CDN Cloudflare Cloudflare Flexible SSL, Nginx & XenForo
Discussion in 'Domains, DNS, Email & SSL Certificates' started by BamaStangGuy, Oct 1, 2014.
  1. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    8:08 AM
    I am getting a redirect loop as well.
        server_name yabucket.com www.yabucket.com;
    return 301 https://www.yabucket.com$request_uri;
    listen 443 ssl spdy;
      server_name www.yabucket.com;
  2. BamaStangGuy
    669
    192
    8:08 AM
    Can someone post their domains .conf file for nginx using the Flexible SSL where you are forcing SSL?
    12,579
    11:08 PM
    hmm wonder if Cloudflare tech support were correct then from SSL - Cloudflare Flexible SSL, Nginx & XenForo | Centmin Mod Community You'd want to contact Cloudflare tech support and ask specifically what is Nginx equivalent for How do I redirect HTTPS traffic with Flexible SSL and Apache? – CloudFlare Support
    My test Cloudflare flexible SSL is still in SSL expired state and the other domain I did not request flexible SSL is activated but it's on a Apache + WHM/Cpanel server with working https redirect
  4. BamaStangGuy
    669
    192
    8:08 AM
    I opened a ticket with them and will report back here
    12,579
    11:08 PM
    yeah i opened a follow up ticket with Cloudflare pointing to this thread too
    here's the exact reply I had previously.. just in case I read it incorrectly
    note, page rules method they mention is only available to paid pro and higher plan users not free plan Cloudflare users.
    so maybe try
    return 301 $scheme://www.yabucket.com$request_uri;
    but that would allow both http and https not redirect to https
  6. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    7:08 PM
    1.7.6
    5.10
    I have tried a few configuration with Cloudflare's flexible SSL but none seems working fine for me :(. I am testing flexible SSL (not forced) on Test Page for the Centmin Mod Nginx HTTP Server
    Config #1: current-config - Pastebin.com
    CSS and JS doesn't load when trying Reflection design studio | ... we bring ideas to life
    but, without https it works fine.
    Config #2: centmin-default-page - Pastebin.com
    This config takes to centminmod's default page instead of actual website.
    Config #3: redirect-loop - Pastebin.com
    This config gives redirect loop error.
    12,579
    11:08 PM
    thanks for sharing @Razib Hasan
    here's hoping Cloudflare support comes back to us with a working setup.
  8. BamaStangGuy
    669
    192
    8:08 AM
    This is the reply I got back
  9. rdan
    9:08 PM
    CloudFlare’s Flexible SSL Without Infinite Redirect Loops
    Within CloudFlare go to the Page Rules section for your domain and enter a rule just as shown in the screenshot below:
    The rule should be: *your-domain.com*
    Always Use HTTPS – On
    And that is it.
    Once this is saved, after a few minutes, CloudFlare will start forcing all traffic over SSL.
    12,579
    11:08 PM
    haha that easy.. shame my domain is in 10+ days and still not activated :LOL::rolleyes:
  11. rdan
    9:08 PM
    Try to cancel it, then enable back flexible ssl or full ssl.
    All my domains are enabled already.
  12. BamaStangGuy
    669
    192
    8:08 AM
    Even with that redirect @RoldanLT SSL is not working correctly. Even with changing the URL to https in Board settings, it still tries to load all css and javascript over http.
  13. rdan
    9:08 PM
    Purge cache on cloudflare settings?
  14. BamaStangGuy
    669
    192
    8:08 AM
    12,579
    11:08 PM
    I gave up for now, still nearly 13 days and my SSL is still expired status. Cloudflare support says they have engineers investigating and will get back to me eventually heh.
  16. Razib Hasan
    Razib Hasan Member
    37
    15
    Dhaka, Bangladesh
    7:08 PM
    1.7.6
    5.10
    I had similar problem with a domain. I checked yesterday and saw the SSL is active now :)
    12,579
    11:08 PM
    well just checked, went out of SSL Expired back to SSL authorizing so guess that's progress :D
  18. rdan
    9:08 PM
    @BamaStangGuy Are you using Pro plan now?
    How many hours or days for the Full SSL become active?
    Mine is more than 24 hours now still not yet active.
  19. BamaStangGuy
    669
    192
    8:08 AM
    Pro. Took mine about an hour.
  20. rdan
    9:08 PM
    What :(
    Mine already 30 hours now.
