CSF Centos issue
Discussion in 'Other Centmin Mod Installed software' started by Jake, Mar 31, 2015.
  1. Jake
    Jake Member
    76
    8:26 PM
    NA
    Maria DB 5.5
    Hey Guys,
    I have a really ANNOYING issue. I somehow keep getting ipbanned from my server. I have white listed, ignored, my ip. I have checked the deny file, nothing. Any ideas?
  2. Jake
    Jake Member
    76
    8:26 PM
    NA
    Maria DB 5.5
    PS. I am able to get on the site on my phone, logged into wifi that is on the same connection as this computer.
    49,875
    11,487
    8:26 PM
    That's strange is your ip address dynamic ip ? If so might need additional step for dynamic ip CSF Firewall whitelisting outlined here
    1. Double check again that your ip address is not in /etc/csf/csf.deny file
    2. Use csf -g to grep your ip to make sure for instance checking ip 77.236.96.162
    csf -g 77.236.96.162
    Chain            num   pkts bytes target     prot opt in     out     source               destination
    DENYIN           46       0     0 DROP       all  --  !lo    *       77.236.96.162        0.0.0.0/0
    DENYOUT          46       0     0 LOGDROPOUT  all  --  *      !lo     0.0.0.0/0            77.236.96.162
    csf.deny: 77.236.96.162 # lfd: 77.236.96.162 (DE/Germany/webbox1114.server-home.net), 5 distributed sshd attacks on account [PlcmSpIp] in the last 3600 secs - Mon Mar 30 04:34:07 2015
    and check /var/log/lfd.log via grep
    grep 77.236.96.162 /var/log/lfd.log
    Mar 30 04:34:07 skys02 lfd[17986]: 77.236.96.162 (DE/Germany/webbox1114.server-home.net), 5 distributed sshd attacks on account [PlcmSpIp] in the last 3600 secs - *Blocked in csf* [LF_DISTATTACK]
    3. have you manually enabled any of the /etc/csf/csf.blocklists ? if you have double check your ip is not listed in spam black lists at Email Blacklist Check - See if your server is blacklisted
    # Copyright 2006-2015, Way to the Web Limited
    # URL: http://www.configserver.com
    # Email: sales@waytotheweb.com
    # This file contains definitions to IP BLOCK lists.
    # Uncomment the line starting with the rule name to use it, then restart csf
    # and then lfd
    # Each block list must be listed on per line: as NAME|INTERVAL|MAX|URL
    #   NAME    : List name with all uppercase alphabetic characters with no
    #             spaces and a maximum of 9 characters - this will be used as the
    #             iptables chain name
    #   INTERVAL: Refresh interval to download the list, must be a minimum of 3600
    #             seconds (an hour), but 86400 (a day) should be more than enough
    #   MAX     : This is the maximum number of IP addresses to use from the list,
    #             a value of 0 means all IPs
    #   URL     : The URL to download the list from
    # Note: Some of thsese lists are very long (thousands of IP addresses) and
    # could cause serious network and/or performance issues, so setting a value for
    # the MAX field should be considered
    # After making any changes to this file you must restart csf and then lfd
    # If you want to redownload a blocklist you must first delete
    # /var/lib/csf/csf.block.NAME and then restart csf and then lfd
    # Each URL is scanned for an IPv4/CIDR address per line and if found is blocked
    # Spamhaus Don't Route Or Peer List (DROP)
    # Details: http://www.spamhaus.org/drop/
    #SPAMDROP|86400|0|http://www.spamhaus.org/drop/drop.lasso
    # Spamhaus Extended DROP List (EDROP)
    #SPAMEDROP|86400|0|http://www.spamhaus.org/drop/edrop.lasso
    # DShield.org Recommended Block List
    # Details: http://dshield.org
    #DSHIELD|86400|0|http://www.dshield.org/block.txt
    # TOR Exit Nodes List
    # Set URLGET in csf.conf to use LWP as this list uses an SSL connection
    # Details: https://trac.torproject.org/projects/tor/wiki/doc/TorDNSExitList
    #TOR|86400|0|https://check.torproject.org/cgi-bin/TorBulkExitList.py?ip=1.2.3.4
    # Alternative TOR Exit Nodes List
    # Details: http://torstatus.blutmagie.de/
    #ALTTOR|86400|0|http://torstatus.blutmagie.de/ip_list_exit.php/Tor_ip_list_EXIT.csv
    # BOGON list
    # Details: http://www.team-cymru.org/Services/Bogons/
    #BOGON|86400|0|http://www.cymru.com/Documents/bogon-bn-agg.txt
    # Project Honey Pot Directory of Dictionary Attacker IPs
    # Details: http://www.projecthoneypot.org
    #HONEYPOT|86400|0|http://www.projecthoneypot.org/list_of_ips.php?t=d&rss=1
    # C.I. Army Malicious IP List
    # Details: http://www.ciarmy.com
    #CIARMY|86400|0|http://www.ciarmy.com/list/ci-badguys.txt
    # BruteForceBlocker IP List
    # Details: http://danger.rulez.sk/index.php/bruteforceblocker/
    #BFB|86400|0|http://danger.rulez.sk/projects/bruteforceblocker/blist.php
    # OpenBL.org 30 day List
    # Details: https://www.openbl.org
    #OPENBL|86400|0|https://www.openbl.org/lists/base_30days.txt
    # Autoshun Shun List
    # Details: http://www.autoshun.org/
    #AUTOSHUN|86400|0|http://www.autoshun.org/files/shunlist.csv
    # MaxMind GeoIP Anonymous Proxies
    # Details: https://www.maxmind.com/en/anonymous_proxies
    #MAXMIND|86400|0|https://www.maxmind.com/en/anonymous_proxies
    # Blocklist.de
    # Details: https://www.blocklist.de
    # This first list only retrieves the IP addresses added in the last hour
    #BDE|3600|0|https://api.blocklist.de/getlast.php?time=3600
    # This second list retrieves all the IP addresses added in the last 48 hours
    # and is usually a very large list (over 10000 entries), so be sure that you
    # have the resources available to use it
    #BDEALL|86400|0|http://lists.blocklist.de/lists/all.txt
    4. double check if ip is set in /etc/csf/csf.ignore
    # The following IP addresses will be ignored by all lfd checks
    # One IP address per line
    # CIDR addressing allowed with a quaded IP (e.g. 192.168.254.0/24)
    # Only list IP addresses, not domain names (they will be ignored)
    127.0.0.1
  4. Jake
    Jake Member
    76
    8:26 PM
    NA
    Maria DB 5.5
    I double checked its def not in the deny list,
    2) Doing 2. Use csf -g to grep your ip to make sure for instance checking ip myip
    returns nothing
    3)3. have you manually enabled any of the /etc/csf/csf.blocklists
    Nope, also have the ipadress in ignore, so when I check grep in the LFD it shows abunch of ignored IP addresses from SSH
    49,875
    11,487
    8:26 PM
    what's the exact symptoms you get that make you think it's banning you ?
    what can you access on desktop ? anything ? SSH into server ? if you can SSH in but can't view site it could be block at nginx server level ? can you access any other site on your server ? i.e. the main hostname ?
  6. Jake
    Jake Member
    76
    8:26 PM
    NA
    Maria DB 5.5
    What I do, I am just simply viewing the main page, when I click to go somewhere else I get the generic "Cant connect" on the browser, I then attempt to open up SSH via putty, doesnt work, then I attempt ssh via filezilla, doesnt connect. But I do the exact thing on my phone, and it works fine! I also ask users in the shoutbox, and they arent experiencing any issues,
    49,875
    11,487
    8:26 PM
    who's your web host ? maybe they have a firewall level above your server ?
    you can also grep all your server logs for you ip to see if any show the ip
    grep -Ro youripaddress /var/log/*
  8. Jake
    Jake Member
    76
    8:26 PM
    NA
    Maria DB 5.5
    Its Linode.
  9. Jake
    Jake Member
    76
    8:26 PM
    NA
    Maria DB 5.5
    I did that and got a ton of stuff with my IP, what am I looking for?
    49,875
    11,487
    8:26 PM
    to narrow it down far left should show the filename of the log in /var/log/filename
    this will only print far left file name
    grep -Ro youripaddress /var/log/* | awk -F ":" '{print $1}' | uniq
    what's the filename that is outputted
  11. AlekseY
    AlekseY Member
    47
    1:26 PM
    If you changed the ssh port, you must add it to the trusted
    49,875
    11,487
    8:26 PM
    FYI, if you change SSHD port via centmin.sh menu option 16, it will auto add the new SSHD port to csf trusted ports list for TCP_IN
    menu option 16 will prompt first for default SSHD port currently used i.e. 22 and then prompt for new SSHD port you want to use.
    Centmin Mod 1.2.3-eva2000.07 - http://centminmod.com
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    22). Exit
    Enter option [ 1 - 22 ]
