community.centminmod.com journey for speed
Discussion in 'Show Cases & Centmin Testimonials' started by eva2000, May 24, 2014.
Thread Status:
Not open for further replies.
    50,852
    11,782
    4:41 AM
    Folks may know I have an addiction to speed = server speed, forum speed and page load speed :D So here's my journey to optimising page load speed for this forum, http://community.centminmod.com.
    Server Information
    Web stack
    • Centmin Mod .07 released LEMP web stack
    • Nginx 1.7.0 with ngx_pagespeed 1.8.31.2 beta enabled
    • PHP 5.5.12 PHP-FPM with Zend OpCache 7.0.4-dev
    • MariaDB MySQL 5.5.37 with InnoDB default
    • Memcached 1.4.20 server with Memcache 3.0.8/Memcached 2.2.0 + Libmemcached 1.18 (igbinary supported)
    • CSF Firewall
    Current List of Xenforo Addons
    • Avatar Flags by Waindigo 1.0.1
    • Defer JS 2.1.0
    • Daily Statistics 1.2.1
    • Digital Point Better Analytics 1.0.4
    • Digital Point Syntax Highlighter 1.3.0
    • Forum Jump Menu by Waindigo 1.0.10 disabled
    • Forum List Tabs by Waindigo 1.0.3 disabled
    • Install and Upgrade by Waindigo 1.1.2a
    • Mark Threads as Solved by Waindigo 1.0.2
    • Member's Local Time by Waindigo 1.0.3
    • News 1.9
    • PayPal Sandbox by Waindigo 1.0.1
    • Quick Reply Preview 1.4.3
    • Register Timezone 1.0
    • Sidebar (Collapse/expand) 1.0.0
    • Similar Threads 3.0
    • Thread Starter 1.3 disabled
    • TPU: Detect Spam Registrations 1.0.1
    • TPU: Disable Captcha for registration only 1.0.0
    • Unread Post Count 1.1.3
    • User Upgrades by Waindigo 1.3.1c
    • XenForo Resource Manager 1.1.3 disabled
    • [bd] Cache 1.0.5
    • [rellect] Nodes Grid 1.0.4
    • [Tinhte] XenTag 2.1
    50,852
    11,782
    4:41 AM
    Centmin Mod 1.2.3-eva2000.07 beta #20 install time stats
    Centmin Mod 1.2.3-eva2000.07 - http://centminmod.com
                       Centmin Mod Menu
    1).  Centmin Install
    2).  Add Nginx vhost domain
    5).  PHP Upgrade / Downgrade
    6).  XCache Re-install
    7).  APC Cache Re-install
    8).  XCache Install
    9).  APC Cache Install
    14). SELinux disable
    16). Change SSHD Port Number
    20). NSD Re-install
    22). Exit
    Enter option [ 1 - 22 ]
    Total YUM Time: 219.504090154 seconds
    Total Centmin Mod Install Time: 1109.147935431 seconds
    curl -I http://community.centminmod.com
    HTTP/1.1 200 OK
    Server: nginx centminmod
    Connection: keep-alive
    Vary: Accept-Encoding
    Set-Cookie: xf_session=xxxxx; path=/; httponly
    X-Frame-Options: SAMEORIGIN
    Date: Sat, 24 May 2014 03:09:25 GMT
    X-Page-Speed: 1.8.31.2-3973
    Cache-Control: max-age=0, no-cache
    nginx -V
    nginx version: nginx/1.7.0
    built by gcc 4.4.7 20120313 (Red Hat 4.4.7-4) (GCC)
    TLS SNI support enabled
    configure arguments: --with-cc-opt='-I/svr-setup/staticlibssl/include -I/usr/include' --with-ld-opt='-L/svr-setup/staticlibssl/lib -Wl,-rpath -lssl -lcrypto -ldl -lz' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-http_ssl_module --with-http_gzip_static_module --with-http_stub_status_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module --with-http_secure_link_module --with-http_flv_module --with-http_realip_module --with-http_geoip_module --with-openssl-opt=enable-tlsext --add-module=../ngx-fancyindex-ngx-fancyindex --add-module=../ngx_cache_purge-2.1 --add-module=../headers-more-nginx-module-0.25 --add-module=../nginx-accesskey-2.0.3 --add-module=../nginx-http-concat-master --with-openssl=../openssl-1.0.1g --with-libatomic --with-pcre=../pcre-8.35 --with-pcre-jit --with-http_spdy_module --add-module=../ngx_pagespeed-release-1.8.31.2-beta
    php -v
    PHP 5.5.12 (cli) (built: May 24 2014 03:15:01)
    Zend Engine v2.5.0, Copyright (c) 1998-2014 Zend Technologies
        with Zend OPcache v7.0.4-dev, Copyright (c) 1999-2014, by Zend Technologies
    mysqladmin ver
    mysqladmin  Ver 9.0 Distrib 5.5.37-MariaDB, for Linux on x86_64
    Copyright (c) 2000, 2014, Oracle, Monty Program Ab and others.
    Server version          5.5.37-MariaDB
    Protocol version        10
    Connection              Localhost via UNIX socket
    UNIX socket             /var/lib/mysql/mysql.sock
    Uptime:                 5 hours 17 min 49 sec
    50,852
    11,782
    4:41 AM
    50,852
    11,782
    4:41 AM
    50,852
    11,782
    4:41 AM
    50,852
    11,782
    4:41 AM
    Installed DigitalPoint Better Analytics and enabled Google Analytics tracking code both of which add more http requests (ngx_pagespeed reduces it slightly) and increase page size.
    gtmetrix result
    connection speed: unlimited
    region test server: Dallas, USA
    http://gtmetrix.com/reports/community.centminmod.com/G4R2SRbz
    webpagetest.org result
    connection speed: Cable 5Mbps
    region test server: Los Angeles different test location
    http://www.webpagetest.org/result/140525_72_e401a9292dbf3ae390060ce608b51266/
    50,852
    11,782
    4:41 AM
    Heaps of add ons and optimisations done since last benchmark.
    Latest addon listing at http://community.centminmod.com/threads/xenforo-addon-suggestions-list.17/#post-24 with following addons installed
    • Daily Statistics 1.2.2
    • Defer JS 2.1.0 [disabled]
    • Digital Point Search 1.1.1
    • Digital Point User Map 1.3.2
    • Disable Debug Mode by Waindigo 1.0.1
    • Double Post Merge 1.0.9
    • Find Unanswered Threads 1.0.5
    • First Post 1.0
    • Forum Jump Menu by Waindigo 1.0.10 [disabled]
    • Forum List Tabs by Waindigo 1.0.3 [disabled]
    • News 1.9
    • Nodes As Tabs 1.2.2
    • PayPal Sandbox by Waindigo 1.0.1 [disabled]
    • Restore Strikethrough In Editor 1.0.0 [disabled]
    • Sitemap for XenForo 1.5.2
    • Smiley Manager 2.0.1
    • Statistics 1.1 [disabled]
    • Thread Navigation by Waindigo 1.0.0a
    • Thread Starter 1.3 [disabled]
    • Who Has Visited Today 1.0.0
    • Xen Cache 1.0.1
    • XenForo Enhanced Search 1.0.3
    • XenForo Resource Manager 1.1.3 [disabled]
    • [bd] Cache 1.0.5
    • [bd] Keyword Alert 1.0.4d
    • [bd] Widget Framework 2.5.0d
    • [Nobita] XenForo Alert Plus 1.0.6
    • [rellect] Desktop Version For Mobiles 1.0.2
    • [Tinhte] XenTag 2.1.0
    • [WMTech] - Social Share Privacy 1.0.3 [disabled]
    http://www.webpagetest.org/result/140528_H8_9c263b3f0a37e8cb144d97106218908f/
    Video http://www.webpagetest.org/video/view.php?id=140528_H8_9c263b3f0a37e8cb144d97106218908f.1.0
    notice DOM elements almost doubled :)
    with Nginx 1.7.1
    50,852
    11,782
    4:41 AM
    50,852
    11,782
    4:41 AM
    50,852
    11,782
    4:41 AM
    More adds added and enabling Twitter and Google logins added to the page size with 3rd party js/images https://community.centminmod.com/threads/enabled-twitter-google-login-support.284/. Adding Fontawesome icons also added 82+ KB to page size too https://community.centminmod.com/threads/font-awesome-is-awesome.180/ as does Featured threads https://community.centminmod.com/threads/featured-threads-added.293/
    Current List of Xenforo Addons Installed
    • Add Poll to Existing Threads 1.1.4
    • Calender 3.0
    • CTA Featured Threads & Portal 2.6.1
    • CTA Login 1.0.1
    • Digital Point Ad Positioning 1.3.0
    • Digital Point Image Proxy 1.0.2
    • Digital Point Social Bar 1.0.0
    • First Post 1.0
    • Live Update 3.0
    • News 1.9
    • Quick Navigation in Menu 1.1.0
    • Remove Date Of Birth 1.1
    • Search All Forums 1.0.0
    • Slide Out Poll 1.0.0
    • Smiley Manager 2.0.1 [disabled]
    • Xen Cache 1.0.1
    • XenForo Enhanced Search 1.1.0 Beta 1
    • [bd] Attachment Store 1.1.3
    • [bd] Cache 1.0.5
    • [bd] Mails 0.9.3b
    • [FreddysHouse] Signature Once 1.2.1 [disabled] not working
    • [Iversia] FAQ Manager 3.1.0
    • [TAZ] Profile Control 1.0.0
    Google PageSpeed Insights
    Desktop http://developers.google.com/speed/pagespeed/insights/?url=https://community.centminmod.com&tab=desktop
    Mobile http://developers.google.com/speed/pagespeed/insights/?url=https://community.centminmod.com&tab=mobile
    50,852
    11,782
    4:41 AM
    Latest GTMetrix result for https://community.centminmod.com after fine tuning my ngx_pagespeed filters.
    Using Centmin Mod based Nginx 1.7.2, PHP 5.5.14, MariaDB 5.5.38 + CSF Firewall + Google SPDY SSL + ngx_pagespeed :)
    primed ngx_pagespeed gtmetrix result (meaning after a few page loads and ngx_pagespeed has optimised resources on the page) :D
    note: both twitter and google login integration also enabled
    Dallas, Cable 5Mbps test
    50,852
    11,782
    4:41 AM
    Webpagetest Cable 5Mbps, Dallas Chrome
    50,852
    11,782
    4:41 AM
    Synthetic tests are nice, but it's more accurate to look at Google Analytic's Page Speed numbers as they have a geographically relative context to them. Particularly for average page load time and more important the average DOMinteractive time (time for visitor to visually see and interact with the page that is loading).
    Numbers for my forums https://community.centminmod.com/ most recently
    50,852
    11,782
    4:41 AM
    50,852
    11,782
    4:41 AM
    Latest state of the forums
    GTmetrix
    Webpagetest
    LA location Cable
    4x runs
    50,852
    11,782
    4:41 AM
    Some Xenforo page generation times for various forum areas. I have approximately 100+ addons installled where ~30 of them are currently disabled.
    Linode SSD VPS hosted forums using Nginx with SPDY SSL with OpenSSL 1.0.2 beta3 with chacha20-poly1305 SSL cipher support enabled.
    Server Information
    Web stack
    • Nginx 1.7.4 with ngx_pagespeed 1.8.31.4 beta enabled
    • PHP 5.5.16 PHP-FPM with Zend OpCache 7.0.4-dev
    • MariaDB MySQL 5.5.39 with InnoDB default
    • CSF Firewall
    • Added: Elasticsearch 1.3.2
    Index page
    • Timing: 0.0688 seconds Memory: 8.686 MB DB Queries: 8
    • Timing: 0.0713 seconds Memory: 8.686 MB DB Queries: 8
    • Timing: 0.0689 seconds Memory: 8.685 MB DB Queries: 8
    Announcement Category page
    • Timing: 0.0354 seconds Memory: 7.136 MB DB Queries: 8
    • Timing: 0.0324 seconds Memory: 7.136 MB DB Queries: 8
    • Timing: 0.0336 seconds Memory: 7.136 MB DB Queries: 8
    Forum News Forum page
    • Timing: 0.0566 seconds Memory: 8.818 MB DB Queries: 9
    • Timing: 0.0614 seconds Memory: 8.818 MB DB Queries: 9
    • Timing: 0.0593 seconds Memory: 8.818 MB DB Queries: 9
    Thread page 22 posts Greetings from a Debian user | Centmin Mod Community
    • Timing: 0.1478 seconds Memory: 10.142 MB DB Queries: 15
    • Timing: 0.1474 seconds Memory: 10.142 MB DB Queries: 15
    • Timing: 0.1409 seconds Memory: 10.142 MB DB Queries: 15
    Member profile page https://community.centminmod.com/members/eva2000.1/
    • Timing: 0.0547 seconds Memory: 8.269 MB DB Queries: 15
    • Timing: 0.0538 seconds Memory: 8.268 MB DB Queries: 15
    • Timing: 0.0534 seconds Memory: 8.269 MB DB Queries: 15
    50,852
    11,782
    4:41 AM
    Latest stats with updated Nginx and PHP-FPM versions as well as a few updated addons
    Server Information
    Web stack
    • Nginx 1.7.5 with ngx_pagespeed 1.9.32.1 beta enabled
    • PHP 5.6.0 PHP-FPM with Zend OpCache 7.0.4-dev
    • CSF Firewall
    Index page
    • Timing: 0.0702 seconds Memory: 8.500 MB DB Queries: 8
    • Timing: 0.0691 seconds Memory: 8.500 MB DB Queries: 8
    • Timing: 0.0677 seconds Memory: 8.500 MB DB Queries: 8
    • Timing: 0.0304 seconds Memory: 6.954 MB DB Queries: 8
    • Timing: 0.0334 seconds Memory: 6.954 MB DB Queries: 8
    • Timing: 0.0296 seconds Memory: 6.954 MB DB Queries: 8
    • Timing: 0.0604 seconds Memory: 8.572 MB DB Queries: 9
    • Timing: 0.0580 seconds Memory: 8.573 MB DB Queries: 9
    • Timing: 0.0607 seconds Memory: 8.573 MB DB Queries: 9
    • Timing: 0.1407 seconds Memory: 9.858 MB DB Queries: 11
    • Timing: 0.1405 seconds Memory: 9.858 MB DB Queries: 11
    • Timing: 0.1381 seconds Memory: 9.859 MB DB Queries: 11
    • Timing: 0.0516 seconds Memory: 8.044 MB DB Queries: 15
    • Timing: 0.0492 seconds Memory: 8.043 MB DB Queries: 15
    • Timing: 0.0490 seconds Memory: 8.043 MB DB Queries: 15
    50,852
    11,782
    4:41 AM
    Latest updates
    Webpagetest
    50,852
    11,782
    4:41 AM
    Enabled Share This Page social media features for Twitter, Facebook and Google+ so retesting forums for gtmetrix and webpagetest pagespeed numbers :)
    webpagetest compare across several regions including Dulles, New York, San Jose, Chicago, Denver and Montreal (tested twice)
    SpeedIndex is what you need to look at for best performance in terms of initial perceived page loading as you can see from filmstrip, San Jose is fastest give this forum's server is located in Freemont, California :)
    50,852
    11,782
    4:41 AM
    Just enabled Facebook login integration, so check to see how that affects page speed.
    • Looks like increase in javascript js requests as expected and seems that fully loaded page time increased dramatically - being twice as slow. If you look closely, you can see for Facebook first view, the Facebook login button on right sidebar doesn't begin to show until around 1.6 seconds into the 2nd listed screenshot
    • While initial visual render time slightly improved for first paint (probably just normal variation between runs). However, for seeing the more of the forum page rendered, Facebook first view was slower at 1.2s vs 1.1s for non-facebook page.
    • Repeat view on the other hand was faster for Facebook repeat view run.
    First and repeat view compared for each - listed order from top to bottom is
    • facebook first view
    • non-facebook first view
    • facebook repeat view
    • non-facebook repeat view
    webpagetest_compare_121114_00.png webpagetest_compare_121114_01.png webpagetest_compare_121114_02.png
Thread Status:
