Create Multi Vhost Script
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by TRINH AI QUOC, Jun 1, 2021.
  1. TRINH AI QUOC
    TRINH AI QUOC New Member
    13
    6:33 PM
    1.17.3
    Hi All, and @eva2000 ^^
    i must change my web server, i have 250 domains.
    May anyone help me, how to make script to create multi vhost for centmin.sh
    Thanks you so much !!!
    54,600
    12,225
    9:33 PM
  3. TRINH AI QUOC
    13
    6:33 PM
    1.17.3
    Sorry I searched but couldn't find it. Thank you very much eva2000. I am very grateful to you for your enthusiastic support, answering all members' questions.
    Have A Good Day !!!
  4. TRINH AI QUOC
    13
    6:33 PM
    1.17.3
    hi @eva2000.
    i use nv command to create vhost.
    (I create 500 wordpress websites, but every time I configure website wordpress I have to remove the # tag manually in /usr/local/nginx/conf/conf.d
    file domain.ssl.conf
    Every time I remove the # tag I have to use nprestart (all the web will be paused when nprestart finish.)
    Is there a way to create a vhost then automatically remove the # tag in
    # try_files $uri $uri/ /index.php?q=$uri&$args;
    centminmod auto create file domain.ssl.conf
    i want to file domain.ssl.conf on /usr/local/nginx/conf/conf.d auto remove tag # like this.
    Please help me @eva2000 .
    Thanks Full !!!
    54,600
    12,225
    9:33 PM
    54,600
    12,225
    9:33 PM
    Back on desktop now, so for sed replacement as per that link for yours would be like
    for single domain nginx vhost
    domain=yourdomain.com
    sed -i "s|#try_files \$uri \$uri\/ \/index.php?q=\$uri\&\$args;| try_files \$uri \$uri\/ \/index.php?q=\$uri\&\$args;|" /usr/local/nginx/cpnf/conf.d/$domain.ssl.conf
    or for bulk domains listed in a file /home/vhostlist.txt
    while read -r d; do echo "update /usr/local/nginx/cpnf/conf.d/${d}.ssl.conf"; sed -i "s|#try_files \$uri \$uri\/ \/index.php?q=\$uri\&\$args;| try_files \$uri \$uri\/ \/index.php?q=\$uri\&\$args;|" /usr/local/nginx/cpnf/conf.d/${d}.ssl.conf; done < /home/vhostlist.txt
    where /home/vhostlist.txt contains list of domains
    domain1.com
    domain2.com
    domain3.com
    I'd test this on a separate test bulk nv command run on a test server first
    54,600
    12,225
    9:33 PM
    FYI, I am working on a new advance method for bulk Nginx vhost creation using JSON config files https://community.centminmod.com/th...00beta01-release-discussion.22676/#post-93300
    A very early alpha version can be previewed at GitHub - centminmod/centminmod-config-json not ready for production use, but gives you an idea of what's to come :)
  8. TRINH AI QUOC
    13
    6:33 PM
    1.17.3
    Thank you so much !!!
    I solved my issue.
