cmupdate problem
Discussion in 'Install & Upgrades or Pre-Install Questions' started by Meirami, Oct 7, 2018.
  1. Meirami
    Meirami Member
    128
    15
    9:05 AM
    • Nginx Version Installed: i.e. 1.15.5
    • PHP Version Installed: 7.2.10
    • MariaDB MySQL Version Installed: 10.1.36
    • When was last time updated Centmin Mod code base ? : fresh install few days ago
      PHPFINFO='y'
      LETSENCRYPT_DETECT=y
    I tryed cmupdate, and got this.
    # cmupdate
    *** Please tell me who you are.
    Run
      git config --global user.email "[email protected]"
      git config --global user.name "Your Name"
    to set your account's default identity.
    Omit --global to set the identity only in this repository.
    fatal: unable to auto-detect email address (got '[email protected](none)')
    Cannot save the current index state
    Updating 8046d1e..27dcf78
    error: Your local changes to the following files would be overwritten by merge:
    centmin.sh
    Please, commit your changes or stash them before you can merge.
    Aborting
    The autodetection fails. On the others vps' I think I have used [email protected] with autodetection succesfully. How to fix this?
    40,322
    8,930
    4:05 PM
    rm /etc/centminmod/email-primary.ini file and then re-run centmin.sh when prompted for email addresses, set a valid working email of yours for primary and secondary email prompts. Then should fix it
  3. Meirami
    Meirami Member
    128
    15
    9:05 AM
    No such a file.
    I run centmin.sh and set email. Now update worked.
    Thanks!
