Master Branch update MOTD routines in 123.09beta01
Discussion in 'Centmin Mod Github Commits' started by eva2000, Sep 30, 2019.
    4:31 AM
    - On first SSH login a MOTD banner is shown with Centmin Mod info and checks for latest nginx version and whether centmin mod code updates are available. Part of these checks is logging to a file named cmm-login-git-checks* in /root/centminlogs of this login routine with recorded time duration of how long the checks took. This is for troubleshooting if needed.
    - However, this SSH login routine is triggered for both interactive and non-interactive logins. So when you SSH login = interactive. But when you have scripts remotely connecting to your server, they're non-interactive but the MOTD banner and /root/centminlogs/cmm-login-git-checks* generated logs are still triggered.
    - This update changes it so that only interactive SSH logins trigger MOTD banner and /root/centminlogs/cmm-login-git-checks* generated logs. If you have scripts or processes which remotely log into the Centmin Mod server via SSH and they are non-interactive, then MOTD banner and /root/centminlogs/cmm-login-git-checks* generated logs are now skipped.
    - To update existing Centmin Mod 123.09beta01 servers, run cmupdate command and then run centmin.sh menu once and exit.
