[Solved] Default XenForo style?
Discussion in 'Forum Feedback & Suggestions' started by Floren, Aug 3, 2014.
    60,082
    12,584
    11:01 AM
    Yeah depends solely on the site and even the style used i.e. soft responsive theme on this forum didn't have issues but Metro and Flat Awesome did. I don't have such problems with ngx_pagespeed and Wordpress and with vBulletin either.
    But I find you learn alot more via troubleshooting :)
    Also doesn't rule out SPDY conflicts too. Tweaked pagespeed.conf and moved the prioritize critical css filter under the defer js filter - not sure if order matters
      # defer_javascript
      # https://developers.google.com/speed/pagespeed/module/filter-js-defer
      pagespeed EnableFilters defer_javascript;
      # prioritize_critical_css
      # https://developers.google.com/speed/docs/mod_pagespeed/filter-prioritize-critical-css
       pagespeed EnableFilters prioritize_critical_css;
    prioritize critical css involves a bit of javascript
    60,082
    12,584
    11:01 AM
  3. Jalan
    Jalan New Member
    9:01 PM
    Hello,
    Whenever I start a new thread or try to reply the message box or text editor will be hidden, and I have to refresh several times until I get the text box where I can type my message. The problem started when I installed bdcache. I uninstalled it but the problem still remained.
    I have seen the same problem being solved here and the solution was given as below. could you please give me the proper instructions on how to solve this?
    I don't know where to add the pagespeed disallow code i.e., which directory, which file?
    Thank you in advance
    60,082
    12,584
    11:01 AM
    Did you specifically enable ngx_pagespeed as per instructions at ngx_pagespeed install on Centmin Mod - Menu based Nginx installer for CentOS servers ? if you did not, then ngx_pagespeed isn't your problem.
    If you did enable ngx_pagespeed, then read over the following:
