Featured Install Compiling Newer Versions of Clang 4.0
Discussion in 'Centmin Mod User Tutorials & Guides' started by Revenge, Jan 31, 2017.
    11:58 PM
    11:58 PM
    Clang 5 Release Retested
    Clang 5.0 final release was made, so retested my Clang 4.0.1 + 5.0 installer on my OVH i7 4790K 32GB server to compare with install times on my Intel Xeon E3-1270v1, 16GB server which took ~67 minutes to install. Should be faster due to i7 4790K's higher cpu clock speed 4.0-4.4GHZ versus E3-1270v1 @3.4-3.8Ghz clock speed. Would really like to see how Clang compiles on AMD EPYC servers one day :)
    From LLVM 5.0 Released With C++17 Support, Ryzen Scheduler, AMDGPU Vega & Much More - Phoronix
    Installed Clang 4.0.1 + 5.0 with GCC 6.2.1 Gold linker enabled.
    Took ~47 minutes to install so faster than E3-1270v1 time of ~67 minutes due to higher clock speed and new processor :)
    tail -1 /root/centminlogs/centminmod_llvm_090917-052357.log
    Total LLVM 4 & 5 Build Time: 2821.023094214 seconds
    /usr/local/bin/ld -v
    GNU ld (GNU Binutils) 2.29
    /usr/local/bin/ld.gold -v
    GNU gold (GNU Binutils 2.29) 1.14
    /usr/local/bin/ld.bfd -v
    /opt/sbin/llvm-release_50/bin/clang -v
    clang version 5.0.0 (branches/release_50 312855)
    Target: x86_64-unknown-linux-gnu
    Thread model: posix
    InstalledDir: /opt/sbin/llvm-release_50/bin
    Found candidate GCC installation: /opt/rh/devtoolset-4/root/usr/lib/gcc/x86_64-redhat-linux/5.3.1
    Found candidate GCC installation: /opt/rh/devtoolset-6/root/usr/lib/gcc/x86_64-redhat-linux/6.2.1
    Found candidate GCC installation: /usr/lib/gcc/x86_64-redhat-linux/4.8.2
    Found candidate GCC installation: /usr/lib/gcc/x86_64-redhat-linux/4.8.5
    Selected GCC installation: /opt/rh/devtoolset-6/root/usr/lib/gcc/x86_64-redhat-linux/6.2.1
    Candidate multilib: .;@m64
    Candidate multilib: 32;@m32
    Selected multilib: .;@m64
    /opt/sbin/llvm-release_40/bin/clang -v
    clang version 4.0.1 (branches/release_40 312854)
    Thread model: posix
    InstalledDir: /opt/sbin/llvm-release_40/bin
    Selected GCC installation: /opt/rh/devtoolset-4/root/usr/lib/gcc/x86_64-redhat-linux/5.3.1
    Centmin Mod 123.09beta01's Nginx 1.13.5 compiled with newly installed Clang 5.0
    11:58 PM
    11:58 PM
    11:58 PM
    Clang 5.0.1 was released so retesting source compile of Clang 5.0.1 (compiled using GCC 6.3.1) on soon to be canceled OVH MC-64-OC i7 7700K @4.7-5.0Ghz, 64GB, 2x 450GB NVMe raid 1 server running CentOS 7.4 64bit with Centmin Mod 123.09beta01 :)
    Clang 5.0.1 source compiled in 19 mins 16s :)
    GNU ld (GNU Binutils) 2.29.1
    GNU gold (GNU Binutils 2.29.1) 1.14
    clang version 5.0.1 (branches/release_50 321398)
    Thread model: posix
    Found candidate GCC installation: /opt/rh/devtoolset-6/root/usr/lib/gcc/x86_64-redhat-linux/6.3.1
    Selected GCC installation: /opt/rh/devtoolset-6/root/usr/lib/gcc/x86_64-redhat-linux/6.3.1
    ls -lah /opt/sbin/llvm-release_50/lib/LLVMgold.so
    -rwxr-xr-x 1 root root 27M Dec 23 04:16 /opt/sbin/llvm-release_50/lib/LLVMgold.so
    tail -1 /root/centminlogs/centminmod_llvm_231217-035911.log
    real    19m16.825s
    user    137m0.376s
    sys     6m41.430s
    11:58 PM
    Clang 5.0.1 and 6.0.0 testing
    clang version 5.0.1 (branches/release_50 323061)
    Thread model: posix
    /opt/sbin/llvm-release_60/bin/clang -v
    clang version 6.0.0 (branches/release_60 323061)
    Thread model: posix
    InstalledDir: /opt/sbin/llvm-release_60/bin
    11:58 PM
    Latest source compiled Clang 4.0.1, 5.0.1 and 6.0.0 compilers builds :)
    Clang 6.0.0 compiler built Centmin Mod Nginx 1.13.9 web server :D Unfortunately, some compatibility issues with Clang 6.0.0 and Cloudflare zlib forked library so have to switch back to standard zlib 1.2.11 library and Clang 6.0.0 throws up an error with OpenSSL 1.1.1-pre2 beta crypto library so using OpenSSL 1.1.0g stable
    clang version 6.0.0 (branches/release_60 326962)
    Thread model: posix
    clang version 5.0.1 (branches/release_50 326959)
    Thread model: posix
    clang version 4.0.1 (branches/release_40 326956)
    Thread model: posix
