Upgrade city-fan repo issue
Discussion in 'Bug Reports' started by pamamolf, Dec 14, 2022.
    4,022
    421
    7:18 PM
    Nginx-1.17.x
    Hello,
    On latest beta code when exiting using the option 24 i can see these errors:
    http://www.city-fan.org/ftp/contrib/yum-repo/rhel7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://www.city-fan.org/ftp/contrib/yum-repo/rhel7/x86_64/repodata/repomd.xml: (28, "Failed to connect to www.city-fan.org port 80 after 15031 ms: Couldn't connect to server")
    Trying other mirror.
    http://nervion.us.es/city-fan/yum-repo/rhel7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://nervion.us.es/city-fan/yum-repo/rhel7/x86_64/repodata/repomd.xml: (28, "Failed to connect to nervion.us.es port 80 after 15037 ms: Couldn't connect to server")
    http://www.city-fan.org/ftp/contrib/yum-repo/rhel7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://www.city-fan.org/ftp/contrib/yum-repo/rhel7/x86_64/repodata/repomd.xml: (28, "Failed to connect to www.city-fan.org port 80 after 15039 ms: Couldn't connect to server")
    http://www.city-fan.org/ftp/contrib/yum-repo/rhel7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://www.city-fan.org/ftp/contrib/yum-repo/rhel7/x86_64/repodata/repomd.xml: (28, "Failed to connect to www.city-fan.org port 80 after 15037 ms: Couldn't connect to server")
    http://nervion.us.es/city-fan/yum-repo/rhel7/x86_64/repodata/repomd.xml: [Errno 12] Timeout on http://nervion.us.es/city-fan/yum-repo/rhel7/x86_64/repodata/repomd.xml: (28, "Failed to connect to nervion.us.es port 80 after 15038 ms: Couldn't connect to server")
    Don't know if a fix is needed...
    50,450
    11,658
    2:18 AM
    what happens if you run these 2 commands
    yum clean all
    yum repolist all
  3. pamamolf
    4,022
    421
    7:18 PM
    Nginx-1.17.x
    It seems that after updating the system and re executing the menu and exit was fixed...
    I didn't see that issue again..
