Nginx Chasing location directive issues
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by enderst, Jan 8, 2019.
  1. enderst
    enderst New Member
    25
    5
    3:38 AM
    Migrated two sites, first one went fine the second I'm getting the following error:
    #nginx -t
    nginx: [emerg] "location" directive is not allowed here in /usr/local/nginx/conf/autoprotect/domain.com/autoprotect-domain.conf:3
    If clear the file:
    then I get:
    # nginx -t
    nginx: [emerg] "location" directive is not allowed here in /usr/local/nginx/conf/503include-main.conf:5
    Not sure if I'm going down a rabbit hole if I continue to clear the files.
    37,710
    8,254
    8:38 PM
    Most likely missing or extra ending or starting curly braces {} in your main nginx vhost throwing stuff out of wack.
    Where newdomain.com is your problem domain name.
  3. enderst
    enderst New Member
    25
    5
    3:38 AM
    Once again you saved some hair pulling.
    I had an extra brace where I pasted a redirect.
    Thanks.
