community.centminmod.com journey for speed
Discussion in 'Show Cases & Centmin Testimonials' started by eva2000, May 24, 2014.
Thread Status:
Not open for further replies.
    12,579
    8:53 PM
    re-ran facebook first and repeat view as it seems the first run had fully loaded delays due to ngx_pagespeed defer js calculations and optimisations not being activated yet (ngx_pagespeed still working out optimal js loading).
    now that ngx_pagespeed has optimised js and defer js filter, we can see the following breakdown
    first and repeat view compared for each from top to bottom, listed order as
    • facebook first view run 2
    • facebook repeat view run 2
    • facebook first view run 1
    • facebook repeat view run 1
    • non-facebook first view
    • non-facebook repeat view
    GTmetrix numbers
    Both are ngx_pagespeed optimised pages
    left side = non-facebook login
    right side = facebook login
    Interestingly, filmstrip shows that facebook visual loading rendered slightly more to screen 0.25 seconds ahead of non-facebook login enabled page
    12,579
    8:53 PM
    Latest gtmetrix results as at Jan 25, 2015
    12,579
    8:53 PM
    Webpagetest.org latest LA 5Mbps Cable 9 run test
    speedindex = 639ms :cool:
    12,579
    8:53 PM
    Some real time visitor gathered Page Speed load times from Google Analytics for forums. Geographic location matters when looking at Page Speed numbers. As you can see Indonesia and Philippines having a bad month for connectivity to my Linode Freemont located server for this forums and pulling up my averages heh :)
    Most important is Avg Document Interactive Time, that is as close to Webpagetest.org's Speedindex metric and initial visual render time.
    gapagespeed_oct26_2014_to_jan26_2015_00a.png gapagespeed_oct26_2014_to_jan26_2015_00b.png
    12,579
    8:53 PM
    Removed Bing Translator from sidebar and updated 10+ XF addons :)
    12,579
    8:53 PM
    :D
    12,579
    8:53 PM
    latest gtmetrix score
    12,579
    8:53 PM
    12,579
    8:53 PM
    Latest GTMetrix
    12,579
    8:53 PM
    Re-re-enabled KeyCDN account for the forums now that KeyCDN has HTTP/2 suppot :D
    Since GTmetrix Chrome 36 doesn't support HTTP/2, using webpagetest.org Dulles vs San Francisco Cable 5Mbp tests to compare. Looking good :D
    Forums hosted on 4GB Linode VPS Freemont, California so San Francisco test is naturally faster :)
    12,579
    8:53 PM
    Faster than google.com :D
    12,579
    8:53 PM
    Forums hosted on newly upgraded 8GB Linode VPS Freemont, California thanks to Linode's free double memory upgrade.
    Also new forum style in place - Forum New Style - Flat Pixel+ Default | Centmin Mod Community So re-testing pagespeed numbers :D
    webpagetest.org Dulles Cable vs Dulles 3G Fast with Chrome browser. Only concerned with Speedindex numbers as that relates to how fast the page visually renders for users. Compress image and cache static files are all 3rd party resource related due to serving Adsense banner ads etc. Note previous results in this thread didn't have Adsense footer banner ad on forum index page like I do have now.
    • Centmin Mod 123.09beta01 LEMP stack
    • Nginx 1.11.3 with HTTP/2 + ngx_pagespeed enabled
    • MariaDB 5.5.x latest
    • PHP 5.6.24 + Zend Opcache
    • CentOS 6.8
    • Enhanced Search Xenforo Addon + Elasticsearch
    • Xenforo Redis Cache Addon
    • Linode 8GB KVM VPS Fremont, CA
    12,579
    8:53 PM
    Started long term tracking of forum's webpagetest.org dulles cable 5mbps performance over 5 run averages and charting it out :)
    Forums are in Fremont, California behind Sucuri Cloudproxy for DDOS mitigation so part of performance is for Sucuri's nginx proxy.
    12,579
    8:53 PM
    Did you know you can do WebPagetest.org page speed testing with webpagetest.org scripting to test your web application's shared cache paths via navigating a few urls without logging data and only log data for the final destination to see effects of caching at browser etc levels ? ;)
    example scripting to be added to script tab
    logData 0
    setViewportSize 1920 1080
    navigate https://community.centminmod.com/
    navigate https://community.centminmod.com/forums/forum-news.2/
    logData 1
    end result is WebPagetest Test Details - Dulles : nav ind...ty.centminmod.com/ - 01/01/17 05:02:34
    12,579
    8:53 PM
    Latest webpagetest.org cable 5mbps 3x run tests in San Jose and Dulles while forums are located in Fremont, CA
    SpeedIndex is the important metric :)
    seems San Jose version loaded more Google Adsense related assets though
    12,579
    8:53 PM
    Switched off Sucuri WAF and moved to Cloudflare Pro plan and disabled Centmin Mod ngx_pagespeed too as not needed with Cloudflare Pro's feature set i.e. Polish and WebP support
    WebpageTest.org Dulles Cable page load tests to backend origin Centmin Mod Nginx located in Fremont, California with 4 tests done each with 3x WPT run average. The filmstrip compare shows in order from top to bottom the following:
    • Cloudflare Pro with Centmin Mod Nginx ngx_pagespeed disabled
    • Cloudflare Free plan with Sucuri WAF in between connecting to Centmin Mod Nginx
    • Cloudflare Free plan with Cloudflare in DNS only mode connecting to Sucuri WAF in front of Centmin Mod Nginx
    • Sucuri WAF in front of Centmin Mod Nginx
    As you can slowest was having Cloudflare > Sucuri WAF > Centmin Mod Nginx and fastest is as expected with Cloudflare Pro in front of Centmin Mod Nginx.
    Changing WPT location to California EC2 so same as origin server in Fremont, California shows similar result in that Cloudflare Pro by itself was fastest out of the 4 tested configurations.
    Finer details
    12,579
    8:53 PM
    Been a while since I updated this thread and retested mobile 3G 1.6Mbps webpagetest.org profile for
    • Galaxy S7 Chrome
    • Motorola G4 Chrome
    • Apple iPhone 8 iOS 11
    • OnePlus 5 Chrome
    • iPad 2017 iOS 11
    Tested 3x runs each with first and repeat view all are from Dulles, VA US East Coast. FYI forums are hosted in Fremont, CA Linode VPS on US West Coast so on other side of USA.
    Galaxy S7 Chrome 3G mobile 1.6Mbps
    Motorola G4 Chrome 3G mobile 1.6Mbps
    iPhone 8 3G mobile 1.6Mbps
    OnePlus 5 Chrome mobile 1.6Mbps
    iPad 2017 iOS 11 mobile 1.6Mbps
    12,579
    8:53 PM
    Forum page speed updates
    It's been a little over 2 weeks since I switched the forums over to Progressive Web App (PWA) ~July 28th, 2018 to improve page load speed and the results haven't been as dramatic as when I switched centminmod.com site over to PWA. Overall, there has been some improvements which have been overshadowed by spikes in page load times in Indonesia and India regions (and single spikes in UK and China). The most dramatic improvement if you see below charts is from Russia based visitors though :)
    Below are the top country visitor page load speed times for the forums from July 2, 2018 to August 13, 2018 with circle marker indicating July 28, 2018 switch over date.
    First 3 charts are for overall Desktop, Mobile, Desktop + Modible pagespeed
    cmm-forums-pwa-changes-130818-01b.png cmm-forums-pwa-changes-130818-01c.png cmm-forums-pwa-changes-130818-02b.png
    Though Google PageSpeed Insight origin stats show improvements WebPerf - PageSpeed - PageSpeed Testing Via APIs: Google PageSpeed Insights, GTMetrix & WebpageTest.org.
    FYI, Google PageSpeed Insight origin reports are updated daily for past month's metrics. So over time if you're working on page load speed optimisations for First Contentful Paint (FCP) and Document Content Loaded (DCL) times, they will reflect in your PSI origin reported pagespeed metric time
    12,579
    8:53 PM
    Being a pagespeed obsessed addict, I decided to optimise my forum style's Fontawesome usage by reducing the size of the forum style's default Fontawesome css and web font sizes so that I only load the web fonts that my particular forum style uses. This is opposed to loading a heap of web fonts that come in default Fontawesome bundle which are never used by the forum style.
    End result is reducing web font sizes dramatically
    i.e.
    • woff2 font dropped from 76KB to 19.5KB and the bundled uncompressed css dropped from 31KB to 12KB.
    • woff font dropped from 96KB to 42KB
    • ttf font dropped from 162KB to 42KB
    • eot font dropped from 162KB to 42KB
    • otf front increased from 132KB to 157KB ??
    • svg font dropped from 434KB to 153KB
    default
    optimised
    webpagetest.org test shows optimised fontawesome.css is 2.2KB compressed !
    Not sure if I managed replicate all forum style's Fontawesome referenced calls, so there maybe missing icons somewhere.
    12,579
    8:53 PM
    Been a while since updated this thread. Using webpagetest to test my forum's repeat visitor browser and cloudflare caching effectiveness with a multi-step webpagetest test navigating the following forum urls where some are revisited to see 1st and 2nd visit page speed metrics. This will evaluate how effective a configuration I have for browser level cache and cloudflare cache :)
    Navigation path as follows
    https://community.centminmod.com/link-forums/ways-you-can-support-centmin-mod.62/
    https://community.centminmod.com/forums/introductions.5/
    https://community.centminmod.com/threads/attention-future-centmin-mod-experts.8021/
    https://community.centminmod.com/forums/virtual-private-server-vps-hosting.26/
    https://community.centminmod.com/forums/virtual-private-server-vps-hosting.26/page-2
    https://community.centminmod.com/threads/13-way-vps-server-benchmark-comparison-tests-upcloud-vs-digitalocean-vs-linode-vs-vultr-vs-hetzner.17742/
    https://community.centminmod.com/forums/system-administration.39/
    https://community.centminmod.com/media/
    https://community.centminmod.com/media/amd-ryzen-3900x-12c-24t-centminmodbench-sh-run.52/
    https://community.centminmod.com/media/albums/cpu-frequency-charts.14/
    webpagetest dulles US East Coast 5mbps cable chrome browser
    webpagetest california US West Coast 5mbps cable chrome browser
Thread Status:
