Cminfo tool info
Discussion in 'Add Ons' started by pamamolf, Mar 29, 2015.
    4,003
    420
    6:00 AM
    Nginx-1.17.x
    Hi
    I need some info about this tool cminfo but i can't find any related topic for it :(
    I am looking most for why a cron is needed and not update it manually?
    49,879
    11,487
    1:00 PM
    cminfo is new tool which can undergo changes in code frequently so cronjob auto updates the script other end users won't update it as frequently
  3. pamamolf
    4,003
    420
    6:00 AM
    Nginx-1.17.x
    Is there a way to disable this and avoid cron job before installation?
    49,879
    11,487
    1:00 PM
    not right now if you using .08 beta you're meant to be helping me test and provide feedback for such features ;) Would defeat the purpose of beta testing .08 beta02 :D
