Xenforo Connection timeout when sending emails
Discussion in 'Forum software usage' started by Afterward, Sep 18, 2014.
  1. Afterward
    Afterward Member
    94
    29
    4:51 AM
    1.7.5
    5.5
    Zend_Mail_Protocol_Exception: Email to email@gmail.com failed: Connection timed out - library/Zend/Mail/Protocol/Abstract.php:277
    Is this related to the firewall that centminmod uses? because im using mandrill via smtp.
    Thank you.
    55,983
    1:51 PM
    yup CSF Firewall needs tuning see CSF Firewall - Centmin Mod - Menu based Nginx installer for CentOS servers
    most common is TCP_OUT port 587 needs adding or whatever you using to connect to Mandrill
  3. Afterward
    Afterward Member
    94
    29
    4:51 AM
    1.7.5
    5.5
    When i added post 587 and saved then csf -r i got this error
    Error: The VPS iptables rule limit (numiptent) is too low to add 6568 rules (99/1000) - *IPs not added*, at line 3844
    Do you have any idea what is this exactly o_O
    55,983
    1:51 PM
    you using OpenVZ VPS, it has limits on processes like numiptent :(
    You probably want to use XEN or KVM based VPSes
