Nginx CORS Headers
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Matt Williams, Feb 6, 2015.
  1. Matt Williams
    537
    104
    Virginia, USA
    8:56 AM
    latest
    When I apply MaxCDN to any site, Font awesome ( web fonts ) disappears. I've added
    location ~ \.(js|css|png|jpg|jpeg|gif|ico|html|woff|ttf|svg|eot|otf)$ {
    add_header "Access-Control-Allow-Origin" "*";
    expires 1M;
    access_log off;
    add_header Cache-Control "public";
    In the /usr/local/nginx/conf/staticfiles.conf but it's still giving me an issue. It doesn't load the headers. It's like something is blocking it but I can't figure out what it could be. I have spent hours with MaxCDN tech support to nothing working. Hopefully someone here will have the right answer...
    55,801
    12,271
    10:56 PM
    maybe MaxCDN's own header management overriding your local headers ? Use browser's dev tool network and console tabs to troubleshoot your site's page loading :)
    Also try
    add_header Access-Control-Allow-Origin "*";
    see How to use CDN with Webfonts | MaxCDN One and Edge Rules Recipes | MaxCDN One
    I use KeyCDN and they have option on their edge servers for CORS for this cors_enabled.png
  3. AKIN SENOL
    AKIN SENOL Member
    36
    London
    1:56 PM
    1.9.12
    10.1.12
    I found some information in Mozilla Developer site HTTP access control (CORS) - HTTP | MDN
    I think, our nginx header conf need some Preflighted requests e.g.
    Access-Control-Request-Method: POST
    Access-Control-Request-Headers: X-PINGOTHER
    And the other Access-Control-Expose-Headers e.g.
    Access-Control-Expose-Headers: X-My-Custom-Header, X-Another-Custom-Header
    And Access-Control-Allow-Credentials e.g.
    Access-Control-Allow-Credentials: true | false
    What do you think @eva2000
    55,801
    12,271
    10:56 PM
    honestly not entirely sure that is needed, if CDN provider properly handles their added headers for CORS, you shouldn't need to do anything on Nginx level. I use KeyCDN and it properly provides the CORS header for CDN specially served content.
  5. AKIN SENOL
    AKIN SENOL Member
    36
    London
    1:56 PM
    1.9.12
    10.1.12
    55,801
    12,271
    10:56 PM
    If you use your own CDN, then you should use your own domain name which for me would bypass any CORS restrictions I think?.
    Using CORS - HTML5 Rocks
    I've been working on and developing my own GeoDNS SPDY SSL based CDN for private use and not having such with the mini rollout I tested on some of my sites. But definitely yes we need to work this out on Nginx level if possible as clearly not all CDN providers have CORS support :)
