MariaDB Curious why InnoDB Buffer Pool load on startup isn't enabled?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by jeffwidman, Feb 26, 2015.
  1. jeffwidman
    jeffwidman Active Member
    152
    27
    8:29 AM
    Per Understanding MySQL’s InnoDB buffer pool | Michael Bouvy
    Seems like this would be a nice thing to enable on Centminmod's default MariaDB 10 my.cnf templates??
    Here's the official docs: XtraDB/InnoDB Server System Variables - MariaDB Knowledge Base
    Also, if this is enabled, probably want to set
     innodb_blocking_buffer_pool_restore = 1
    Only caveat is I'm not sure how this is affected by changed in the buffer pool size. I know most of the time when I'm restarting mysql, it's because I adjusted the size of the buffer pool.
    55,397
    12,255
    1:29 AM
    doh thought I already had those in MariaDB 10 default my.cnf templates had the wrong ones commented out
    #innodb_buffer_pool_load_now=1
    #innodb_buffer_pool_dump_now=1
    should be
    innodb_buffer_pool_dump_at_shutdown=1
    innodb_buffer_pool_load_at_startup=1
    will update .08 beta with it enabled :)
    55,397
    12,255
    1:29 AM
    Done updated .08 beta 's MariaDB 10 my.cnf default template with correct innodb buffer pool dump and load settings update default MariaDB 10 my.cnf template settings for .08 beta · 1eaecdb · centminmod/centminmod · GitHub :)
    Ah now I remember why it wasn't added to default template as very early MariaDB 10 versions in alpha and beta releases were default using Oracle InnoDB plugin by default and not Percona's XtraDB Innodb plugin and didn't support those variables. Only later did MariaDB 10 releases switched to XtraDB InnoDB plugin and supported those values IIRC
