CVE-2026-109618 and CVE-2026-109619
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by allastronauts, Oct 21, 2026.
    60,296
    12,609
    6:58 PM
    I've tested this and have the functions/code in place just still undecided about forcing automatic updates on folks. Personally, I don't like it myself as I like to choose the time I update.
    But with ever increasing security landscape, might need to compromise (pun intended :LOL: ), and give into it as a user variable that can be enabled. But then if folks don't enable it, they just open to compromise!
    The other option I was thinking of being to able to remotely via cmupdate, trigger Nginx and PHP updates for severe security issues for all installs. But then again privacy and users might not like that even if it's to keep them safe. Decisions!
  2. Jon Snow
    Jon Snow Premium Member Premium Member
    934
    192
    4:58 AM
    Nginx 1.13.9
    MariaDB 10.1.31
    If it's minor version bumps, I'm all for forcing it but have an option to disable it.
    A better way to handle it would be to have a note in the terminal when the person next updates centminmod and have them enable forced updates by adding the variable to custom config?
  3. allastronauts
    allastronauts New Member
    7
    2:58 AM
    Yes. Opt-in please. Double plus good if we can set the opt-in based on the severity level of the CVE.
    I imagine a cron job to poke the bear every hour or something given this ever enshittening timeline.
  4. Dannymh
    Dannymh New Member
    27
    6
    9:58 AM
    1.7.x
    5.5
    Completely understand your hesitation, but I think if its an opt in via a flag or an option in the menu to turn on Critical Updates or a way for us to both opt in and trigger it from our side.
    I was going to just set cmupdate on a cron and then try to compile it but in the end I took the lazy route
  5. Colin
    Colin Premium Member Premium Member
    193
    60
    Sheffield UK
    8:58 AM
    1.19.#
    MariaDB 10.1.#
    Have to say thanks to XenForo too. Even though not an active user. Was away on holiday, the old laptop I lug around just in case got to be used again. Painless with Centmin.
    I'd be quite tempted to have an awol opt in auto update option. I mean we leave unattended upgrades to do it's thing and that works well enough.
    A SMS ( old school I know ) service ( happily pay for ) would also be fab. SMS is now a clear separation for me from social/chat notifications. I know SMS can be delayed too. There is nothing perfect, I could of just sat down on the cinema and turned my phone off :)
    Great work as always @eva2000 Thanks!
  6. deltahf
    600
    274
    3:58 AM
    I also understand the hesitation, but would immediately opt-in to critical automatic security updates if the option was available in Centminmod.
    60,296
    12,609
    6:58 PM
    Thanks for the support and appreciation :)
    Good news automatic Nginx and PHP-FPM upgrades feature is built and being tested in Centmin Mod 141.00beta01 right now ;)
  8. iaTa
    iaTa Member
    106
    8:58 AM
    MariaDB 10.11.x
    PHP
    23 Oct 2026
    Informational advisory: Session upload progress
    We suggest you set session.upload_progress.enabled=0 until the next regular bugfix release, to fully protect from an unlikely RCE vector. This setting was already listed as a mitigation in the GHSA-6wmf-4rv5-p3rp advisory for CVE-2026-109619 published on Oct 21st, 2026. If you applied it then, keep it in place and no further action is needed.
    The issue can only occur under an unusual combination of configuration and application code. An application must set session.serialize_handler to php_binary or php_serialize in its configuration and then switch it to php at runtime with ini_set() before calling session_start(). Session upload progress must also still be enabled. Applications that never change the serialize handler at runtime can keep the feature enabled. Since this setup is unlikely in practice, we are handling it in the regular release cycle and will publish a full advisory for CVE-2026-115560 with the next release.
    60,296
    12,609
    6:58 PM
    132.00stable, 140.00beta01, 141.00beta01 have this set now, just run cmupdate and recompile your php version via centmin.sh menu option 5
  10. duderuud
    duderuud Active Member
    328
    98
    The Netherlands
    9:58 AM
    1.29 x
    11.4
    I put it in the custom php.ini already...
  11. Itworx4me
    344
    35
    12:58 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    Why the 2 beta versions?
    60,296
    12,609
    6:58 PM
