Beta Branch Cronjob Auto Updating Centmin Mod Code Guide
Discussion in 'Beta release code' started by eva2000, Jun 15, 2015.
  1. RB1
    RB1 Active Member
    292
    75
    California
    1:45 AM
    MariaDB 10.1.x
    Different from my current cron?
    15 */3 * * * /root/tools/updatecm.sh 2>/dev/null
    59,950
    12,556
    6:45 PM
    yeah just change your cronjob to the updated one AFTER you had updated one more time via centmin.sh menu option 23 submenu option 2 to pull in the updated new /usr/local/src/centminmod/updatecm.sh script
  3. pamamolf
    4,127
    11:45 AM
    So is that needed now?
    0 */4 * * * /usr/bin/cminfo_updater 2>/dev/null
    Sorry don't remember what is it for.... :(
    59,950
    12,556
    6:45 PM
    That is separate cron for cminfo command update so still needed
  5. GamerJota
    GamerJota Member
    49
    7
    5:45 AM
    Hello, I'm going to leave a note in here.
    If for any reason, when you log in as root and centmin gets stucked at "Current Nginx Version - Latest Nginx Available" or if it also does it when you try to execute centmin, updatecm.sh is your saviour.
  6. Itworx4me
    343
    35
    1:45 AM
    Nginx 1.27.4
    MariaDB 10.6.21
    Just making sure this is the only line you need to run at command prompt?
    0 */6 * * * /usr/local/src/centminmod/updatecm.sh 2>/dev/null
    Do you still have to setup git environment?
    Thanks,
    Itworx4me
    59,950
    12,556
    6:45 PM
    59,950
    12,556
    6:45 PM
    Reminder, when you log into your Centmin Mod 123.09beta01 server, the MOTD info display will tell you if you have Centmin Mod code updates available i.e.
     Centmin Mod code updates available for /usr/local/src/centminmod
     to update re-run centmin.sh menu option 23 submenu option 2
    or when up to date
     Centmin Mod local code is up to date at /usr/local/src/centminmod
     no available updates at this time...
