Command not running on script
Discussion in 'System Administration' started by pamamolf, Jul 8, 2014.
    4,101
    428
    9:34 PM
    Nginx-1.26.x
    Hi
    I am testing a script.sh and i can't get this work:
    #!/bin/bash
    # Compress them
    /bin/tar -zcf /home/backup/file.txt
    file /home/backup/file.txt exist and the cron is running as i can check using tailf /var/log/cron
    Why is not running?
    I was try also as
    55,400
    12,255
    4:34 AM
  3. pamamolf
    4,101
    428
    9:34 PM
    Nginx-1.26.x
    ok found it thanks :)
