Install DigitalOcean VPS installation questions
Discussion in 'Install & Upgrades or Pre-Install Questions' started by dooma, Nov 2, 2016.
  1. dooma
    dooma Active Member
    326
    34
    Cairo
    6:28 PM
    I replaced the first part and its still down and I didnt get you where can I add the second part?
    thanks
     cat /usr/local/nginx/conf/conf.d/domain.com.conf
    #server {
    #            listen   80;
    #            server_name mydomaint.com;
      server_name mydomain.com www.domain.com;
      # ssi  on;
      access_log /home/nginx/domains/myodomain.com/log/access.log main_ext buffer=256k flush=60m;
      error_log /home/nginx/domains/mydomaint.com/log/error.log;
      include /usr/local/nginx/conf/autoprotect/xmydomain.com/autoprotect-myodomain.com.conf;
      root /home/nginx/domains/mydomain.com/public;
      # server and/or vhost site
      #location ~ (?:^|/)\. {
      # deny all;
  2. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    6:28 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    I belive this:
    Shoud be like this:
         location /internal_data/ {
            internal;
            allow 127.0.0.1;
            #allow my ISP ip;
            deny all;
         location /library/ {
            internal;
            allow 127.0.0.1;
            #allow my ISP ip;
            deny all;
  3. dooma
    dooma Active Member
    326
    34
    Cairo
    6:28 PM
    Thanks for help but still down !! :(
    cat /usr/local/nginx/conf/conf.d/mysite.com.conf
    #server {
    #            listen   80;
    #            server_name mysite.com;
    #            return 301 $scheme://www.mysite.com$request_uri;
      server_name mysite.com www.mysite.com;
      # ssi  on;
      access_log /home/nginx/domains/mysite.com/log/access.log main_ext buffer=256k flush=60m;
      error_log /home/nginx/domains/mysite.com/log/error.log;
      include /usr/local/nginx/conf/autoprotect/mysite.com/autoprotect-mysite.com.conf;
      root /home/nginx/domains/mysite.com/public;
      # deny all;
           internal;
            allow 127.0.0.1;
            #allow my ISP ip;
            deny all;
            internal;
            allow 127.0.0.1;
            #allow my ISP ip;
            deny all;
  4. Sunka
    1,150
    325
    Pula, Croatia
    6:28 PM
    Nginx 1.17.9
    MariaDB 10.3.22
    nginx -t
    59,718
    2:28 AM
    did you restart nginx after editing nginx vhost files ?
    service nginx restart
    or command shortcut
    ngxrestart
    Also as @Sunka mentioned nginx -t can check nginx config syntax
  6. dooma
    dooma Active Member
    326
    34
    Cairo
    6:28 PM
    I forgot to restart. Thank you :)
  7. dooma
    dooma Active Member
    326
    34
    Cairo
    6:28 PM
    How to protect the install and admin folder without using static IP ?
    and What is the best method to install my SSL I purchased from namecheap ?
