Featured Install Changing default CentOS system timezones
Discussion in 'Install & Upgrades or Pre-Install Questions' started by eva2000, Jun 8, 2014.
    55,896
    12,281
    4:23 PM
    In centmin.sh there's a variable called ZONEINFO which can be changed prior to Centmin Mod install to set the default CentOS system timezone. This system timezone can also be changed after install as per FAQ 8 http://centminmod.com/faq.html.
    Full example of post-install timezone changes are outlined at http://centminmod.com/datetimezones.html.
    For example for Greece, Athens you can use ZONEINFO=Europe/Athens
    ls -lah /usr/share/zoneinfo/Europe/
    total 244K
    drwxr-xr-x.  2 root root 4.0K Jun  2 06:33 .
    drwxr-xr-x. 20 root root 4.0K Jun  2 06:33 ..
    -rw-r--r--.  1 root root 2.9K May 15 05:05 Amsterdam
    -rw-r--r--.  1 root root 1.7K May 15 05:05 Andorra
    -rw-r--r--.  1 root root 2.2K May 15 05:05 Athens
    -rw-r--r--.  7 root root 3.6K May 15 05:05 Belfast
    -rw-r--r--.  6 root root 1.9K May 15 05:05 Belgrade
    -rw-r--r--.  1 root root 2.3K May 15 05:05 Berlin
    -rw-r--r--.  2 root root 2.2K May 15 05:05 Bratislava
    -rw-r--r--.  1 root root 2.9K May 15 05:05 Brussels
    -rw-r--r--.  1 root root 2.2K May 15 05:05 Bucharest
    -rw-r--r--.  1 root root 2.4K May 15 05:05 Budapest
    -rw-r--r--.  3 root root 1.9K May 15 05:05 Busingen
    -rw-r--r--.  2 root root 2.4K May 15 05:05 Chisinau
    -rw-r--r--.  1 root root 2.1K May 15 05:05 Copenhagen
    -rw-r--r--.  2 root root 3.5K May 15 05:05 Dublin
    -rw-r--r--.  1 root root 3.0K May 15 05:05 Gibraltar
    -rw-r--r--.  7 root root 3.6K May 15 05:05 Guernsey
    -rw-r--r--.  2 root root 1.9K May 15 05:05 Helsinki
    -rw-r--r--.  7 root root 3.6K May 15 05:05 Isle_of_Man
    -rw-r--r--.  3 root root 2.7K May 15 05:05 Istanbul
    -rw-r--r--.  7 root root 3.6K May 15 05:05 Jersey
    -rw-r--r--.  1 root root 1.5K May 15 05:05 Kaliningrad
    -rw-r--r--.  1 root root 2.1K May 15 05:05 Kiev
    -rw-r--r--.  2 root root 3.4K May 15 05:05 Lisbon
    -rw-r--r--.  6 root root 1.9K May 15 05:05 Ljubljana
    -rw-r--r--.  7 root root 3.6K May 15 05:05 London
    -rw-r--r--.  1 root root 2.9K May 15 05:05 Luxembourg
    -rw-r--r--.  1 root root 2.6K May 15 05:05 Madrid
    -rw-r--r--.  1 root root 2.6K May 15 05:05 Malta
    -rw-r--r--.  2 root root 1.9K May 15 05:05 Mariehamn
    -rw-r--r--.  1 root root 1.3K May 15 05:05 Minsk
    -rw-r--r--.  1 root root 2.9K May 15 05:05 Monaco
    -rw-r--r--.  2 root root 1.5K May 15 05:05 Moscow
    -rw-r--r--.  2 root root 2.0K May 15 05:05 Nicosia
    -rw-r--r--.  3 root root 2.2K May 15 05:05 Oslo
    -rw-r--r--.  1 root root 2.9K May 15 05:05 Paris
    -rw-r--r--.  6 root root 1.9K May 15 05:05 Podgorica
    -rw-r--r--.  2 root root 2.2K May 15 05:05 Prague
    -rw-r--r--.  1 root root 2.2K May 15 05:05 Riga
    -rw-r--r--.  3 root root 2.6K May 15 05:05 Rome
    -rw-r--r--.  1 root root 1.3K May 15 05:05 Samara
    -rw-r--r--.  3 root root 2.6K May 15 05:05 San_Marino
    -rw-r--r--.  6 root root 1.9K May 15 05:05 Sarajevo
    -rw-r--r--.  1 root root 1.5K May 15 05:05 Simferopol
    -rw-r--r--.  6 root root 1.9K May 15 05:05 Skopje
    -rw-r--r--.  1 root root 2.1K May 15 05:05 Sofia
    -rw-r--r--.  1 root root 1.9K May 15 05:05 Stockholm
    -rw-r--r--.  1 root root 2.2K May 15 05:05 Tallinn
    -rw-r--r--.  1 root root 2.1K May 15 05:05 Tirane
    -rw-r--r--.  2 root root 2.4K May 15 05:05 Tiraspol
    -rw-r--r--.  1 root root 2.1K May 15 05:05 Uzhgorod
    -rw-r--r--.  3 root root 1.9K May 15 05:05 Vaduz
    -rw-r--r--.  3 root root 2.6K May 15 05:05 Vatican
    -rw-r--r--.  1 root root 2.2K May 15 05:05 Vienna
    -rw-r--r--.  1 root root 2.2K May 15 05:05 Vilnius
    -rw-r--r--.  1 root root 1.2K May 15 05:05 Volgograd
    -rw-r--r--.  2 root root 2.7K May 15 05:05 Warsaw
    -rw-r--r--.  6 root root 1.9K May 15 05:05 Zagreb
    -rw-r--r--.  1 root root 2.1K May 15 05:05 Zaporozhye
    -rw-r--r--.  3 root root 1.9K May 15 05:05 Zurich
    You'd want to change your /usr/local/lib/php.ini defined timezone too date.timezone according to predefined ones at http://www.php.net//manual/en/timezones.php
  2. rdan
    1,412
    2:23 PM
    It didn't apply automatically for me with Asia/Manila on php.ini on my 1st install.
    55,896
    12,281
    4:23 PM
    it should set to UTC with inc/phpsededit.inc line 2 to 6 at https://github.com/centminmod/centminmod/blob/123.07beta21/inc/phpsededit.inc#L2
        if [[ "$(date +"%Z")" = 'EST' ]]; then
        sed -i "s/;date.timezone =/date.timezone = Australia\/Brisbane/g" /usr/local/lib/php.ini
        else
        sed -i "s/;date.timezone =/date.timezone = UTC/g" /usr/local/lib/php.ini
        fi
    what does the command below return
    echo $(date +"%Z")
  4. rdan
    1,412
    2:23 PM
    It's "PHT" because I manually edited the php.ini file.
  5. rdan
    1,412
    2:23 PM
    For Philippines I should use UTC or EST?
    55,896
    12,281
    4:23 PM
    For system timezone or PHP ?
    For system pick closest city on Asia directory listing, i.e. Asia/Manila
    ls /usr/share/zoneinfo/Asia/
    Aden      Ashkhabad  Brunei      Damascus  Hebron       Jayapura   Katmandu      Macao     Novokuznetsk  Qatar      Seoul      Tel_Aviv       Urumqi
    Almaty    Baghdad    Calcutta    Dhaka     Ho_Chi_Minh  Jerusalem  Khandyga      Macau     Novosibirsk   Qyzylorda  Shanghai   Thimbu         Ust-Nera
    Amman     Bahrain    Choibalsan  Dili      Hong_Kong    Kabul      Kolkata       Magadan   Omsk          Rangoon    Singapore  Thimphu        Vientiane
    Anadyr    Baku       Chongqing   Dubai     Hovd         Kamchatka  Krasnoyarsk   Makassar  Oral          Riyadh     Taipei     Tokyo          Vladivostok
    Aqtau     Bangkok    Chungking   Dushanbe  Irkutsk      Karachi    Kuala_Lumpur  Manila    Phnom_Penh    Saigon     Tashkent   Ujung_Pandang  Yakutsk
    Aqtobe    Beirut     Colombo     Gaza      Istanbul     Kashgar    Kuching       Muscat    Pontianak     Sakhalin   Tbilisi    Ulaanbaatar    Yekaterinburg
    Ashgabat  Bishkek    Dacca       Harbin    Jakarta      Kathmandu  Kuwait        Nicosia   Pyongyang     Samarkand  Tehran     Ulan_Bator     Yerevan
    For PHP closest on Asia listing http://www.php.net/manual/en/timezones.php at http://www.php.net/manual/en/timezones.asia.php
    Asia/Aden    Asia/Almaty    Asia/Amman    Asia/Anadyr    Asia/Aqtau
    Asia/Aqtobe    Asia/Ashgabat    Asia/Ashkhabad    Asia/Baghdad    Asia/Bahrain
    Asia/Baku    Asia/Bangkok    Asia/Beirut    Asia/Bishkek    Asia/Brunei
    Asia/Calcutta    Asia/Choibalsan    Asia/Chongqing    Asia/Chungking    Asia/Colombo
    Asia/Dacca    Asia/Damascus    Asia/Dhaka    Asia/Dili    Asia/Dubai
    Asia/Dushanbe    Asia/Gaza    Asia/Harbin    Asia/Hebron    Asia/Ho_Chi_Minh
    Asia/Hong_Kong    Asia/Hovd    Asia/Irkutsk    Asia/Istanbul    Asia/Jakarta
    Asia/Jayapura    Asia/Jerusalem    Asia/Kabul    Asia/Kamchatka    Asia/Karachi
    Asia/Kashgar    Asia/Kathmandu    Asia/Katmandu    Asia/Khandyga    Asia/Kolkata
    Asia/Krasnoyarsk    Asia/Kuala_Lumpur    Asia/Kuching    Asia/Kuwait    Asia/Macao
    Asia/Macau    Asia/Magadan    Asia/Makassar    Asia/Manila    Asia/Muscat
    Asia/Nicosia    Asia/Novokuznetsk    Asia/Novosibirsk    Asia/Omsk    Asia/Oral
    Asia/Phnom_Penh    Asia/Pontianak    Asia/Pyongyang    Asia/Qatar    Asia/Qyzylorda
    Asia/Rangoon    Asia/Riyadh    Asia/Saigon    Asia/Sakhalin    Asia/Samarkand
    Asia/Seoul    Asia/Shanghai    Asia/Singapore    Asia/Taipei    Asia/Tashkent
    Asia/Tbilisi    Asia/Tehran    Asia/Tel_Aviv    Asia/Thimbu    Asia/Thimphu
    Asia/Tokyo    Asia/Ujung_Pandang    Asia/Ulaanbaatar    Asia/Ulan_Bator    Asia/Urumqi
    Asia/Ust-Nera    Asia/Vientiane    Asia/Vladivostok    Asia/Yakutsk    Asia/Yekaterinburg
  7. rc112
    rc112 Member
    126
    14
    2:23 PM
    Hi @eva2000 I had timezone set up as below in custom config file but I ran date and it output UTC, still.
    [20:16][root@centmin ~]# cat /etc/centminmod/custom_config.inc
    ZONEINFO=Asia/Taipei  # Set Timezone
    ZOPCACHEDFT='y'
    PHP_VERSION='7.1.15'
    NGINX_IPV='y'
    PHP_PGO='y'  # Use PHP 7.x with Profile Guide Optimizations (PGO)
    NGXDYNAMIC_BROTLI='y'
    NGINX_LIBBROTLI='y'
    CLOUDFLARE_ZLIBPHP='y' # use Cloudflare optimised zlib fork for PHP-FPM zlib instead of system zlib
    CLOUDFLARE_PATCHSSL='y'   # set 'y' to implement Cloudflare's chacha20 patch  [https://github.com/cloudflare/sslconfig](https://github.com/cloudflare/sslconfig)
    NGINX_DYNAMICTLS='y'    # set 'y' and recompile nginx  [https://blog.cloudflare.com/optimizing-tls-over-tcp-to-reduce-latency/](https://blog.cloudflare.com/optimizing-tls-over-tcp-to-reduce-latency/)
    OPENSSLECDSA_PATCH='y' # https://community.centminmod.com/posts/57725/
    OPENSSLECDHX_PATCH='y' # https://community.centminmod.com/posts/57726/
    Should I still set up a seperate custom file for php timezone? Thanks.
  8. Revenge
    Revenge Active Member
    469
    93
    Portugal
    7:23 AM
    1.9.x
    10.1.x
    Run this command:
    mv /etc/localtime /etc/localtime.bak
    ln -s /usr/share/zoneinfo/Asia/Taipei /etc/localtime
    Reboot the server after that.
  9. rc112
    rc112 Member
    126
    14
    2:23 PM
    Hi @eva2000
    1. Is it a bug? Or something I did wrong?
    2. I follow your other command on the forum to change and ran date and output the correct timezone.
    3. I also did this.
      vi /etc/centminmod/php.d/custom.ini
      date.timezone = Asia/Taipei
      fpmrestart
      How can I know php has the correct time zone? Thank you so mucn.
    55,896
    12,281
    4:23 PM
    pay attention to instructions in 1st post Install - Changing default CentOS system timezones centos 7 method is different from centos 6 method as well
    to check php timezone check phpinfo page or via command line phpinfo with grep filter on timezone keyword
    php -i | grep timezone
    Default timezone => UTC
    date.timezone => UTC => UTC
    fyi, I generally use UTC time cause if you have multiple servers it easier to see what's happing at UTC time
    Centmin Mod also sets a mytimes custom command which outputs various common timezones if the only reason you want to change timezone is to be able to see your timezone
     mytimes
    Fri Mar  2 20:27:16 UTC 2018    [UTC]
    Sat Mar  3 06:27:16 AEST 2018   [Australia/Brisbane]
    Fri Mar  2 12:27:16 PST 2018    [America/Los_Angeles]
    Fri Mar  2 14:27:16 CST 2018    [America/Chicago]
    Fri Mar  2 15:27:16 EST 2018    [America/New_York]
    Fri Mar  2 15:27:16 EST 2018    [America/Montreal]
    Fri Mar  2 20:27:16 GMT 2018    [Europe/London]
    Fri Mar  2 21:27:16 CET 2018    [Europe/Berlin]
    Sat Mar  3 03:27:16 +07 2018    [Asia/Bangkok]
    Sat Mar  3 03:27:16 +07 2018    [Asia/Ho_Chi_Minh]
    Sat Mar  3 03:27:16 WIB 2018    [Asia/Jakarta]
    Sat Mar  3 04:27:16 +08 2018    [Asia/Kuala_Lumpur]
    Sat Mar  3 04:27:16 +08 2018    [Asia/Singapore]
  11. rc112
    rc112 Member
    126
    14
    2:23 PM
    Yes, I used the method below to post-edit the timezone.
    timedatectl set-timezone America/Los_Angeles
    But the reason why I asked is I got
    in custom config file but it didnt take effect. I ran date and it still output UTC.
    Thank for your advice.
    55,896
    12,281
    4:23 PM
    You can grep filter your initial install log in /root/centminlogs to see what was set during initial install
    grep -A3 'preferred localtime' "$(echo "/root/centminlogs/$(ls /root/centminlogs/ | grep _install.log)")"
    the basically finds install log name using
    centminmod_123.09beta01.b016_250218-032050_install.log
    and does a grep -A3 for keywords 'preferred localtime' so returns matching keyword and the 3 lines after it
    so example output
    * Setting preferred localtime for VPS
    Current date & time for the zone you selected is:
    Sun Feb 25 03:22:09 UTC 2018
  13. rc112
    rc112 Member
    126
    14
    2:23 PM
    Here is the output. It didnt set up correctly at the first place. Not sure if it is also related to the character.
    [06:13][root@centmin ~]# grep -A3 'preferred localtime' "$(echo "/root/centminlogs/$(ls /root/centminlogs/ | grep _install.log)")"
    Fri Mar  2 08:14:16 UTC 2018
    55,896
    12,281
    4:23 PM
    might be due to method used for centos 6 and not 7 so might need to update the routine
    will update 123.09beta01 in a few moments :)
  15. rc112
    rc112 Member
    126
    14
    2:23 PM
    I will try with a new server. :D Thank you so much as always. Have a great weekend.
    55,896
    12,281
    4:23 PM
    Just updated with fix :)
  17. rc112
    rc112 Member
    126
    14
    2:23 PM
    So I need to update centminmod by running option23 > option2 if I previously have set up git base with option 1? Thank you.
    55,896
    12,281
    4:23 PM
    this can only be tested on fresh centmin mod 123.09beta01 installs
    initial install time is only time the timezone is updated
  19. rc112
    rc112 Member
    126
    14
    2:23 PM
    yes, got it. Thank you for your hard work. thumb up!
