Install CentOS 6 32bit Install Issue
Discussion in 'Install & Upgrades or Pre-Install Questions' started by iaTa, Mar 27, 2018.
  1. iaTa
    iaTa New Member
    24
    3:00 AM
    • CentOS Version: CentOS 6 32bit
    • Nginx Version Installed: N/A
    • PHP Version Installed: N/A
    • MariaDB MySQL Version Installed: N/A
    • When was last time updated Centmin Mod code base ? : New fresh install
    • Persistent Config: N/A
    I have issues early on in the installer as described in my introduction post: Hi!
    I'm running on a Vultr 512MB server and thought CentOS 6 32bit would be the best option.
    Any help would be appreciated.
    38,584
    8,514
    1:00 PM
    Example list /root/centminlogs files in date ascending order and grep for install.log
  3. iaTa
    iaTa New Member
    24
    3:00 AM
    38,584
    8,514
    1:00 PM
    what command did you use to install 123.09beta01 you seem to be missing the first part of the curl installer setup in the logs or your SSH window scroll buffer too small to view all the contents of install log, in which can need to download the install log and copy and paste contents to pastebin.
    install command
    Best bet for now is to use 64bit OS.
  5. iaTa
    iaTa New Member
    24
    3:00 AM
    This was the third attempt at trying to get this to install properly. In between each attempt I reinstalled the server.
    This third try I thought I would try 'yum -y update' first, reboot and then the rest of the install command 'curl -O https://centminmod.com/betainstaller.sh && chmod 0700 betainstaller.sh && bash betainstaller.sh' to see if that helped.
    So use CentOS 6 64-bit or 7 64-bit?
    38,584
    8,514
    1:00 PM
  7. JJC84
    JJC84 Active Member
    202
    10:00 PM
    10.1.x
    38,584
    8,514
    1:00 PM
    Guide is a bit old and the problem here is 32bit CentOS 6.x with 123.09beta01 could be something with my 123.09beta01 code as it more tuned for 64bit systems these days.
  9. JJC84
    JJC84 Active Member
    202
    10:00 PM
    10.1.x
    You're probably right on that. I'm happy I bit the bullet and migrated to Centos 7 actually. It has been a bit of a pain though.
  10. iaTa
    iaTa New Member
    24
    3:00 AM
    Worked fine on 64-bit. Maybe mention to not use 32-bit in the install guide.
    38,584
    8,514
    1:00 PM
    cheers.. will have to revisit 123.09beta01 install routine for 32bit and see what's what.
    38,584
    8,514
    1:00 PM
  13. iaTa
    iaTa New Member
    24
    3:00 AM
    38,584
    8,514
    1:00 PM
    centos 6 64bit right ? seems tripped on a dependency being missing or the version of
    libxslt being too old hmmm
    checking for xml2-config path... (cached) /usr/bin/xml2-config
    checking whether libxml build works... (cached) yes
    checking for XSL support... yes
    configure: error: xslt-config not found. Please reinstall the libxslt >= 1.1.0 distribution
    php_configure.inc make -j1
    make: *** No targets specified and no makefile found.  Stop.
    strange as php configuration routine will libxslt-devel yum package install it if not detected centminmod/centminmod
    can you check if libxslt-devel package was installed via command
    yum info libxslt-devel
    and
    yum history info libxslt-devel
    my Vultr CentOS 6.9 64bit 123.09beta01 install
    Loaded plugins: fastestmirror, priorities, security
     * base: mirrors.centos.webair.com
     * epel: epel.mirror.constant.com
     * extras: centos.mirror.constant.com
     * rpmforge: mirror.us.leaseweb.net
     * updates: ftp.osuosl.org
    1564 packages excluded due to repository priority protections
    Installed Packages
    Arch        : x86_64
    Version     : 1.1.26
    Release     : 2.el6_3.1
    Repo        : installed
    From repo   : base
    Summary     : Libraries, includes, etc. to embed the Gnome XSLT engine
    URL         : http://xmlsoft.org/XSLT/
    License     : MIT
    Description : This C library allows to transform XML files into other XML files
                : (or HTML, text, ...) using the standard XSLT stylesheet transformation
                : mechanism. To use it you need to have a version of libxml2 >= 2.6.27
                : installed.
    How long between Vultr CentOS server install and running centminmod 123.09beta01 installer ? as in between a few minutes Vultr as a cloud-init script which does a yum update run so need to wait 5-10 mins after server install to start installing stuff. A problem can be if you install straight away, then Vultr cloud-init script for yum update might lock yum process, so centmin mod install routine and it's yum package installs might not complete as Vultr's yum script is locking and hogging the yum process.
  15. iaTa
    iaTa New Member
    24
    3:00 AM
    Yes.
    [[email protected] ~]# yum info libxslt-devel
     * base: mirror.cc.columbia.edu
     * epel: mirror.beyondhosting.net
     * extras: mirror.cc.columbia.edu
     * rpmforge: apt.sw.be
     * updates: mirrors.advancedhosters.com
    Error: requested datatype primary not available
    [[email protected] ~]# yum history info libxslt-devel
    No transaction ID, or package, given
    Error: Failed history info
    Ah Ok I did run the install quite soon after the server came up.
    38,584
    8,514
    1:00 PM
    yeah for some reason your install run didn't properly install libxslt-devel. I am testing Vultr 512MB VPS with CentOS 6.9 64bit right this moment and it's compiling PHP fine. So most of been once off issue for you. Try reloading CentOS 6.9 64bit OS and after you can log in, wait 5-10 mins before running 123.09beta01 installer to allow Vultr cloud-init yum update to complete it's run.
    example of yum process conflict when another yum process is currently running
    Loaded plugins: fastestmirror, priorities, security, versionlock
    Existing lock /var/run/yum.pid: another copy is running as pid 28614.
    Another app is currently holding the yum lock; waiting for it to exit...
      The other application is: yum
        Memory :  27 M RSS (326 MB VSZ)
        Started: Tue Mar 27 04:06:07 2018 - 00:02 ago
        State  : Sleeping, pid: 28614
        Memory :  53 M RSS (352 MB VSZ)
        Started: Tue Mar 27 04:06:07 2018 - 00:04 ago
        State  : Running, pid: 28614
        Memory : 105 M RSS (404 MB VSZ)
        Started: Tue Mar 27 04:06:07 2018 - 00:06 ago
        Memory : 118 M RSS (418 MB VSZ)
        Started: Tue Mar 27 04:06:07 2018 - 00:08 ago
    completed CentOS 6.9 64bit 123.09beta01 install on Vultr 512MB VPS
    Total Curl Installer YUM or DNF Time: 212.4180 seconds
    Total YUM Time: 43.707585562 seconds
    Total YUM or DNF + Source Download Time: 85.7728
    Total Nginx First Time Install Time: 563.5568
    Total PHP First Time Install Time: 555.4672
    Download Zip From Github Time: 6.8105
    Total Time Other eg. source compiles: 425.8025
    Total Centmin Mod Install Time: 1630.5992
    Total Install Time (curl yum + cm install + zip download): 1849.8277 seconds
          1  Virtual CPU a7769a6388d5 (1  2394.454 Mhz)
    post install check list
    * Post-Install Check List....
    Check ccache Version:
    ccache version 3.4.1
    Copyright (C) 2009-2018 Joel Rosdahl
    version.
    Check Nginx Version:
    nginx version: nginx/1.13.10
    built by gcc 7.2.1 20170829 (Red Hat 7.2.1-1) (GCC)
    built with OpenSSL 1.1.0g  2 Nov 2017
    TLS SNI support enabled
    configure arguments: --with-ld-opt='-ljemalloc -Wl,-z,relro -Wl,-rpath,/usr/local/lib' --with-cc-opt='-m64 -march=native -g -O3 -fstack-protector-strong -flto -fuse-ld=gold --param=ssp-buffer-size=4 -Wformat -Werror=format-security -Wimplicit-fallthrough=0 -fcode-hoisting -Wp,-D_FORTIFY_SOURCE=2 -gsplit-dwarf' --sbin-path=/usr/local/sbin/nginx --conf-path=/usr/local/nginx/conf/nginx.conf --with-compat --with-http_stub_status_module --with-http_secure_link_module --with-libatomic --with-http_gzip_static_module --with-http_sub_module --with-http_addition_module --with-http_image_filter_module=dynamic --with-http_geoip_module --with-stream_geoip_module --with-stream_realip_module --with-stream_ssl_preread_module --with-threads --with-stream=dynamic --with-stream_ssl_module --with-http_realip_module --add-dynamic-module=../ngx-fancyindex-0.4.2 --add-module=../ngx_cache_purge-2.4.2 --add-module=../ngx_devel_kit-0.3.0 --add-dynamic-module=../set-misc-nginx-module-0.31 --add-dynamic-module=../echo-nginx-module-0.61 --add-module=../redis2-nginx-module-0.14 --add-module=../ngx_http_redis-0.3.7 --add-module=../memc-nginx-module-0.18 --add-module=../srcache-nginx-module-0.31 --add-dynamic-module=../headers-more-nginx-module-0.33 --with-pcre=../pcre-8.42 --with-pcre-jit --with-zlib=../zlib-cloudflare-1.3.0 --with-http_ssl_module --with-http_v2_module --with-openssl=../openssl-1.1.0g --with-openssl-opt='enable-ec_nistp_64_gcc_128'
    Check PHP-FPM Version:
    PHP 5.6.34 (cli) (built: Mar 27 2018 03:54:42)
    Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
        with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
    MariaDB-compat-10.1.31-1.el6.x86_64
    MariaDB-server-10.1.31-1.el6.x86_64
    MariaDB-common-10.1.31-1.el6.x86_64
    MariaDB-client-10.1.31-1.el6.x86_64
    MariaDB-shared-10.1.31-1.el6.x86_64
    MariaDB-devel-10.1.31-1.el6.x86_64
    memcached 1.5.6
    Check CSF Firewall Version:
    csf: v12.01 (generic)
    SIEGE 4.0.4
    Copyright (C) 2017 by Jeffrey Fulmer, et al.
    FOR A PARTICULAR PURPOSE.
    Check mysqlreport version:
    Check pure-ftpd Version:
    pure-ftpd v1.0.30
    Check YUM Repo List
    1555 packages excluded due to repository priority protections
    repo id                       repo name                              status
    base                          CentOS-6 - Base                        5,102+1,604
    centos-sclo-rh                CentOS-6 - SCLo rh                       6,243+162
    centos-sclo-sclo              CentOS-6 - SCLo sclo                           488
    epel                          Extra Packages for Enterprise Linux 6  9,377+3,089
    extras                        CentOS-6 - Extras                               53
    mariadb                       MariaDB                                       14+4
    rpmforge                      RHEL 6 - RPMforge.net - dag            3,168+1,550
    updates                       CentOS-6 - Updates                         991+186
    varnishcache_varnish41        varnishcache_varnish41                          45
    varnishcache_varnish41-source varnishcache_varnish41-source                    0
    repolist: 25,481
    mytimes check:
    /usr/bin/mytimes
    Tue Mar 27 04:00:38 UTC 2018    [UTC]
    Tue Mar 27 14:00:38 AEST 2018   [Australia/Brisbane]
    Mon Mar 26 21:00:38 PDT 2018    [America/Los_Angeles]
    Mon Mar 26 23:00:38 CDT 2018    [America/Chicago]
    Tue Mar 27 00:00:38 EDT 2018    [America/New_York]
    Tue Mar 27 00:00:38 EDT 2018    [America/Montreal]
    Tue Mar 27 05:00:38 BST 2018    [Europe/London]
    Tue Mar 27 06:00:38 CEST 2018   [Europe/Berlin]
    Tue Mar 27 11:00:38 +07 2018    [Asia/Bangkok]
    Tue Mar 27 11:00:38 +07 2018    [Asia/Ho_Chi_Minh]
    Tue Mar 27 11:00:38 WIB 2018    [Asia/Jakarta]
    Tue Mar 27 12:00:38 +08 2018    [Asia/Kuala_Lumpur]
    Tue Mar 27 12:00:38 +08 2018    [Asia/Singapore]
  17. iaTa
    iaTa New Member
    24
    3:00 AM
    Ok I'll give it a try, cheers!
  18. robert syputa
    robert syputa Member
    61
    11
    Seattle
    11:00 PM
    latest
  19. robert syputa
    61
    11
    Seattle
    11:00 PM
    latest
    I suggest upgrading to at least 1GB server and to use Centos 7.2. 512MB may be described as being a minimum to run Centos 6/7, however, the demands of most server environments require at least 1GB. 1GB VPS have become the baseline.
  20. iaTa
    iaTa New Member
    24
    3:00 AM
    512MB on Centos 6 64-bit is running superb!
