CSF limit problem
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by hitman, Jul 23, 2014.
  1. hitman
    hitman Member
    126
    11
    9:56 PM
    hallo i tried to limit the connections per IP
    i show that there is the way with domain.com.conf with the limit_conn limit_per_ip 16;
    and there is the the connection limit through csf
    i do not know if these 2 ways are relevant or even if they are the same but the fact is that although i have used both it does not work.
    here is the results after running the /etc/csf/csftest.pl
    Testing ip_tables/iptable_filter...OK
    Testing ipt_LOG...OK
    Testing ipt_multiport/xt_multiport...OK
    Testing ipt_REJECT...OK
    Testing ipt_state/xt_state...OK
    Testing ipt_limit/xt_limit...OK
    Testing ipt_recent...OK
    Testing xt_connlimit...FAILED [Error: iptables: Invalid argument. Run `dmesg' fo r more information.] - Required for CONNLIMIT feature
    Testing ipt_owner/xt_owner...OK
    Testing iptable_nat/ipt_REDIRECT...OK
    Testing iptable_nat/ipt_DNAT...OK
    as you can see the xt_connlimit failed,how can i fix that or what else can be done
    thank you
    55,335
    12,255
    4:56 AM
