Current OwnCloud tuto
Discussion in 'Other Web Apps usage' started by Jota, Mar 22, 2016.
  1. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
  2. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
    Okay, I decided to use version 8.2.3 and all was Okay until I try to log in to the web interface.
    In fact main screen where you enter mysql credentials worked fine, but after that screen, I got a 404 error.
    Log --> [error] 28531#28531: *30 "/home/nginx/domains/domain.com/public/index.php/apps/files/index.php" is not found (20: Not a directory),
    I guess issue is this one: Owncloud has a buggy Nginx's configuration. - ownCloud Forums
    Any tip ? thanks ! ;)
    55,247
    12,253
    7:30 PM
    55,247
    12,253
    7:30 PM
    seems official docs at NGINX Configuration · owncloud/documentation Wiki · GitHub
    Example configs
    the 9.x config has some differences for the what is required for php location match in /usr/local/nginx/conf/phpowncloud.conf
    so /usr/local/nginx/conf/phpowncloud.conf would be something like this I believe (not tested)
    location ~ \.php(?:$|/) {
        fastcgi_split_path_info ^(.+\.php)(/.+)$;
        fastcgi_pass   127.0.0.1:9000;
        #fastcgi_pass   unix:/tmp/php5-fpm.sock;
        fastcgi_index  index.php;
        fastcgi_param PATH_INFO $fastcgi_path_info;
        fastcgi_param modHeadersAvailable true; #Avoid sending the security headers twice
    # might shave 200+ ms off PHP requests
    # which don't pass on a content length header
    # slightly faster page response time at the
    # expensive of throughput / scalability
    #sendfile on;
    #tcp_nopush off;
    #keepalive_requests 0;
    fastcgi_connect_timeout 60;
    fastcgi_send_timeout 180;
    fastcgi_read_timeout 180;
    fastcgi_buffer_size 512k;
    fastcgi_buffers 512 16k;
    fastcgi_busy_buffers_size 512k;
    fastcgi_temp_file_write_size 512k;
    fastcgi_intercept_errors on;
    #new .04+ map method
    fastcgi_param HTTPS $server_https;
    # comment out PATH_TRANSLATED line if /usr/local/lib/php.ini sets following:
    # cgi.fix_pathinfo=0
    # as of centminmod v1.2.3-eva2000.01 default is set to cgi.fix_pathinfo=1
    fastcgi_param  PATH_TRANSLATED    $document_root$fastcgi_path_info;
    fastcgi_param  QUERY_STRING       $query_string;
    fastcgi_param  REQUEST_METHOD     $request_method;
    fastcgi_param  CONTENT_TYPE       $content_type;
    fastcgi_param  CONTENT_LENGTH     $content_length;
    fastcgi_param  SCRIPT_NAME        $fastcgi_script_name;
    fastcgi_param  REQUEST_URI        $request_uri;
    fastcgi_param  DOCUMENT_URI       $document_uri;
    fastcgi_param  DOCUMENT_ROOT      $document_root;
    fastcgi_param  SERVER_PROTOCOL    $server_protocol;
    fastcgi_param  GATEWAY_INTERFACE  CGI/1.1;
    fastcgi_param  SERVER_SOFTWARE    nginx/$nginx_version;
    fastcgi_param  REMOTE_ADDR        $remote_addr;
    fastcgi_param  REMOTE_PORT        $remote_port;
    fastcgi_param  SERVER_ADDR        $server_addr;
    fastcgi_param  SERVER_PORT        $server_port;
    fastcgi_param  SERVER_NAME        $server_name;
    # PHP only, required if PHP was built with --enable-force-cgi-redirect
    fastcgi_param  REDIRECT_STATUS    200;
    and /usr/local/nginx/conf/owncloud.conf
    add_header X-Content-Type-Options nosniff;
    add_header X-Frame-Options "SAMEORIGIN";
    add_header X-XSS-Protection "1; mode=block";
    add_header X-Robots-Tag none;
    add_header X-Download-Options noopen;
    add_header X-Permitted-Cross-Domain-Policies none;
    client_max_body_size 10G; # set max upload size
    fastcgi_buffers 64 4K;
    index index.php;
    error_page 403 /core/templates/403.php;
    error_page 404 /core/templates/404.php;
    rewrite ^/.well-known/carddav /remote.php/dav/ permanent;
    rewrite ^/.well-known/caldav /remote.php/dav/ permanent;
    # The following 2 rules are only needed for the user_webfinger app.
    # Uncomment it if you're planning to use this app.
    #rewrite ^/.well-known/host-meta /public.php?service=host-meta last;
    #rewrite ^/.well-known/host-meta.json /public.php?service=host-meta-json last;
    location = /robots.txt {
    allow all;
    log_not_found off;
    access_log off;
    location ~ ^/(build|tests|config|lib|3rdparty|templates|data)/ {
    deny all;
    location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) {
    deny all;
    rewrite ^/remote/(.*) /remote.php last;
    rewrite ^(/core/doc/[^\/]+/)$ $1/index.html;
    try_files $uri $uri/ =404;
    All untested so :)
  5. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
    Thanks mate, but seems to not be working.
    Anyway, it's fine ... thanks again for your help ! ;)
  6. Ahmad
    Ahmad Active Member
    209
    80
    11:30 AM
    1.9.9
    10.1.10
    I have a working owncloud site on a centminmod vps. It's still 8.x and not planning to upgrade to 9.x anytime soon. Mostly used the owncloud nginx configuration guide.
    Will post my config later when I am on my pc.
  7. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
    Hey thanks Ahmad ! I'm sure that will help a lot !
    Cheers !
  8. Ahmad
    Ahmad Active Member
    209
    80
    11:30 AM
    1.9.9
    10.1.10
    Nginx vhost, may need to adapt it with your ssl config:
      listen 443 ssl http2;
      server_name mydomain.com www.mydomain.com;
      ssl_dhparam /usr/local/nginx/conf/ssl/mydomain.com/dhparam.pem;
      ssl_certificate      /etc/letsencrypt/live/mydomain.com/fullchain.pem;
      ssl_certificate_key  /etc/letsencrypt/live/mydomain.com/privkey.pem;
      # mozilla recommended
      ssl_ciphers ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA:!DES-CBC3-SHA;
      ########add_header Alternate-Protocol  443:npn-spdy/3;
      # HTTP Public Key Pinning Header uncomment only one that applies include or exclude domains.
      # You'd want to include subdomains if you're using SSL wildcard certificates
      # include subdomain
      #add_header Public-Key-Pins 'pin-sha256="LiZ43ky3AeWJWGMMEwSFL7K7VluhCyXxpc4fNMrEKW8=8ZudVEGSQ0KeoljREq9TMRaJCw4VdutRH8gYIwGIqUM="; pin-sha256="6j6EWkvIehZMt3GBbpcLPgEeAewLmun459IZLoOQo/I=fnk11YGOKNCHP1O0KiDuC5oLZ+clLgxQPby05wPL944="; max-age=86400; includeSubDomains';
      # exclude subdomains
      #add_header Public-Key-Pins 'pin-sha256="LiZ43ky3AeWJWGMMEwSFL7K7VluhCyXxpc4fNMrEKW8=8ZudVEGSQ0KeoljREq9TMRaJCw4VdutRH8gYIwGIqUM="; pin-sha256="6j6EWkvIehZMt3GBbpcLPgEeAewLmun459IZLoOQo/I=fnk11YGOKNCHP1O0KiDuC5oLZ+clLgxQPby05wPL944="; max-age=86400';
      ########spdy_headers_comp 5;
      ssl_buffer_size 1400;
      ssl_session_tickets on;
      # enable ocsp stapling
      resolver_timeout 10s;
      ssl_stapling on;
      ssl_stapling_verify on;
      ssl_trusted_certificate /etc/letsencrypt/live/mydomain.com/fullchain.pem;
      # Turn off pagespeed for this vhost
      pagespeed off;
      access_log /home/nginx/domains/mydomain.com/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/mydomain.com/log/error.log;
      root /home/nginx/domains/mydomain.com/public;
      location ~ (?:^|/)\. {
        deny all;
      include /usr/local/nginx/conf/owncloud.conf;
      include /usr/local/nginx/conf/phpowncloud.conf;
    /usr/local/nginx/conf/owncloud.conf:
    rewrite ^/caldav(.*)$ /remote.php/caldav$1 redirect;
    rewrite ^/carddav(.*)$ /remote.php/carddav$1 redirect;
    rewrite ^/webdav(.*)$ /remote.php/webdav$1 redirect;
    index index.php;
    location ~ ^/(data|config|\.ht|db_structure\.xml|README) {
         deny all;
        # The following 2 rules are only needed with webfinger
        rewrite ^/.well-known/carddav /remote.php/carddav/ redirect;
        rewrite ^/.well-known/caldav /remote.php/caldav/ redirect;
        try_files $uri $uri/ index.php;
    location ~ ^/home/nginx/domains/mydomain.com/public/data/.+$ {
        internal;
        root /;
    location ~ ^/tmp/oc-noclean/.+$ {
        internal;
        root /;
    location ~ "^/tmp/owncloud-oc[a-zA-Z0-9]{10}/.+$" {
        internal;
        root /;
    I had alot of issues when using the "normal" php file (/usr/local/nginx/conf/php.conf) and after alot of research I couldn't find a solution so I tested alot and giving the site a dedicated php-fpm pool fixed all the issues for som reasons. So you may need to do that too.
    Also you need to append the following to /usr/local/etc/php-fpm.conf:
    env[HOSTNAME] = $HOSTNAME
    env[PATH] = /usr/local/bin:/usr/bin:/bin
    env[TMP] = /tmp
    env[TMPDIR] = /tmp
    env[TEMP] = /tmp
  9. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
    I'll check this later .... will update you with the results, thanks buddy !!! ;)
  10. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
    I never have time for this things ..... also I'm so lazy and getting old ! :D
  11. hardousse
    hardousse Active Member
    169
    35
    Sweden
    12:30 PM
    1.11.*
    10.1*
    Did your config work with Owncloud 10?
  12. Jota
    Jota Member
    78
    Barcelona
    12:30 PM
    Hey @Ahmad .... thanks for this vaulable info ! I'll keep it in mind once I do have another OwnCloud box ! :)
