Custom post-add nginx vhost
Discussion in 'Install & Upgrades or Pre-Install Questions' started by noxonx, Jun 29, 2020.
  1. noxonx
    noxonx New Member
    7:32 AM
    is it possible to run some custom script after creating nginx vhost? I need to set up HTTP basic authentication after each creation and it would be great if I didn't have to run the script manually every time but it could run after executing menu 2.
    Thank you.
    44,742
    10,200
    3:32 PM
    If you already have a script and using centmin.sh menu option 2 to create nginx vhosts, you can just script nginx vhost creation using alternative nv command line outlined at
    so enable letsencrypt SSL support one time task
    touch /etc/centminmod/custom_config.inc
    echo "LETSENCRYPT_DETECT='y'" >> /etc/centminmod/custom_config.inc
    then to create Nginx vhost domain = domain.com you make sure DNS A record for domain.com and www version of domain points to server IP address
    and then just run nv command line changing ftpusername to your desired pure-ftpd virtual ftp username
    nv -d domain.com -s lelived -u ftpusername
    if you have you own script to run afterwards and you modify to work based on domain name passed via the script, you can script it as such
    #!/bin/bash
    /run/your/script.sh domain.com
    Centmin Mod overview of all structures/config files at Centmin Mod Configuration Files - CentminMod.com LEMP Nginx web stack for CentOS so if your script modifies nginx vhost with https you'd want to be modifying /usr/local/nginx/conf/conf.d/domain.com.ssl.conf nginx vhost
  3. noxonx
    noxonx New Member
    7:32 AM
    Thanks, that's exactly what I need. I can also use mysqladmin_shell.ssh. All in one custom script.
    Can you write to me how can I check if vhost and mysql db have been successfully created to create a command string?
    Should I check the output or is it better to check the config (/usr/local/nginx/conf/conf.d/newdomain.com.conf) creation for vhost and db existence?
    Thank you.
    44,742
    10,200
    3:32 PM
    Yup that is the intention so you can script nginx vhost/site setups
    check for newdomain.com.conf or newdomain.com.ssl.conf in /usr/local/nginx/conf/conf.d and /home/nginx/domain/newdomain.com directory existence
    for mysql databases you can use mysqlshow command and checking command exit status via $? variable. When $? variable returns exit status = 0, means database exists and return non-zero value, means database doesn't exist
    dbname=mysql
    mysqlshow $dbname >/dev/null 2>&1; echo $?
    dbname=mysqlnot
