Sysadmin Directory Backup
Discussion in 'System Administration' started by Itworx4me, Feb 9, 2025.
  1. Itworx4me
    344
    35
    9:10 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    Would this be the correct way to backup a directory?
    tar -czf archive.name.tar.gz /home/nginx/domains/mydomain.com/public
    Thanks,
    Itworx4me
    2:10 AM
    tar -czpf archive.name.tar.gz -C /home/nginx/domains/mydomain.com public
    • tar → Calls the tar utility.
    • -c → Creates a new archive.
    • -z → Compresses the archive using gzip.
    • -p → Preserves file permissions.
    • -f archive.name.tar.gz → Specifies the archive filename.
    • -C /home/nginx/domains/mydomain.com → Changes the working directory to /home/nginx/domains/mydomain.com before archiving.
    • public → The relative path of the folder being archived.
    To restore the archive back to /home/nginx/domains/mydomain.com/, run:
    tar -xzpf archive.name.tar.gz -C /home/nginx/domains/mydomain.com
    This will restore the public/ directory inside /home/nginx/domains/mydomain.com/, keeping its structure and permissions intact. If you want to restore to a staging directory first, change the path for -C flag
  3. Itworx4me
    344
    35
    9:10 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    Thank you. Much appreciated
