Beta Branch raise DMOTD_FANCY column gate to 80 to match rule width in 140.00beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, May 20, 2026.
    59,480
    12,536
    12:18 AM
    The fancy heavy / light rules at _fancy_rule_heavy / _fancy_rule_light
    are 79 display columns wide, but the capability gate previously
    required only >= 75. Terminals at 75-79 columns would pass the gate
    and then visually wrap every separator line.
    - Extract the threshold as _DMOTD_FANCY_MIN_COLS=80 (matches rule
    width with 1 column of margin)
    - Update the gate test to use the constant
    - Update inline comments to match the new floor
    Users on terminals narrower than 80 columns now fall back cleanly to
    compact-plain rendering instead of getting broken fancy separators.
    140.00beta01 branch
