Letsencrypt Cloudflare cloudflare http to https redirecting issue
Discussion in 'Domains, DNS, Email & SSL Certificates' started by emre22, Jan 22, 2017.
  1. emre22
    emre22 Member
    44
    5
    12:28 PM
    nginx-1.10.1
    MariaDB 10
    Hello,
    I am using cloudflare as dns, ssl = off, all kind of records are set up and working fine with non-ssl
    http://fs5.directupload.net/images/170122/4wnmqzpx.jpg
    I wanted to switch over to ssl, because I received a mail from google regarding this.
    I followed exactly this tutorial, I am using cmm beta, but when I try to reach my site with https://....net I am directly redirected to the non ssl site.
    54,909
    12,240
    9:28 PM
    Also what is output of these commands in ssh
    curl -I https://domain.com
    curl -I http://domain.com
    curl -I http://www.domain.com
    wrap output in CODE tags
  3. emre22
    emre22 Member
    44
    5
    12:28 PM
    nginx-1.10.1
    MariaDB 10
    Hey Eva,
    I did not create the domain new, I wanted to switch for an existing non-ssl domain to letsencrypt
    54,909
    12,240
    9:28 PM
    still need the existing domain's vhost contents to double check
  5. emre22
    emre22 Member
    44
    5
    12:28 PM
    nginx-1.10.1
    MariaDB 10
    [root@cmm-beta ~]# curl -I https://domain.net/
    Date: Sun, 22 Jan 2017 13:31:15 GMT
    Connection: keep-alive
    Set-Cookie: __cfduid=d17d0fa31f2ff18a408aaf13439b684991485091875; expires=Mon, 22-Jan-18 13:31:15 GMT; path=/; domain=.domain.net; HttpOnly
    Server: cloudflare-nginx
    CF-RAY: 32535d7bda672bee-AMS
    [root@cmm-beta ~]# curl -I https://www.domain.net/
    Date: Sun, 22 Jan 2017 13:34:13 GMT
    Set-Cookie: __cfduid=d831c5434e9a71252aa4357c42b51aeac1485092053; expires=Mon, 22-Jan-18 13:34:13 GMT; path=/; domain=.domain.net; HttpOnly
    CF-RAY: 325361d6590c2bd0-AMS
    [root@cmm-beta ~]# curl -I http://domain.net/
    HTTP/1.1 200 OK
    Date: Sun, 22 Jan 2017 13:32:36 GMT
    Set-Cookie: __cfduid=d04097d0d5202ca370476c84aab4ec5e31485091956; expires=Mon, 22-Jan-18 13:32:36 GMT; path=/; domain=.domain.net; HttpOnly
    Vary: Accept-Encoding
    X-Powered-By: centminmod
    X-Page-Speed: 1.12.34.2-0
    Cache-Control: max-age=0, no-cache
    CF-RAY: 32535f7707862ba6-AMS
    [root@cmm-beta ~]# curl -I http://www.domain.net/
    Date: Sun, 22 Jan 2017 13:33:10 GMT
    Set-Cookie: __cfduid=d605e78cd1847a9de2313ce889c3f1d0f1485091990; expires=Mon, 22-Jan-18 13:33:10 GMT; path=/; domain=.domain.net; HttpOnly
    CF-RAY: 3253604aa40c2c42-AMS
  6. emre22
    emre22 Member
    44
    5
    12:28 PM
    nginx-1.10.1
    MariaDB 10
    #server {
    #            listen   80;
    #            server_name existing-domain-conf.net www.existing-domain-conf.net;
    #            return 301 $scheme://www.existing-domain-conf.net$request_uri;
    include /usr/local/nginx/conf/pagespeedstatslog.conf;
      # ssi  on;
      access_log /home/nginx/domains/existing-domain-conf.net/log/access.log main_ext buffer=256k flush=60m;
      error_log /home/nginx/domains/existing-domain-conf.net/log/error.log;
      include /usr/local/nginx/conf/autoprotect/existing-domain-conf.net/autoprotect-existing-domain-conf.net.conf;
      root /home/nginx/domains/existing-domain-conf.net/public;
      # server and/or vhost site
      # include /usr/local/nginx/conf/cloudflare.conf;
      include /usr/local/nginx/conf/wpincludes/existing-domain-conf.net/wpcacheenabler_existing-domain-conf.net.conf;
      #include /usr/local/nginx/conf/wpincludes/existing-domain-conf.net/wpsupercache_existing-domain-conf.net.conf;
      #include /usr/local/nginx/conf/wpincludes/existing-domain-conf.net/rediscache_existing-domain-conf.net.conf;
      #autoindex  on;
      # for wp cache enabler plugin
      try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
      # Wordpress Permalinks
      # Nginx level redis Wordpress
        #limit_conn xwpconlimit 30;
    location ~* /(xmlrpc\.php) {
      include /usr/local/nginx/conf/wpincludes/existing-domain-conf.net/wpsecure_existing-domain-conf.net.conf;
    # For HTTP/2 SSL Setup
    # server {
    #   server_name existing-domain-conf-ssl.net www.existing-domain-conf-ssl.net;
    #    return 302 https://existing-domain-conf-ssl.net$request_uri;
      listen 443 ssl http2;
      include /usr/local/nginx/conf/ssl/existing-domain-conf-ssl.net/existing-domain-conf-ssl.net.crt.key.conf;
      http2_max_field_size 16k;
      http2_max_header_size 32k;
      # dual cert supported ssl ciphers
      ssl_ciphers     EECDH+CHACHA20-draft:EECDH+CHACHA20:EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EECDH+ECDSA+SHA256:EECDH+ECDSA+SHA384:EECDH+aRSA+SHA256:EECDH+aRSA+SHA384:EECDH+AES128:!aNULL:!eNULL:!LOW:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS:!RC4:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA:!CAMELLIA;
      #spdy_headers_comp 5;
      ssl_buffer_size 1369;
      ssl_session_tickets on;
      # enable ocsp stapling
       resolver_timeout 10s;
       ssl_stapling on;
       ssl_stapling_verify on;
      # ssi  on;
      access_log /home/nginx/domains/existing-domain-conf-ssl.net/log/access.log combined buffer=256k flush=60m;
      error_log /home/nginx/domains/existing-domain-conf-ssl.net/log/error.log;
      root /home/nginx/domains/existing-domain-conf-ssl.net/public;
        include /usr/local/nginx/conf/wpincludes/existing-domain-conf-ssl.net/wpcacheenabler_existing-domain-conf-ssl.net.conf;
        try_files $uri $uri/ /wordpress/index.php?q=$request_uri;
        #try_files $cache_enabler_uri $uri $uri/ $custom_subdir/index.php?$args;
    54,909
    12,240
    9:28 PM
    indeed for https version there's a 301 permanent redirect if you look at Location it's going to non-https version !
    nothing in both your vhosts suggest a 301 redirect from what i can see, so cloudflare might be doing it ? maybe when you set https = off in cloudflare ?
    seems cloudflare ssl off will 301 redirect to http version !
    so only way is either disable cloudflare cache and use as dns only = Cloudflare DNS Only Configuration
    or use cloudflare's ssl in front and set ssl to Full SSL or FULL SSL (strict) so cloudflare talks to your site's https letsencrypt ssl site
  8. emre22
    emre22 Member
    44
    5
    12:28 PM
    nginx-1.10.1
    MariaDB 10
    well cloudflare ssl was off all the time, I switched it now to full strict ssl and my website looks strange somehow. I sent you the url
    54,909
    12,240
    9:28 PM
  10. emre22
    emre22 Member
    44
    5
    12:28 PM
    nginx-1.10.1
    MariaDB 10
    Okay, putting a pagerule under cloudflare & Automatic HTTPS Rewrites option fixed it all. Thank you so much eva :)
    54,909
    12,240
    9:28 PM
    excellent :D
