Cloudflare Cloudflare not caching images & Polish not working
Discussion in 'Web Development & Web Performance' started by Rake-GH, May 26, 2021.
  1. Rake-GH
    Rake-GH Active Member
    179
    93
    USA
    12:34 PM
    default
    default
    I had some questions regarding images not being cached by CF and some Polish confusion, and I figured this is the best place to ask.
    I was just poking around in Cloudflare and noticed this:
    I thought it was weird that these are being served by the origin, even weirder that the content type is empty.
    Then I realized, 99% of my images on the site are all attachments. None of the attachments are being served as webp despite using Polish? Yikes, how did I never realize this before.
    I found this: Getting proxy images to work well with CloudFlare compression (Polish) and this Getting proxy images to work well with CloudFlare compression (Polish)
    There doesn't seem to be any simple way to solve this problem.
    Any thoughts or advice? Thank you in advance
  2. Rake-GH
    179
    93
    USA
    12:34 PM
    default
    default
    I was just thinking, I can probably cache the image attachments on the CDN at least by making a page rule, something like:
    if uri.contains(/attachments/*-png.*) then cacheLevel = standard
    does that sound like a decent idea?
  3. rdan
    1,389
    1:34 AM
    That's the right thing to do, Yes.
  4. rdan
    1,389
    1:34 AM
    Mine
    50,928
    11,808
    3:34 AM
    Yup @rdan approach would be the easiest via a custom Cloudflare page rule :)
  6. Rake-GH
    179
    93
    USA
    12:34 PM
    default
    default
    I just wanted to note that this firewall rule makes paid account upgrades fail on my website:
    So if you ever run into trouble with registrations, try disabling this rule.
    Sounds crazy, but it's true, hope it helps someone so they don't have to debug as long as I did to find the problem
    50,928
    11,808
    3:34 AM
    CF Firewall rule or Page rule? That looks like CF Page rule to me.
  8. Rake-GH
    179
    93
    USA
    12:34 PM
    default
    default
    Page rule, that was a typo
    50,928
    11,808
    3:34 AM
    I see, still don't see how css.php caching prevented user upgrades though. What errors did you get with that Page rule in place?
