CSF CSF Firewall info
Discussion in 'Other Centmin Mod Installed software' started by eva2000, May 25, 2014.
    12,578
    7:31 PM
    For folks wondering what /etc/csf/csf.conf settings are, you can also check out the web server demo at ConfigServer Security & Firewall for easier reading :)
  2. Sunka
    Sunka Well-Known Member
    1,150
    325
    Pula, Croatia
    11:31 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    Yesterday, I reinstall my windows, and after setup I tried to connect to my host through ssh from my PC. Because of wrong password csf firewall blocked my IP, and only way to connect is with terminal directly through Digital Ocean.
    I google for solution and this is what I found. I solved my problem, and if anybody come to exact problem, here is solution.
    P.S. Many of this commands is allready posted in this thread, but it is not pity to post it again all in one post.
    enable CSF
    csf -e
    restart the CSF
    csf -r
    disable CSF
    csf -x
    For remove blocked ip:
    csf -dr YOURIPADDRESS
    For whitelist ip:
    csf -a YOURIPADDRESS
    list temporary blocked IP
    /usr/sbin/csf -t
    flush all temporary blocked IP
    /usr/sbin/csf -tf
    Just flush the tables. If you have installed csf then use
    csf -f
    If you are running with iptables then use
    iptables --flush
    For more command line options try
    csf --help
    12,578
    7:31 PM
    12,578
    7:31 PM
  5. Ahmad
    Ahmad Active Member
    209
    80
    11:31 AM
    1.9.9
    10.1.10
    I do this on every server I own and it saved me already a few times (I have a dynamic IP.so this is really handy) ;)
  6. ModeltogTossen
    313
    97
    Denmark
    11:31 AM
    1.9.12
    10.0.23
    I also have dynamic ip - have vpn access to work - and that public IP is whitelisted on everything I do - so if something happens - from home, remote desktop to a management server with putty on work and then ssh from that into the 'faulty' server and alter it.
    12,578
    7:31 PM
    (y)
    (y)
    both good ideas :)
  8. Sunka
    1,150
    325
    Pula, Croatia
    11:31 AM
    Nginx 1.17.9
    MariaDB 10.3.22
    When we ban some Ip, or put into whitelist, is that valid at that moment, or we have to restart first csf?
    12,578
    7:31 PM
    valid immediately without restart
  10. MaximilianKohler
    MaximilianKohler Member
    220
    2:31 AM
