CInfo Issues
Discussion in 'Add Ons' started by Matt Williams, Mar 10, 2015.
  1. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    When I install the cinfo ( add-on ) I get this
    This needs access to /proc and /sys to work.
    How can I fix this?
    55,926
    6:22 PM
  3. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    Centmin mod 08 beta - openVZ CentOS 6.6 | That is the full error message when I access IP/cinfo - It's installs fine - Brand new install
    I've installed it on every VPS I've put up and never has been an issue except for these last 2
    55,926
    6:22 PM
    55,926
    6:22 PM
  6. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    I just installed one about an hour ago and one yesterday and one the day before
    55,926
    6:22 PM
    yup confirmed it's open_basedir related as PHP doesn't have permissions to access /proc and /sys due to tighter security via open_basedir
    I suppose, you can just allow default nginx vhost at /usr/local/nginx/conf/conf.d/virtual.conf to have a separate php.conf include file without open_basedir
    create a new php.conf includes at /usr/local/nginx/conf/phpallowed.conf
    cp -a /usr/local/nginx/conf/php.conf /usr/local/nginx/conf/phpallowed.conf
    edit /usr/local/nginx/conf/phpallowed.conf and comment out
    #fastcgi_param PHP_ADMIN_VALUE open_basedir=$document_root/:/usr/local/lib/php/:/tmp/;
    then change the default nginx vhost's /usr/local/nginx/conf/conf.d/virtual.conf include
    from
    to
    include /usr/local/nginx/conf/phpallowed.conf;
    restart nginx and php-fpm via command shortcut
    nprestart
    edit: might have to make that the default on .08 if i stick with enabling open_basedir
    55,926
    6:22 PM
    ah easier way include new phpallowed.conf in cinfo include itself at /usr/local/nginx/conf/cinfo.conf
                location /cinfo/ {
            auth_basic "Private";
            auth_basic_user_file /usr/local/nginx/conf/cinfo_htpasswd;
    probably best approach as i can just edit addons/linfo.sh :)
    55,926
    6:22 PM
  10. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    Worked like a charm! Thanks George!
    55,926
    6:22 PM
    no probs.
    thanks for the heads up.. also good to update the linfo version to 2.0.2 too (was hoping for a more spiffy modern default theme for linfo though heh)
  12. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    Does this need a vHost to work properly? I setup a remote DB server only, using 08 beta / openVZ Container but have not setup a vHost for a website because it wont have one.
    The cInfo addon still gives me the "This needs access to /proc and /sys to work". - this is a fresh install ( 08 beta ) just using MariaDB/phpmyadmin as a remote DB server.
    I ran the new CInfo addon script Centmin Mod Addons for Menu based Nginx installer for CentOS servers Checked the /usr/local/nginx/conf/cinfo.conf and it shows the changes/updates you made, then checked /usr/local/nginx/conf/phpallowed.conf and the
    is commented out...
    Strange....
    55,926
    6:22 PM
    what about a simple nprestart to restart both nginx and php-fpm ?
  14. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    Still the same - This needs access to /proc and /sys to work.
    55,926
    6:22 PM
    and if you comment it out from /usr/local/nginx/conf/php.conf again ?
  16. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    Works just fine now that I commended out the #fastcgi_param PHP_ADMIN_VALUE open_basedir=$document_root/:/usr/local/lib/php/:/tmp/;
    55,926
    6:22 PM
    ok weird then, guess more testing :)
  18. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    Your the best George!
  19. Matt Williams
    537
    104
    Virginia, USA
    4:22 AM
    latest
    I thought I should let you know that It worked fine on a new 08 beta install on KVM - VULTR
