Nginx Custom Module
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by zakkaz, Jun 9, 2020.
  1. zakkaz
    zakkaz New Member
    7
    3:13 PM
    sorry for bother you, I am using CentminMOD from like 2 years.
    For the fist time I need add custom modules and them are not included in centminmod, I found them on github.
    I tried adding them with the guide, but without success.
    yaoweibin/nginx_http_recaptcha_module
    I wanted to add this, but it required other two modules:
    1. nginx_eval_module
    2. nginx_secure_cookie_module
    Can someone help me?
    51,261
    11,900
    12:13 AM
    That Nginx module hasn't been updated in 5 to 9+ yrs, most likely won't work with Nginx 1.19 mainline builds that Centmin Mod 123.09beta01 use though.
    If you need to custom add additional modules not supported by Centmin Mod Nginx read below. But first check with Centmin Mod 123.09beta01 as it has added variable support for other Nginx modules similar to above MP4 module via NGINX_MP4 that you can enable and recompile Nginx with. 123.09beta01 change log and centmin.sh list of variables you can place in the persistent config file at /etc/centminmod/custom_config.inc.
    I posted an example of how to add nginx modules to Centmin Mod at centminmod.com/nginx_webdav.html for webdav prior to it becoming an official part of Centmin Mod's default module list. You can use that example to pretty much add or extend Nginx with additional modules.
    Only limitations are
    1. You need to know generally how to add Nginx modules and that is basically the same for any Nginx server not just Centmin Mod
    2. You also need to know the instructions for specific Nginx module
    3. You also need to know any prerequiste system dependencies and YUM packages that the Nginx module requires as I may not know what they are as I may have never used the Nginx module you want.
    4. I'm limited to what I can add to Centmin Mod by what I know and use usually and what I am comfortable with supporting. So that limits what officially I can add to Centmin Mod. But you are free to add whatever you need using above as a guide.
    For Centmin Mod Nginx, download tar.gz nginx modules to /svr-setup and extract and then editing inc/nginx_configure.inc just use the same --add-module=../nginx-module-name line.
    Posted a more recent example below. Actual Github commits for adding 3 new Centmin Mod Nginx modules, echo-nginx-module, set-misc-nginx-module and ngx_devel_kit are located below (you can use these changes and webdav example as a blue print for understanding how to extend and add your own Centmin Mod Nginx modules.
    Github commits for 3 new Nginx modules
    General Info on Adding New Nginx Modules
    There's 5 basic steps involve in adding a new Nginx module into Centmin Mod Nginx server for Centmin Mod .08 beta02 and higher. They involve editing 5 Centmin Mod files.
    1. centmin.sh - add VARIABLE name to define the nginx module's version number if there is one
    2. inc/downloadlinks.inc - add 2 VARIABLES to define the module download link and filename
    3. inc/downloads.inc - add download function to download the module using download link defined in inc/downloadlinks.inc and test the download validity i.e. untar it using filename defined in inc/downloadlinks.inc
    4. inc/nginx_configure.inc - add check variables to grab latest nginx module extracted directory and put it info directory variable to be called from Nginx ./configure options only if NGINX_OPENRESTY='y'
    5. inc/nginx_upgrade.inc - add to existing file check, the new module download file name (defined in inc/downloadlinks.inc). This ensures, when you run centmin.sh menu option 4 to upgrade Nginx, if the new nginx module download file doesn't exist in /svr-setup, it will download it and extract it before the Nginx compilation begins
    Another way of doing it is shown at Nginx - A straight forward tutorial to install test-cookie? | Centmin Mod Community This way doesn't allow for managing nginx module version updates and auto updates via centmin.sh menu option 4 like the above method.
    The above is for nginx modules requiring additional downloads to be configured. There's also nginx modules which do not need additional downloads but just enabling of the nginx module itself. I just added ngx_http_auth_request_module to Nginx for .08 beta 03 as it only required adding --with-http_auth_request_module to configure options. You can see the changes I did here add ngx_http_auth_request_module support · centminmod/centminmod@ec079c5 · GitHub - similar to above instructions just did not need to touch inc/downloadslinks.inc and inc/downloads.inc and inc/nginx_upgrade.inc as there are NO additional downloads to account for and check.
