Master Branch centos 6 fix for hostname -f detection
Discussion in 'Centmin Mod Github Commits' started by eva2000, Jul 24, 2017.
    37,703
    8,252
    10:56 AM
    - on centos 6 the hostname -f detection will give error unknown host on dummy not FQDN based hostnames so need to fallback to hostname command without -f when unknown host errror is detected.
    example if you run local virtualbox centos server and hostname is set to domain.localdomain instead of say host.domain.com, then hostname -f would result in
    hostname -f
    hostname: Unknown host
    so fall back to hostname command with -f
    hostname
    domain.localdomain
