx server.
  6. R0rke
    R0rke Member
    139
    Iran
    8:55 PM
    1.11.1
    10.1
    @eva2000 so there is no way to disable CF's SSL?
    even with buying a cert?
    41,375
    9,288
    1:55 PM
    only way is if you want your own SSL certs shown to visitors while using Cloudflare is upgrading to Cloudflare Business or higher plan which allows you to upload your own purchased SSL certificates for Cloudflare to use.
  8. R0rke
    R0rke Member
    139
    Iran
    8:55 PM
    1.11.1
    10.1
    so you are using the Business account of Cloudflare?
    41,375
    9,288
    1:55 PM
    My cloudflare is using Cloudflare's provided SSL certificates just I purchased a dedicated Cloudflare SSL certificate at $5/month. But yes I am using Cloudflare Business account but not using custom uploaded SSL certificates as you have do renewal on my end. Using Cloudflare's provided SSL certificate means they handle auto renewals.
