Sysadmin Connection refused after yum update
Discussion in 'System Administration' started by negative, Dec 13, 2016.
  1. negative
    negative Active Member
    415
    50
    12:43 AM
    1.9.10
    10.1.11
    [root@server centminmod]# yum list firewalld firewalld-filesystem -q
    Kurulan Paketler
    firewalld.noarch        0.4.3.2-8.1.el7_3                                                       @updates
    firewalld-filesystem.noarch                                                       0.4.3.2-8.1.el7_3                                                       @updates
    [root@server centminmod]# yum history info firewalld firewalld-filesystem -q
    Transaction ID : 61
    Başlama zamanı     : Sat Jan 21 01:02:06 2017
    -edit
    59,935
    12,556
    7:43 AM
    looks like it goes back to yum transaction id = 1
    Transaction ID : 1
    Başlama zamanı     : Fri Sep  9 21:32:02 2016
    So firewalld was installed on your system via os default image. Centmin Mod doesn't install firewalld by default but if it detects it, it will stop/disable firewalld without removal. So probably what happened for you.
    some packages depend on firewalld and blind removal might remove those packages accidentally too
    and what firewalld depends on
    repoquery --requires --resolve firewalld
    iptables-services-0:1.4.21-17.el7.x86_64
    iptables-0:1.4.21-17.el7.x86_64
    bash-0:4.2.46-20.el7_2.x86_64
    python-0:2.7.5-48.el7.x86_64
    ebtables-0:2.0.10-15.el7.x86_64
    ipset-0:6.19-6.el7.x86_64
    systemd-0:219-30.el7.x86_64
    python-firewall-0:0.4.3.2-8.1.el7_3.noarch
    firewalld-filesystem-0:0.4.3.2-8.1.el7_3.noarch
    yum deplist firewalld -q
    package: firewalld.noarch 0.4.3.2-8.1.el7_3
      dependency: /bin/bash
       provider: bash.x86_64 4.2.46-21.el7_3
      dependency: /bin/sh
      dependency: /usr/bin/python
       provider: python.x86_64 2.7.5-48.el7
      dependency: ebtables
       provider: ebtables.x86_64 2.0.10-15.el7
      dependency: firewalld-filesystem = 0.4.3.2-8.1.el7_3
       provider: firewalld-filesystem.noarch 0.4.3.2-8.1.el7_3
      dependency: ipset
       provider: ipset.x86_64 6.19-6.el7
      dependency: iptables
       provider: iptables-services.x86_64 1.4.21-17.el7
       provider: iptables.x86_64 1.4.21-17.el7
      dependency: python-firewall = 0.4.3.2-8.1.el7_3
       provider: python-firewall.noarch 0.4.3.2-8.1.el7_3
      dependency: systemd
       provider: systemd.x86_64 219-30.el7_3.6
    So should be fine to leave as is
    59,935
    12,556
    7:43 AM
    looks like good to just remove them if you want
    yum remove firewalld firewalld-filesystem
    Resolving Dependencies
    --> Running transaction check
    ---> Package firewalld.noarch 0:0.4.3.2-8.1.el7_3 will be erased
    ---> Package firewalld-filesystem.noarch 0:0.4.3.2-8.1.el7_3 will be erased
    Dependencies Resolved
     Package                                                             Arch                                                  Version                                                          Repository                                               Size
    Removing:
     firewalld                                                           noarch                                                0.4.3.2-8.1.el7_3                                                @updates                                                1.7 M
     firewalld-filesystem                                                noarch                                                0.4.3.2-8.1.el7_3                                                @updates                                                239
    Transaction Summary
    Remove  2 Packages
    Installed size: 1.7 M
    Is this ok [y/N]: y
    Downloading packages:
    Running transaction test
    Transaction test succeeded
    Running transaction
      Erasing    : firewalld-0.4.3.2-8.1.el7_3.noarch        1/2
      Erasing    : firewalld-filesystem-0.4.3.2-8.1.el7_3.noarch        2/2
      Verifying  : firewalld-0.4.3.2-8.1.el7_3.noarch        1/2
      Verifying  : firewalld-filesystem-0.4.3.2-8.1.el7_3.noarch        2/2
    Removed:
      firewalld.noarch 0:0.4.3.2-8.1.el7_3        firewalld-filesystem.noarch 0:0.4.3.2-8.1.el7_3
    Complete!
  4. negative
    415
    50
    12:43 AM
    1.9.10
    10.1.11
    So, should i run FIRST only that command now? before yum update
    What about some packages depend on firewalld ?
    59,935
    12,556
    7:43 AM
    only need to do yum remove once for that and no extra packages seem to be removed so that's good
  6. khine
    khine New Member
    6:43 AM
    I did yum update command and server updated, installed in centos 7.
    When I browse, I got 192.168.11.24 refused to connect error. I saw that firewalld is active, then I remove firewalld as well and I also try to undo using yum history undo transactionID but this not success also.Can someone help me?
    59,935
    12,556
    7:43 AM
    Are you using Centmin Mod LEMP stack ? this forum is for Centmin Mod LEMP stack support. I ask as Centmin Mod doesn't use firewalld but CSF Firewall so usually firewalld isn't active.
  8. khine
    khine New Member
    6:43 AM
    humm,No Centmin Mod LEMP stack.sorry. actually i am CentOS Linux release 7.4.1708 (Core) and I did installation of phpMyAdmin and i did
    sudo yum install -y epel-release
    sudo yum –y update
    after that i cannot browse the server.
    59,935
    12,556
    7:43 AM
    Unfortunately wouldn't be able to help you as Centmin Mod doesn't use firewalld. Might want to ask on CentOS 7 official forums CentOS - CentOS 7
