centminmodbench.sh for dedicated servers
Discussion in 'Dedicated server hosting' started by eva2000, Sep 14, 2014.
  1. Sebastian B.
    Sebastian B. New Member
    25
    3:27 PM
    1.7.2
    5.5
  2. rdan
    9:27 PM
  3. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    3:27 PM
    kimsufi benchmark for KS-5 Xeon 2 x E5504 4997 8c / 8t 2 GHz+ 16 GB ECC 2 TB 100 Mbps
    [CODE]
    centminmodbench.sh 0.9.2
    http://bench.centminmod.com
    written by: George Liu (eva2000)
    http://centminmod.com
    System Information
    3.10.0-514.2.2.el7.x86_64
    CentOS Linux release 7.3.1611 (Core)
    Centmin Mod
    Architecture:          x86_64
    CPU(s):                8
    On-line CPU(s) list:   0-7
    Thread(s) per core:    1
    Core(s) per socket:    4
    Socket(s):             2
    NUMA node(s):          2
    CPU family:            6
    Model:                 26
    Model name:            Intel(R) Xeon(R) CPU           E5504  @ 2.00GHz
    Stepping:              5
    CPU MHz:               2000.000
    BogoMIPS:              3999.43
    Virtualization:        VT-x
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              4096K
    NUMA node0 CPU(s):     0-3
    NUMA node1 CPU(s):     4-7
    CPU Flags
     fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm dca sse4_1 sse4_2 popcnt lahf_lm dtherm tpr_shadow vnmi flexpriority ept vpid
    CPU NODE SOCKET CORE L1d:L1i:L2:L3 ONLINE
    0   0    0      0    0:0:0:0       yes
    1   0    0      1    1:1:1:0       yes
    2   0    0      2    2:2:2:0       yes
    3   0    0      3    3:3:3:0       yes
    4   1    1      4    4:4:4:1       yes
    5   1    1      5    5:5:5:1       yes
    6   1    1      6    6:6:6:1       yes
    7   1    1      7    7:7:7:1       yes
    Mem:          16036         995       14211          56         829       14686
    Low:          16036        1825       14211
    Swap:          5118           0        5118
    /dev/sda2        29G  6.9G   21G  26% /
    devtmpfs        7.9G     0  7.9G   0% /dev
    tmpfs           7.9G     0  7.9G   0% /dev/shm
    tmpfs           7.9G  8.7M  7.9G   1% /run
    tmpfs           7.9G     0  7.9G   0% /sys/fs/cgroup
    /dev/sda3       1.8T  328M  1.7T   1% /home
    tmpfs           1.6G     0  1.6G   0% /run/user/0
    disk ioping tests
    2016-12-12 22:28:51 URL:https://storage.googleapis.com/google-code-archive-downloads/v2/code.google.com/ioping/ioping-0.8.tar.gz [10590/10590] -> "ioping-0.8.tar.gz" [1]
    Download done.
    ioping-0.8.tar.gz valid file.
    Running IOPing I/O benchmark...
    IOPing I/O: ./ioping -c 10 .
    4.0 KiB from . (ext4 /dev/sda3): request=1 time=391 us
    4.0 KiB from . (ext4 /dev/sda3): request=2 time=439 us
    4.0 KiB from . (ext4 /dev/sda3): request=3 time=387 us
    4.0 KiB from . (ext4 /dev/sda3): request=4 time=396 us
    4.0 KiB from . (ext4 /dev/sda3): request=5 time=369 us
    4.0 KiB from . (ext4 /dev/sda3): request=6 time=408 us
    4.0 KiB from . (ext4 /dev/sda3): request=7 time=365 us
    4.0 KiB from . (ext4 /dev/sda3): request=8 time=353 us
    4.0 KiB from . (ext4 /dev/sda3): request=9 time=363 us
    4.0 KiB from . (ext4 /dev/sda3): request=10 time=361 us
    --- . (ext4 /dev/sda3) ioping statistics ---
    10 requests completed in 9.0 s, 2.6 k iops, 10.2 MiB/s
    min/avg/max/mdev = 353 us / 383 us / 439 us / 25 us
    IOPing seek rate: ./ioping -RD .
    1.1 k requests completed in 3.0 s, 350 iops, 1.4 MiB/s
    min/avg/max/mdev = 217 us / 2.9 ms / 24.7 ms / 3.1 ms
    IOPing sequential: ./ioping -RL .
    2.1 k requests completed in 3.0 s, 715 iops, 178.9 MiB/s
    min/avg/max/mdev = 1.2 ms / 1.4 ms / 31.1 ms / 1.0 ms
    IOPing cached: ./ioping -RC .
    2.5 M requests completed in 3.0 s, 928.9 k iops, 3.5 GiB/s
    min/avg/max/mdev = 0 us / 1 us / 77 us / 0 us
    disk DD tests
    dd if=/dev/zero of=sb-io-test bs=1M count=1k conv=fdatasync
    1024+0 records in
    1024+0 records out
    1073741824 bytes (1.1 GB) copied, 6.8832 s, 156 MB/s
    dd if=/dev/zero of=sb-io-test bs=64k count=16k conv=fdatasync
    16384+0 records in
    16384+0 records out
    1073741824 bytes (1.1 GB) copied, 6.80508 s, 158 MB/s
    dd if=/dev/zero of=sb-io-test bs=1M count=1k oflag=dsync
    1024+0 records in
    1024+0 records out
    1073741824 bytes (1.1 GB) copied, 44.0682 s, 24.4 MB/s
    dd if=/dev/zero of=sb-io-test bs=64k count=16k oflag=dsync
    16384+0 records in
    16384+0 records out
    1073741824 bytes (1.1 GB) copied, 627.204 s, 1.7 MB/s
    disk FIO tests
    2016-12-12 22:40:41 URL:https://raw.githubusercontent.com/Crowd9/Benchmark/master/fio-2.0.9.tar.gz [275092/275092] -> "fio-2.0.9.tar.gz" [1]
    Download done.
    fio-2.0.9.tar.gz valid file.
    Running FIO benchmark...
    FIO_VERSION = fio-2.0.9
    FIO random reads:
    randomreads: (g=0): rw=randread, bs=4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.0.9
    Starting 1 process
    randomreads: Laying out IO file(s) (1 file(s) / 1024MB)
    randomreads: (groupid=0, jobs=1): err= 0: pid=5442: Mon Dec 12 23:03:15 2016
      read : io=1024.3MB, bw=799465 B/s, iops=195 , runt=1343397msec
      cpu          : usr=0.39%, sys=1.43%, ctx=262084, majf=0, minf=500
      IO depths    : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0%
         submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
         complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%
         issued    : total=r=262207/w=0/d=0, short=r=0/w=0/d=0
    Run status group 0 (all jobs):
       READ: io=1024.3MB, aggrb=780KB/s, minb=780KB/s, maxb=780KB/s, mint=1343397msec, maxt=1343397msec
    Disk stats (read/write):
      sda: ios=262083/307, merge=119/667, ticks=85894264/74524711, in_queue=160435330, util=100.00%
    FIO random writes:
    randomwrites: (g=0): rw=randwrite, bs=4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.0.9
    Starting 1 process
    randomwrites: (groupid=0, jobs=1): err= 0: pid=6047: Mon Dec 12 23:15:48 2016
      write: io=1024.3MB, bw=1393.2KB/s, iops=348 , runt=752828msec
      cpu          : usr=0.71%, sys=2.49%, ctx=259227, majf=0, minf=434
         issued    : total=r=0/w=262207/d=0, short=r=0/w=0/d=0
      WRITE: io=1024.3MB, aggrb=1393KB/s, minb=1393KB/s, maxb=1393KB/s, mint=752828msec, maxt=752828msec
      sda: ios=67/263278, merge=0/1375, ticks=9159/51488612, in_queue=51545890, util=100.00%
    ramdisk DD tests - memory bandwidth
    dd if=/dev/zero of=sb-io-test bs=128k count=1k conv=fdatasync
    1024+0 records in
    1024+0 records out
    134217728 bytes (134 MB) copied, 0.0801168 s, 1.7 GB/s
    dd if=/dev/zero of=sb-io-test bs=8k count=16k conv=fdatasync
    16384+0 records in
    16384+0 records out
    134217728 bytes (134 MB) copied, 0.0929765 s, 1.4 GB/s
    dd if=/dev/zero of=sb-io-test bs=128k count=1k oflag=dsync
    1024+0 records in
    1024+0 records out
    134217728 bytes (134 MB) copied, 0.0797469 s, 1.7 GB/s
    dd if=/dev/zero of=sb-io-test bs=8k count=16k oflag=dsync
    16384+0 records in
    16384+0 records out
    134217728 bytes (134 MB) copied, 0.0935483 s, 1.4 GB/s
    ramdisk ioping tests - memory bandwidth
    2016-12-12 23:15:49 URL:https://storage.googleapis.com/google-code-archive-downloads/v2/code.google.com/ioping/ioping-0.8.tar.gz [10590/10590] -> "ioping-0.8.tar.gz" [1]
    Download done.
    Running IOPing I/O ramdisk benchmark...
    4.0 KiB from . (tmpfs tmpfs): request=1 time=6 us
    4.0 KiB from . (tmpfs tmpfs): request=2 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=3 time=3 us
    4.0 KiB from . (tmpfs tmpfs): request=4 time=3 us
    4.0 KiB from . (tmpfs tmpfs): request=5 time=3 us
    4.0 KiB from . (tmpfs tmpfs): request=6 time=4 us
    4.0 KiB from . (tmpfs tmpfs): request=7 time=3 us
    4.0 KiB from . (tmpfs tmpfs): request=8 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=9 time=3 us
    4.0 KiB from . (tmpfs tmpfs): request=10 time=3 us
    --- . (tmpfs tmpfs) ioping statistics ---
    10 requests completed in 9.0 s, 263.2 k iops, 1.0 GiB/s
    min/avg/max/mdev = 3 us / 3 us / 6 us / 1 us
    IOPing seek rate: ./ioping -R .
    1.2 M requests completed in 3.0 s, 897.2 k iops, 3.4 GiB/s
    min/avg/max/mdev = 0 us / 1 us / 92 us / 0 us
    31.0 k requests completed in 3.0 s, 16.5 k iops, 4.0 GiB/s
    min/avg/max/mdev = 56 us / 60 us / 300 us / 4 us
    2.3 M requests completed in 3.0 s, 842.2 k iops, 3.2 GiB/s
    min/avg/max/mdev = 0 us / 1 us / 74 us / 0 us
    Running bandwidth benchmark...
    Download from Cachefly (http://cachefly.cachefly.net/100mb.test)
    Download Cachefly: 10.2MB/s
    USA bandwidth tests...
    Download from Linode, Atlanta, GA, USA (http://speedtest.atlanta.linode.com/100MB-atlanta.bin)
    Download Linode, Atlanta, GA, USA: 10.5MB/s
    Download from Linode, Dallas, TX, USA (http://speedtest.dallas.linode.com/100MB-dallas.bin)
    Download Linode, Dallas, TX, USA: 1.44MB/s
    Download from Leaseweb, Manassas, VA, USA (http://mirror.us.leaseweb.net/speedtest/100mb.bin)
    Download Leaseweb, Manassas, VA, USA: 10.6MB/s
    Download from Softlayer, Seattle, WA, USA (http://speedtest.sea01.softlayer.com/downloads/test100.zip)
    Download Softlayer, Seattle, WA, USA: 5.68MB/s
    Download from Softlayer, San Jose, CA, USA (http://speedtest.sjc01.softlayer.com/downloads/test100.zip)
    Download Softlayer, San Jose, CA, USA: 8.26MB/s
    Download from Softlayer, Washington, DC, USA (http://speedtest.wdc01.softlayer.com/downloads/test100.zip)
    Download Softlayer, Washington, DC, USA: 10.2MB/s
    Download from VersaWeb, Las Vegas, Nevada (http://104.143.15.254/100MB.test)
    Download VersaWeb, Las Vegas, Nevada: 2.54MB/s
    Download from OVH, BHS, Canada (http://bhs.proof.ovh.net/files/100Mio.dat)
    Download OVH, BHS, Canada: 10.4MB/s
    Download from Vultr, Los Angeles, California (http://lax-ca-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Los Angeles, California: 6.39MB/s
    Download from Vultr, Seattle, Washington (http://wa-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Seattle, Washington: 6.20MB/s
    Download from Vultr, Dallas, Texas (http://tx-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Dallas, Texas: 6.53MB/s
    Download from Vultr, Chicago, Illinois (http://il-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Chicago, Illinois: 8.23MB/s
    Download from Vultr, Atlanta, Georgia (http://ga-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Atlanta, Georgia: 9.26MB/s
    Download from Vultr, Miami, Florida (http://fl-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Miami, Florida: 6.71MB/s
    Download from Vultr, New York / New Jersey (http://nj-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, New York / New Jersey: 10.5MB/s
    Asia bandwidth tests...
    Download from Linode, Tokyo, JP (http://speedtest.tokyo.linode.com/100MB-tokyo.bin)
    Download Linode, Tokyo, JP: 4.22MB/s
    Download from Softlayer, Singapore (http://speedtest.sng01.softlayer.com/downloads/test100.zip)
    Download Softlayer, Singapore: 6.44MB/s
    Download from Vultr, Tokyo, Japan (http://hnd-jp-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Tokyo, Japan: 4.13MB/s
    Europe bandwidth tests...
    Download from Linode, London, UK (http://speedtest.london.linode.com/100MB-london.bin)
    Download Linode, London, UK: 11.2MB/s
    Download from OVH, Paris, France (http://proof.ovh.net/files/100Mio.dat)
    Download OVH, Paris, France: 11.2MB/s
    Download from SmartDC, Rotterdam, Netherlands (http://mirror.i3d.net/100mb.bin)
    Download SmartDC, Rotterdam, Netherlands: 11.1MB/s
    Download from Vultr, Amsterdam, Netherlands (http://ams-nl-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Amsterdam, Netherlands: 11.2MB/s
    Download from Vultr, London, UK (http://lon-gb-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, London, UK: 11.2MB/s
    Download from Vultr, Paris, France (http://par-fr-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Paris, France: 11.1MB/s
    Australia bandwidth tests...
    Download from Vultr, Sydney, Australia (http://syd-au-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Sydney, Australia: 3.47MB/s
    Running Axel multi-threaded bandwidth benchmark...
    Axel Download from Cachefly (http://cachefly.cachefly.net/100mb.test)
    Axel Download Cachefly: 6.87MB/s
    Axel Download from Linode, Atlanta, GA, USA (http://speedtest.atlanta.linode.com/100MB-atlanta.bin)
    Axel Download Linode, Atlanta, GA, USA: 8.16MB/s
    Axel Download from Linode, Dallas, TX, USA (http://speedtest.dallas.linode.com/100MB-dallas.bin)
    Axel Download Linode, Dallas, TX, USA: 4.86MB/s
    Axel Download from Leaseweb, Manassas, VA, USA (http://mirror.us.leaseweb.net/speedtest/100mb.bin)
    Axel Download Leaseweb, Manassas, VA, USA: 8.78MB/s
    Axel Download from Softlayer, Seattle, WA, USA (http://speedtest.sea01.softlayer.com/downloads/test100.zip)
    Axel Download Softlayer, Seattle, WA, USA: 7.73MB/s
    Axel Download from Softlayer, San Jose, CA, USA (http://speedtest.sjc01.softlayer.com/downloads/test100.zip)
    Axel Download Softlayer, San Jose, CA, USA: 7.47MB/s
    Axel Download from Softlayer, Washington, DC, USA (http://speedtest.wdc01.softlayer.com/downloads/test100.zip)
    Axel Download Softlayer, Washington, DC, USA: 9.54MB/s
    Axel Download from VersaWeb, Las Vegas, Nevada (http://104.143.15.254/100MB.test)
    Axel Download VersaWeb, Las Vegas, Nevada: 6.07MB/s
    Axel Download from OVH, BHS, Canada (http://bhs.proof.ovh.net/files/100Mio.dat)
    Axel Download OVH, BHS, Canada: 9.10MB/s
    Axel Download from Vultr, Los Angeles, California (http://lax-ca-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Los Angeles, California: 7.46MB/s
    Axel Download from Vultr, Seattle, Washington (http://wa-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Seattle, Washington: 6.44MB/s
    Axel Download from Vultr, Dallas, Texas (http://tx-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Dallas, Texas: 3.61MB/s
    Axel Download from Vultr, Chicago, Illinois (http://il-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Chicago, Illinois: 8.29MB/s
    Axel Download from Vultr, Atlanta, Georgia (http://ga-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Atlanta, Georgia: 8.55MB/s
    Axel Download from Vultr, Miami, Florida (http://fl-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Miami, Florida: 7.94MB/s
    Axel Download from Vultr, New York / New Jersey (http://nj-us-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, New York / New Jersey: 10.37MB/s
    Axel Download from Linode, Tokyo, JP (http://speedtest.tokyo.linode.com/100MB-tokyo.bin)
    Axel Download Linode, Tokyo, JP: 6.59MB/s
    Axel Download from Softlayer, Singapore (http://speedtest.sng01.softlayer.com/downloads/test100.zip)
    Axel Download Softlayer, Singapore: 6.44MB/s
    Axel Download from Vultr, Tokyo, Japan (http://hnd-jp-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Tokyo, Japan: 3.89MB/s
    Axel Download from Linode, London, UK (http://speedtest.london.linode.com/100MB-london.bin)
    Axel Download Linode, London, UK: 11.00MB/s
    Axel Download from OVH, Paris, France (http://proof.ovh.net/files/100Mio.dat)
    Axel Download OVH, Paris, France: 11.01MB/s
    Axel Download from SmartDC, Rotterdam, Netherlands (http://mirror.i3d.net/100mb.bin)
    Axel Download SmartDC, Rotterdam, Netherlands: 11.06MB/s
    Axel Download from Vultr, Amsterdam, Netherlands (http://ams-nl-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Amsterdam, Netherlands: 11.10MB/s
    Axel Download from Vultr, London, UK (http://lon-gb-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, London, UK: 11.10MB/s
    Axel Download from Vultr, Paris, France (http://par-fr-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Paris, France: 11.06MB/s
    Axel Download from Vultr, Sydney, Australia (http://syd-au-ping.vultr.com/vultr.com.100MB.bin)
    Axel Download Vultr, Sydney, Australia: 3.30MB/s
    Running ping tests...
    Pings (cachefly.cachefly.net):
    PING vip1.g5.cachefly.net (205.234.175.175) 56(84) bytes of data.
    64 bytes from vip1.G-anycast1.cachefly.net (205.234.175.175): icmp_seq=1 ttl=56 time=84.3 ms
    64 bytes from vip1.G-anycast1.cachefly.net (205.234.175.175): icmp_seq=2 ttl=56 time=84.2 ms
    64 bytes from vip1.G-anycast1.cachefly.net (205.234.175.175): icmp_seq=3 ttl=56 time=84.2 ms
    --- vip1.g5.cachefly.net ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2003ms
    rtt min/avg/max/mdev = 84.203/84.259/84.352/0.341 ms
    Pings (syd-au-ping.vultr.com):
    PING syd-au-ping.vultr.com (108.61.212.117) 56(84) bytes of data.
    64 bytes from 108.61.212.117.vultr.com (108.61.212.117): icmp_seq=1 ttl=48 time=294 ms
    64 bytes from 108.61.212.117.vultr.com (108.61.212.117): icmp_seq=2 ttl=48 time=294 ms
    64 bytes from 108.61.212.117.vultr.com (108.61.212.117): icmp_seq=3 ttl=48 time=294 ms
    --- syd-au-ping.vultr.com ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2000ms
    rtt min/avg/max/mdev = 294.311/294.335/294.357/0.626 ms
    Pings (hnd-jp-ping.vultr.com):
    PING hnd-jp-ping.vultr.com (108.61.201.151) 56(84) bytes of data.
    64 bytes from 108.61.201.151.vultr.com (108.61.201.151): icmp_seq=1 ttl=50 time=225 ms
    64 bytes from 108.61.201.151.vultr.com (108.61.201.151): icmp_seq=2 ttl=50 time=225 ms
    64 bytes from 108.61.201.151.vultr.com (108.61.201.151): icmp_seq=3 ttl=50 time=225 ms
    --- hnd-jp-ping.vultr.com ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2001ms
    rtt min/avg/max/mdev = 225.021/225.046/225.074/0.548 ms
    Pings (lax-ca-us-ping.vultr.com):
    PING lax-ca-us-ping.vultr.com (108.61.219.200) 56(84) bytes of data.
    64 bytes from 108.61.219.200.vultr.com (108.61.219.200): icmp_seq=1 ttl=55 time=131 ms
    64 bytes from 108.61.219.200.vultr.com (108.61.219.200): icmp_seq=2 ttl=55 time=131 ms
    64 bytes from 108.61.219.200.vultr.com (108.61.219.200): icmp_seq=3 ttl=55 time=131 ms
    --- lax-ca-us-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 131.860/131.909/131.983/0.422 ms
    Pings (wa-us-ping.vultr.com):
    PING wa-us-ping.vultr.com (108.61.194.105) 56(84) bytes of data.
    64 bytes from 108.61.194.105.vultr.com (108.61.194.105): icmp_seq=1 ttl=52 time=141 ms
    64 bytes from 108.61.194.105.vultr.com (108.61.194.105): icmp_seq=2 ttl=52 time=141 ms
    64 bytes from 108.61.194.105.vultr.com (108.61.194.105): icmp_seq=3 ttl=52 time=141 ms
    --- wa-us-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 141.825/141.857/141.910/0.436 ms
    Pings (tx-us-ping.vultr.com):
    PING tx-us-ping.vultr.com (108.61.224.175) 56(84) bytes of data.
    64 bytes from 108.61.224.175.vultr.com (108.61.224.175): icmp_seq=1 ttl=52 time=118 ms
    64 bytes from 108.61.224.175.vultr.com (108.61.224.175): icmp_seq=2 ttl=52 time=118 ms
    64 bytes from 108.61.224.175.vultr.com (108.61.224.175): icmp_seq=3 ttl=52 time=118 ms
    --- tx-us-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 118.819/118.879/118.986/0.405 ms
    Pings (il-us-ping.vultr.com):
    PING il-us-ping.vultr.com (107.191.51.12) 56(84) bytes of data.
    64 bytes from 107.191.51.12.vultr.com (107.191.51.12): icmp_seq=1 ttl=53 time=96.0 ms
    64 bytes from 107.191.51.12.vultr.com (107.191.51.12): icmp_seq=2 ttl=52 time=95.7 ms
    64 bytes from 107.191.51.12.vultr.com (107.191.51.12): icmp_seq=3 ttl=53 time=95.8 ms
    --- il-us-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 95.797/95.906/96.048/0.105 ms
    Pings (ga-us-ping.vultr.com):
    PING ga-us-ping.vultr.com (108.61.193.166) 56(84) bytes of data.
    64 bytes from 108.61.193.166.vultr.com (108.61.193.166): icmp_seq=1 ttl=51 time=91.4 ms
    64 bytes from 108.61.193.166.vultr.com (108.61.193.166): icmp_seq=2 ttl=51 time=87.1 ms
    64 bytes from 108.61.193.166.vultr.com (108.61.193.166): icmp_seq=3 ttl=51 time=90.0 ms
    --- ga-us-ping.vultr.com ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2002ms
    rtt min/avg/max/mdev = 87.186/89.561/91.446/1.773 ms
    Pings (fl-us-ping.vultr.com):
    PING fl-us-ping.vultr.com (104.156.244.232) 56(84) bytes of data.
    64 bytes from 104.156.244.232 (104.156.244.232): icmp_seq=1 ttl=53 time=123 ms
    64 bytes from 104.156.244.232 (104.156.244.232): icmp_seq=2 ttl=53 time=124 ms
    64 bytes from 104.156.244.232 (104.156.244.232): icmp_seq=3 ttl=53 time=133 ms
    --- fl-us-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 123.269/127.053/133.842/4.828 ms
    Pings (nj-us-ping.vultr.com):
    PING nj-us-ping.vultr.com (108.61.149.182) 56(84) bytes of data.
    64 bytes from 108.61.149.182.vultr.com (108.61.149.182): icmp_seq=1 ttl=52 time=72.1 ms
    64 bytes from 108.61.149.182.vultr.com (108.61.149.182): icmp_seq=2 ttl=51 time=72.1 ms
    64 bytes from 108.61.149.182.vultr.com (108.61.149.182): icmp_seq=3 ttl=52 time=72.1 ms
    --- nj-us-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 72.110/72.145/72.186/0.221 ms
    Pings (fra-de-ping.vultr.com):
    PING fra-de-ping.vultr.com (108.61.210.117) 56(84) bytes of data.
    64 bytes from 108.61.210.117.vultr.com (108.61.210.117): icmp_seq=1 ttl=55 time=13.9 ms
    64 bytes from 108.61.210.117.vultr.com (108.61.210.117): icmp_seq=2 ttl=55 time=13.8 ms
    64 bytes from 108.61.210.117.vultr.com (108.61.210.117): icmp_seq=3 ttl=55 time=13.9 ms
    --- fra-de-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 13.864/13.904/13.939/0.030 ms
    Pings (ams-nl-ping.vultr.com):
    PING ams-nl-ping.vultr.com (108.61.198.102) 56(84) bytes of data.
    64 bytes from 108.61.198.102.vultr.com (108.61.198.102): icmp_seq=1 ttl=58 time=6.00 ms
    64 bytes from 108.61.198.102.vultr.com (108.61.198.102): icmp_seq=2 ttl=58 time=9.90 ms
    64 bytes from 108.61.198.102.vultr.com (108.61.198.102): icmp_seq=3 ttl=58 time=6.03 ms
    --- ams-nl-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 6.000/7.310/9.902/1.835 ms
    Pings (lon-gb-ping.vultr.com):
    PING lon-gb-ping.vultr.com (108.61.196.101) 56(84) bytes of data.
    64 bytes from 108.61.196.101.vultr.com (108.61.196.101): icmp_seq=1 ttl=58 time=4.26 ms
    64 bytes from 108.61.196.101.vultr.com (108.61.196.101): icmp_seq=2 ttl=58 time=4.22 ms
    64 bytes from 108.61.196.101.vultr.com (108.61.196.101): icmp_seq=3 ttl=58 time=4.26 ms
    --- lon-gb-ping.vultr.com ping statistics ---
    rtt min/avg/max/mdev = 4.225/4.252/4.267/0.056 ms
    Pings (par-fr-ping.vultr.com):
    PING par-fr-ping.vultr.com (108.61.209.127) 56(84) bytes of data.
    64 bytes from 108.61.209.127.vultr.com (108.61.209.127): icmp_seq=1 ttl=54 time=15.0 ms
    64 bytes from 108.61.209.127.vultr.com (108.61.209.127): icmp_seq=2 ttl=54 time=14.9 ms
    64 bytes from 108.61.209.127.vultr.com (108.61.209.127): icmp_seq=3 ttl=54 time=14.9 ms
    --- par-fr-ping.vultr.com ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2004ms
    rtt min/avg/max/mdev = 14.939/14.975/15.033/0.108 ms
    Pings (VersaWeb Las Vegas):
    PING 104.143.15.254 (104.143.15.254) 56(84) bytes of data.
    64 bytes from 104.143.15.254: icmp_seq=1 ttl=54 time=133 ms
    64 bytes from 104.143.15.254: icmp_seq=2 ttl=54 time=133 ms
    64 bytes from 104.143.15.254: icmp_seq=3 ttl=54 time=133 ms
    --- 104.143.15.254 ping statistics ---
    rtt min/avg/max/mdev = 133.862/133.905/133.938/0.423 ms
    Pings (VersaWeb Seattle):
    PING 76.164.234.1 (76.164.234.1) 56(84) bytes of data.
    64 bytes from 76.164.234.1: icmp_seq=1 ttl=53 time=143 ms
    64 bytes from 76.164.234.1: icmp_seq=2 ttl=53 time=143 ms
    64 bytes from 76.164.234.1: icmp_seq=3 ttl=53 time=143 ms
    --- 76.164.234.1 ping statistics ---
    rtt min/avg/max/mdev = 143.439/143.461/143.475/0.309 ms
    Pings (OVH Canada):
    PING bhs.proof.ovh.net (192.99.19.165) 56(84) bytes of data.
    64 bytes from bhs.proof.ovh.net (192.99.19.165): icmp_seq=1 ttl=60 time=80.5 ms
    64 bytes from bhs.proof.ovh.net (192.99.19.165): icmp_seq=2 ttl=60 time=80.4 ms
    64 bytes from bhs.proof.ovh.net (192.99.19.165): icmp_seq=3 ttl=60 time=80.4 ms
    --- bhs.proof.ovh.net ping statistics ---
    rtt min/avg/max/mdev = 80.408/80.477/80.542/0.332 ms
    Running mtr tests...
    mtr --report -w 200 --report-cycles=10 cachefly.cachefly.net
    Start: Mon Dec 12 23:30:06 2016
    HOST: hostname                  Loss%   Snt   Last   Avg  Best  Wrst StDev
      1.|-- rbx1-3b-a9.fr.eu                          0.0%    10    3.7   3.9   1.1   6.1   1.6
      2.|-- be11-146.rbx-g1-a9.fr.eu                  0.0%    10    0.4   0.3   0.3   0.4   0.0
      3.|-- 10.95.64.0                                0.0%    10    5.0   6.0   4.7  17.0   3.8
      4.|-- be100-1041.ldn-1-a9.uk.eu                 0.0%    10    4.1   4.2   4.1   4.5   0.0
      5.|-- be100-1295.nwk-1-a9.nj.us                 0.0%    10   70.3  70.3  70.3  70.6   0.0
      6.|-- be10-1037.bhs-g1-a9.qc.ca                 0.0%    10   77.9  78.0  77.8  78.8   0.0
      7.|-- be100-1214.tor-1-a9.on.ca                 0.0%    10   86.4  86.6  86.4  86.7   0.0
      8.|-- torix.te1-4.core01.tor1.prioritycolo.com  0.0%    10   84.5  84.6  84.4  85.6   0.0
      9.|-- ???                                      100.0    10    0.0   0.0   0.0   0.0   0.0
     10.|-- vip1.G-anycast1.cachefly.net              0.0%    10   84.2  84.2  84.2  84.3   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.atlanta.linode.com
    Start: Mon Dec 12 23:30:22 2016
      1.|-- rbx1-3b-a9.fr.eu                                  0.0%    10    4.1   3.3   0.9   5.5   1.4
      2.|-- be11-146.rbx-g1-a9.fr.eu                          0.0%    10    0.2   0.3   0.2   0.3   0.0
      3.|-- ???                                              100.0    10    0.0   0.0   0.0   0.0   0.0
      4.|-- be100-1041.ldn-1-a9.uk.eu                         0.0%    10    4.1   4.3   4.0   4.6   0.0
      5.|-- ge-3-3-0.mpr1.lhr3.uk.above.net                   0.0%    10    4.7   4.1   3.9   4.7   0.0
      6.|-- ae6.mpr3.lhr3.uk.zip.zayo.com                     0.0%    10    4.2   4.3   4.2   4.8   0.0
      7.|-- ae27.cs1.lhr15.uk.eth.zayo.com                    0.0%    10   88.9  88.9  88.9  89.0   0.0
      8.|-- ae5.cs1.dca2.us.eth.zayo.com                      0.0%    10  109.6 105.0  88.3 136.9  18.1
      9.|-- ae28.mpr4.atl6.us.zip.zayo.com                    0.0%    10   90.4  90.5  90.4  90.9   0.0
     10.|-- ae4.mpr3.atl6.us.zip.zayo.com                     0.0%    10   88.6  90.0  88.4  97.1   3.1
     11.|-- 173.46.64.214.static.not.updated.ignitionmsp.com  0.0%    10   89.5  89.6  89.5  89.7   0.0
     12.|-- 74.207.239.7                                      0.0%    10   88.5  88.6  88.5  88.6   0.0
     13.|-- speedtest.atlanta.linode.com                      0.0%    10   88.3  88.3  88.2  88.4   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.dallas.linode.com
    Start: Mon Dec 12 23:30:38 2016
      1.|-- rbx1-3b-a9.fr.eu                        0.0%    10    3.6   3.2   1.0   6.6   1.3
      2.|-- be11-146.rbx-g1-a9.fr.eu                0.0%    10    0.3   0.3   0.3   0.4   0.0
      3.|-- 10.95.64.0                              0.0%    10    5.4   5.1   4.8   5.5   0.0
      4.|-- be100-1048.ams-1-a9.nl.eu               0.0%    10    5.9   5.8   5.5   6.0   0.0
      5.|-- bbr01.eq01.ams01.networklayer.com       0.0%    10    6.2   6.0   5.9   6.2   0.0
      6.|-- ae1.bbr02.eq01.wdc02.networklayer.com   0.0%    10   80.2  80.3  80.2  80.9   0.0
      7.|-- ae6.cbs01.eq01.wdc02.networklayer.com  70.0%    10   83.9  83.8  83.5  84.1   0.0
      8.|-- ae1.cbs01.tl01.atl01.networklayer.com  30.0%    10   94.5  97.7  94.4 115.9   8.0
      9.|-- ae0.cbs02.eq01.dal03.networklayer.com  50.0%    10  113.5 112.7 112.1 113.5   0.0
     10.|-- ae34.bbr02.eq01.dal03.networklayer.com  0.0%    10  109.6 117.0 109.6 169.8  18.9
     11.|-- ae6.dar01.dal06.networklayer.com        0.0%    10  109.6 109.6 109.5 109.6   0.0
     12.|-- po61.dsr02.dllstx2.networklayer.com     0.0%    10  109.8 109.8 109.5 110.0   0.0
     13.|-- po2.car01.dllstx2.networklayer.com      0.0%    10  109.6 109.6 109.5 109.9   0.0
     14.|-- 62.7.1243.static.theplanet.com          0.0%    10  111.7 111.7 111.5 111.8   0.0
     15.|-- gw-h18.linode.com                       0.0%    10  111.6 111.6 111.5 111.8   0.0
     16.|-- speedtest.dallas.linode.com             0.0%    10  109.8 109.7 109.5 110.1   0.0
    mtr --report -w 200 --report-cycles=10 mirror.us.leaseweb.net
    Start: Mon Dec 12 23:30:55 2016
      1.|-- rbx1-3b-a9.fr.eu                      0.0%    10    2.7   3.2   0.9   5.3   1.4
      2.|-- be11-146.rbx-g1-a9.fr.eu              0.0%    10    0.3   0.3   0.3   0.3   0.0
      3.|-- 10.95.64.0                            0.0%    10    4.8   4.9   4.8   5.1   0.0
      4.|-- be100-1048.ams-1-a9.nl.eu             0.0%    10    5.6   5.8   5.6   6.0   0.0
      5.|-- be100-2.ams-5-a9.nl.eu                0.0%    10    5.8   5.9   5.7   6.1   0.0
      6.|-- ???                                  100.0    10    0.0   0.0   0.0   0.0   0.0
      7.|-- te-8-1.bb01.wdc-01.leaseweb.net      60.0%    10   83.7  83.7  83.6  83.7   0.0
      8.|-- xe-8-1-1.br01.wdc-01.us.leaseweb.net  0.0%    10   83.5  84.0  83.5  85.1   0.0
      9.|-- po-11.ce01.wdc-01.us.leaseweb.net     0.0%    10   84.2  84.2  84.2  84.3   0.0
     10.|-- mirror.us.leaseweb.net                0.0%    10   84.3  84.2  84.2  84.3   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.sea01.softlayer.com
    Start: Mon Dec 12 23:31:10 2016
      1.|-- rbx1-3b-a9.fr.eu                       0.0%    10    3.2   4.2   3.0   5.3   0.7
      2.|-- be11-315.rbx-g2-a9.fr.eu               0.0%    10    0.3   0.3   0.2   0.3   0.0
      4.|-- be100-1050.ams-5-a9.nl.eu              0.0%    10    5.7   5.8   5.6   6.1   0.0
      5.|-- bbr01.eq01.ams01.networklayer.com      0.0%    10    6.0   6.3   6.0   7.4   0.3
      6.|-- ae7.bbr02.eq01.ams02.networklayer.com  0.0%    10    6.2   7.0   6.2   8.8   0.7
      7.|-- ae0.bbr02.tg01.lon01.networklayer.com  0.0%    10    8.2   8.9   8.1  11.5   1.2
      8.|-- ae7.bbr01.tg01.lon01.networklayer.com  0.0%    10    8.1   8.2   8.1   8.4   0.0
      9.|-- ae1.bbr02.tl01.nyc01.networklayer.com  0.0%    10   76.9  77.0  76.9  77.3   0.0
     10.|-- ae6.cbs02.tl01.nyc01.networklayer.com 20.0%    10   78.1  78.3  77.7  79.0   0.0
     11.|-- ae0.cbs01.eq01.chi01.networklayer.com 70.0%    10  101.2 101.5 101.2 101.9   0.0
     12.|-- ae8.bbr02.eq01.chi01.networklayer.com  0.0%    10   98.7  98.6  98.3  99.2   0.0
     13.|-- ae1.bbr02.wb01.sea02.networklayer.com  0.0%    10  150.4 150.6 150.3 151.5   0.0
     14.|-- ae1.dar01.sr01.sea01.networklayer.com  0.0%    10  150.3 150.4 150.2 150.5   0.0
     15.|-- po1.fcr01.sr01.sea01.networklayer.com  0.0%    10  150.9 151.3 150.7 154.2   1.1
     16.|-- speedtest.sea01.softlayer.com          0.0%    10  150.6 150.6 150.4 150.8   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.sjc01.softlayer.com
    Start: Mon Dec 12 23:31:28 2016
      1.|-- rbx1-3b-a9.fr.eu                        0.0%    10    3.4   3.3   1.1   5.2   1.3
      2.|-- be11-315.rbx-g1-a9.fr.eu                0.0%    10    0.3   0.3   0.3   0.3   0.0
      3.|-- 10.95.64.0                              0.0%    10    4.9   6.8   4.9  23.5   5.8
      4.|-- be100-1048.ams-1-a9.nl.eu               0.0%    10    5.8   5.8   5.7   6.0   0.0
      5.|-- bbr01.eq01.ams01.networklayer.com       0.0%    10    6.1   6.2   6.0   7.3   0.3
      6.|-- ae7.bbr02.eq01.ams02.networklayer.com   0.0%    10    6.5   6.8   6.2  11.7   1.6
      7.|-- ae0.bbr02.tg01.lon01.networklayer.com   0.0%    10   12.0   9.8   9.4  12.0   0.7
      8.|-- ae7.bbr01.tg01.lon01.networklayer.com   0.0%    10    9.7   9.7   9.5  10.1   0.0
      9.|-- ae1.bbr02.tl01.nyc01.networklayer.com   0.0%    10   78.0  78.4  77.9  80.5   0.7
     10.|-- ae6.cbs02.tl01.nyc01.networklayer.com  70.0%    10   79.4  79.4  79.3  79.6   0.0
     11.|-- ae0.cbs01.eq01.chi01.networklayer.com  40.0%    10  102.7 102.4 102.0 102.7   0.0
     12.|-- ae7.cbs02.eq01.chi01.networklayer.com   0.0%    10  101.1 105.0 100.9 124.2   8.1
     13.|-- ae0.cbs02.cs01.den01.networklayer.com   0.0%    10  121.8 122.4 121.6 125.9   1.1
     14.|-- ae1.cbs01.eq01.sjc02.networklayer.com   0.0%    10  147.2 147.5 146.4 150.9   1.1
     15.|-- ae23.bbr01.eq01.sjc02.networklayer.com  0.0%    10  147.1 147.1 146.9 147.7   0.0
     16.|-- ae5.dar01.sjc01.networklayer.com        0.0%    10  145.5 146.2 145.4 149.9   1.2
     17.|-- po1.fcr01.sr01.sjc01.networklayer.com   0.0%    10  147.3 147.1 147.0 147.3   0.0
     18.|-- speedtest.sjc01.softlayer.com           0.0%    10  147.1 147.2 147.1 147.3   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.wdc01.softlayer.com
    Start: Mon Dec 12 23:31:44 2016
      1.|-- rbx1-3b-a9.fr.eu                       0.0%    10    2.8   3.4   1.1   8.0   1.8
      2.|-- be11-146.rbx-g2-a9.fr.eu               0.0%    10    0.3   0.3   0.2   0.4   0.0
      3.|-- 10.95.64.2                             0.0%    10    4.8   4.9   4.8   5.2   0.0
      4.|-- be100-1050.ams-5-a9.nl.eu              0.0%    10    5.9   5.8   5.6   6.0   0.0
      5.|-- bbr01.eq01.ams01.networklayer.com      0.0%    10    6.1   6.1   5.9   6.2   0.0
      6.|-- ae1.bbr02.eq01.wdc02.networklayer.com  0.0%    10   80.3  80.4  80.2  81.0   0.0
      7.|-- ae1.dar01.wdc01.networklayer.com       0.0%    10   83.6  81.8  81.5  83.6   0.6
      8.|-- po1.fcr01.sr01.wdc01.networklayer.com  0.0%    10   81.7  81.9  81.4  84.7   0.9
      9.|-- speedtest.wdc01.softlayer.com          0.0%    10  125.8 177.8 125.8 211.5  30.9
    mtr --report -w 200 --report-cycles=10 speedtest.tokyo.linode.com
    Start: Mon Dec 12 23:31:59 2016
      1.|-- rbx1-3b-a9.fr.eu                        0.0%    10    0.9   3.5   0.9   5.1   1.4
      2.|-- be11-146.rbx-g1-a9.fr.eu                0.0%    10    0.3   0.3   0.2   0.3   0.0
      4.|-- be99-1043.th2-1-a9.fr.eu                0.0%    10    4.4   4.2   4.1   4.4   0.0
      5.|-- ???                                    100.0    10    0.0   0.0   0.0   0.0   0.0
      6.|-- be12309.ccr42.par01.atlas.cogentco.com  0.0%    10    4.4   4.4   4.3   4.4   0.0
      7.|-- be2425.rcr21.par05.atlas.cogentco.com   0.0%    10    5.1   5.5   5.0   8.7   1.0
      8.|-- gttnet.par05.atlas.cogentco.com         0.0%    10    4.5   4.5   4.5   4.6   0.0
      9.|-- xe-9-3-0.cr0-sjc1.ip4.gtt.net           0.0%    10  156.1 150.5 149.8 156.1   2.0
     10.|-- ip4.gtt.net                             0.0%    10  155.7 158.8 155.7 186.5   9.7
     11.|-- sjeGCS001.int-gw.kddi.ne.jp             0.0%    10  153.0 153.2 153.0 154.0   0.0
     12.|-- pajbb001.int-gw.kddi.ne.jp              0.0%    10  151.2 153.2 151.2 171.1   6.3
     13.|-- otejbb205.int-gw.kddi.ne.jp             0.0%    10  254.7 260.4 254.7 271.5   6.3
     14.|-- cm-fcu204.kddnet.ad.jp                  0.0%    10  254.9 260.0 254.9 265.9   4.6
     15.|-- 124.215.199.170                         0.0%    10  256.0 256.0 255.9 256.2   0.0
     16.|-- speedtest.tokyo.linode.com              0.0%    10  254.0 254.2 254.0 255.0   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.sng01.softlayer.com
    Start: Mon Dec 12 23:32:19 2016
      1.|-- rbx1-3b-a9.fr.eu                       0.0%    10    1.5   4.1   1.5   6.6   1.4
      2.|-- be11-315.rbx-g1-a9.fr.eu               0.0%    10    0.3   0.3   0.3   0.4   0.0
      3.|-- 10.95.64.0                             0.0%    10    4.9   4.9   4.8   5.1   0.0
      4.|-- be100-1048.ams-1-a9.nl.eu              0.0%    10    5.9   5.8   5.6   6.0   0.0
      5.|-- bbr01.eq01.ams01.networklayer.com      0.0%    10    5.9   6.1   5.9   6.4   0.0
      6.|-- ae7.bbr02.eq01.ams02.networklayer.com  0.0%    10    6.4   6.5   6.2   7.0   0.0
      7.|-- ae0.bbr01.eq01.par02.networklayer.com  0.0%    10   18.7  18.6  18.3  19.0   0.0
      8.|-- ae0.bbr02.sr01.che01.networklayer.com  0.0%    10  156.1 156.3 156.1 158.1   0.6
      9.|-- ae7.bbr01.sr01.che01.networklayer.com  0.0%    10  146.6 146.5 146.4 146.7   0.0
     10.|-- ae1.bbr02.eq01.sng02.networklayer.com  0.0%    10  238.9 238.9 238.6 239.5   0.0
     11.|-- ae6.dar01.sr03.sng01.networklayer.com  0.0%    10  194.3 194.3 194.2 194.5   0.0
     12.|-- ???                                   100.0    10    0.0   0.0   0.0   0.0   0.0
     13.|-- speedtest.sng01.softlayer.com          0.0%    10  195.0 194.8 194.7 195.0   0.0
    mtr --report -w 200 --report-cycles=10 speedtest.london.linode.com
    Start: Mon Dec 12 23:32:34 2016
      1.|-- rbx1-3b-a9.fr.eu             0.0%    10    0.9   3.6   0.9   5.2   1.2
      5.|-- 80.249.212.136               0.0%    10    8.9   9.1   8.7  10.2   0.5
      6.|-- gw-h10.linode.com            0.0%    10    9.5   9.0   8.7   9.5   0.0
      7.|-- speedtest.london.linode.com  0.0%    10    8.5   8.6   8.5   8.8   0.0
    mtr --report -w 200 --report-cycles=10 mirror.i3d.net
    Start: Mon Dec 12 23:32:49 2016
      1.|-- rbx1-3b-a9.fr.eu                   0.0%    10    0.9   3.4   0.9  10.0   2.6
      3.|-- 10.95.64.0                         0.0%    10    4.9   4.9   4.8   5.0   0.0
      4.|-- be100-1048.ams-1-a9.nl.eu          0.0%    10    6.0   5.9   5.6   6.2   0.0
      5.|-- 100ge.ams-ix.i3d.net               0.0%    10   11.5  11.6  11.5  11.7   0.0
      6.|-- 60ge.cr0-ar0.smartdc.rtm.i3d.net   0.0%    10   11.6  12.9  11.5  16.5   1.9
      7.|-- 100ge.br3-cr0.smartdc.rtm.i3d.net  0.0%    10   17.7  25.2  12.7  81.7  20.3
      8.|-- hosted-by-i3d.net                  0.0%    10   11.5  11.6  11.5  11.7   0.0
    mtr --report -w 200 --report-cycles=10 syd-au-ping.vultr.com
    Start: Mon Dec 12 23:33:05 2016
      1.|-- rbx1-3b-a9.fr.eu                              0.0%    10    1.6   3.5   0.9  11.6   3.0
      2.|-- be11-146.rbx-g1-a9.fr.eu                      0.0%    10    0.3   0.3   0.2   0.4   0.0
      3.|-- 10.95.64.0                                    0.0%    10    5.0   5.0   4.8   5.1   0.0
      4.|-- be100-1041.ldn-1-a9.uk.eu                     0.0%    10    4.6   4.3   4.1   4.6   0.0
      5.|-- be100-1295.nwk-1-a9.nj.us                     0.0%    10   70.3  70.3  70.2  70.6   0.0
      6.|-- po11.lax-5-6k.ca.us                           0.0%    10  253.3 160.6 130.1 253.3  49.7
      7.|-- po5.lax-1-6k.ca.us                            0.0%    10  131.0 138.7 130.6 172.9  15.5
      8.|-- vocus-connect-pty.as4826.any2ix.coresite.com  0.0%    10  132.2 132.2 132.2 132.3   0.0
      9.|-- bundle-150.cor01.lax01.ca.vocus.net           0.0%    10  294.7 294.7 294.7 294.7   0.0
     10.|-- 100G-0-1-0-0.cor01.sjc01.ca.vocus.net         0.0%    10  295.8 295.8 295.7 296.2   0.0
     11.|-- ten-0-7-0-3.cor01.syd04.nsw.vocus.net.au      0.0%    10  294.9 294.9 294.8 294.9   0.0
     12.|-- bundle-101.bdr04.syd03.nsw.VOCUS.net.au       0.0%    10  368.8 316.1 295.8 368.8  28.3
     13.|-- ip-134.197.255.049.in-addr.VOCUS.net.au       0.0%    10  294.0 300.5 294.0 353.9  18.8
     14.|-- xe-1-0-1.gw102.sy3.ap.equinix.com             0.0%    10  294.6 294.5 294.0 297.8   1.0
     15.|-- 180.189.25.6                                  0.0%    10  295.2 295.5 294.3 305.2   3.4
     16.|-- vl901-ds1-b5-r1120.aus1.choopa.net            0.0%    10  294.6 295.4 294.5 303.2   2.6
     17.|-- ???                                          100.0    10    0.0   0.0   0.0   0.0   0.0
     18.|-- 108.61.212.117.vultr.com                      0.0%    10  294.3 294.4 294.3 294.5   0.0
    mtr --report -w 200 --report-cycles=10 hnd-jp-ping.vultr.com
    Start: Mon Dec 12 23:33:24 2016
      1.|-- rbx1-3b-a9.fr.eu                      0.0%    10    1.6   4.1   1.2   8.2   2.0
      2.|-- be11-315.rbx-g2-a9.fr.eu              0.0%    10    0.3   0.3   0.3   0.3   0.0
      3.|-- 10.95.64.2                            0.0%    10    4.7   4.7   4.5   5.0   0.0
      4.|-- be100-1042.ldn-5-a9.uk.eu             0.0%    10    4.3   4.3   4.1   4.4   0.0
      6.|-- ldn-bb3-link.telia.net                0.0%    10    4.0   4.2   3.9   6.1   0.7
      7.|-- ldn-b7-link.telia.net                 0.0%    10    4.0   4.0   4.0   4.1   0.0
      8.|-- ae-11.r02.londen03.uk.bb.gin.ntt.net  0.0%    10    4.5   4.5   4.4   4.6   0.0
      9.|-- ae-3.r24.londen12.uk.bb.gin.ntt.net   0.0%    10    4.4   4.4   4.3   4.5   0.0
     10.|-- ae-5.r24.nycmny01.us.bb.gin.ntt.net   0.0%    10   81.5  72.3  71.3  81.5   3.2
     11.|-- ae-2.r20.sttlwa01.us.bb.gin.ntt.net   0.0%    10  139.5 140.0 139.5 142.9   0.9
     12.|-- ae-23.r30.tokyjp05.jp.bb.gin.ntt.net  0.0%    10  227.9 228.5 227.7 230.0   0.6
     13.|-- ae-5.r02.tokyjp03.jp.bb.gin.ntt.net   0.0%    10  242.9 242.9 242.8 243.1   0.0
     14.|-- 117.103.177.122                      10.0%    10  234.3 232.7 232.0 235.5   1.1
     15.|-- vl516-ds1-b5-r2605.tyo1.choopa.net    0.0%    10  234.1 234.2 234.1 234.3   0.0
     16.|-- ???                                  100.0    10    0.0   0.0   0.0   0.0   0.0
     17.|-- 108.61.201.151.vultr.com              0.0%    10  225.1 225.1 225.0 225.2   0.0
    mtr --report -w 200 --report-cycles=10 lax-ca-us-ping.vultr.com
    Start: Mon Dec 12 23:33:40 2016
      1.|-- rbx1-3b-a9.fr.eu                                  0.0%    10    5.6   3.8   1.6   5.9   1.2
      4.|-- be100-1041.ldn-1-a9.uk.eu                         0.0%    10    4.1   4.3   4.1   4.5   0.0
      5.|-- be100-1295.nwk-1-a9.nj.us                         0.0%    10   70.4  70.4  70.3  70.7   0.0
      6.|-- po14.lax-5-6k.ca.us                               0.0%    10  130.1 130.1 130.0 130.2   0.0
      7.|-- po5.lax-1-6k.ca.us                                0.0%    10  130.8 133.3 130.5 157.0   8.3
      8.|-- clan-servers-hosting.as20473.any2ix.coresite.com  0.0%    10  139.9 134.6 131.7 142.0   4.1
      9.|-- vl901-ds1-b5-c705.lax3.choopa.net                10.0%    10  132.2 132.7 132.2 136.5   1.3
     10.|-- ???                                              100.0    10    0.0   0.0   0.0   0.0   0.0
     11.|-- 108.61.219.200.vultr.com                          0.0%    10  131.9 131.9 131.8 132.0   0.0
    mtr --report -w 200 --report-cycles=10 wa-us-ping.vultr.com
    Start: Mon Dec 12 23:33:56 2016
      1.|-- rbx1-3b-a9.fr.eu                       0.0%    10    4.2   3.4   0.9   7.3   1.9
      3.|-- 10.95.64.2                             0.0%    10    4.9   5.2   4.8   7.1   0.6
      4.|-- be99-1044.gsw-1-a9.fr.eu               0.0%    10    4.1   4.2   3.9   4.4   0.0
      6.|-- be3009.ccr42.par01.atlas.cogentco.com  0.0%    10    4.4   4.5   4.4   4.7   0.0
      7.|-- be2425.rcr21.par05.atlas.cogentco.com  0.0%    10    5.1   5.0   4.9   5.1   0.0
      8.|-- gttnet.par05.atlas.cogentco.com        0.0%    10    4.4   4.4   4.4   4.4   0.0
      9.|-- et-2-1-0.cr3-sea2.ip4.gtt.net          0.0%    10  143.7 143.6 143.6 143.7   0.0
     10.|-- choopa-gw.ip4.gtt.net                  0.0%    10  141.7 141.9 141.6 142.9   0.3
     11.|-- ???                                   100.0    10    0.0   0.0   0.0   0.0   0.0
     12.|-- 108.61.194.105.vultr.com               0.0%    10  141.9 141.9 141.8 142.2   0.0
    mtr --report -w 200 --report-cycles=10 tx-us-ping.vultr.com
    Start: Mon Dec 12 23:34:11 2016
      1.|-- rbx1-3b-a9.fr.eu                     0.0%    10    5.9   3.7   1.2   5.9   1.4
      3.|-- 10.95.64.0                           0.0%    10    4.9   5.1   4.9   5.6   0.0
      6.|-- ldn-bb2-link.telia.net               0.0%    10    4.0   4.0   4.0   4.1   0.0
      7.|-- nyk-bb4-link.telia.net               0.0%    10   72.7  73.0  72.6  73.6   0.0
      8.|-- dls-b21-link.telia.net               0.0%    10  117.2 117.3 117.1 117.8   0.0
      9.|-- dls-b22-link.telia.net               0.0%    10  117.8 117.7 117.3 118.2   0.0
     10.|-- vultr-ic-318447-dls-b22.c.telia.net  0.0%    10  117.5 118.0 117.5 118.6   0.0
     11.|-- vl902-ds1-b5-02.04.dal4.choopa.net   0.0%    10  118.2 119.1 118.0 123.3   1.4
     13.|-- 108.61.224.175.vultr.com             0.0%    10  119.0 118.7 118.3 119.0   0.0
    mtr --report -w 200 --report-cycles=10 il-us-ping.vultr.com
    Start: Mon Dec 12 23:34:27 2016
      1.|-- rbx1-3b-a9.fr.eu                     0.0%    10    3.5   3.8   1.0   7.3   1.8
      2.|-- be11-146.rbx-g1-a9.fr.eu             0.0%    10    0.4   0.3   0.2   0.4   0.0
      3.|-- 10.95.64.0                           0.0%    10    5.0   4.9   4.9   5.0   0.0
      4.|-- be100-1041.ldn-1-a9.uk.eu            0.0%    10    4.2   4.2   4.1   4.6   0.0
      6.|-- ldn-bb3-link.telia.net               0.0%    10    5.8   6.2   4.0  13.4   3.0
      7.|-- nyk-bb1-link.telia.net               0.0%    10   72.8  89.6  72.8 152.8  32.5
      8.|-- chi-b21-link.telia.net               0.0%    10   97.3  95.9  95.1  97.3   0.5
      9.|-- vultr-ic-318445-chi-b21.c.telia.net  0.0%    10   96.5 100.3  96.5 105.1   2.7
     11.|-- 107.191.51.12.vultr.com              0.0%    10   96.0  95.9  95.5  96.4   0.0
    mtr --report -w 200 --report-cycles=10 ga-us-ping.vultr.com
    Start: Mon Dec 12 23:34:42 2016
      1.|-- rbx1-3b-a9.fr.eu                     0.0%    10    3.4   3.6   2.1   5.7   0.9
      2.|-- be11-146.rbx-g2-a9.fr.eu             0.0%    10    0.4   0.3   0.3   0.4   0.0
      4.|-- be100-1042.ldn-5-a9.uk.eu            0.0%    10    4.1   4.3   4.1   4.5   0.0
      5.|-- be100-2.ldn-1-a9.uk.eu               0.0%    10    4.2   4.3   4.1   4.5   0.0
      7.|-- ldn-bb2-link.telia.net               0.0%    10    4.1  12.9   4.0  69.1  21.1
      8.|-- prs-bb2-link.telia.net               0.0%    10   14.6  65.2  14.6  79.4  26.7
      9.|-- atl-b21-link.telia.net               0.0%    10   84.0  88.0  80.0  93.7   4.8
     10.|-- atl-b21-link.telia.net               0.0%    10   87.4  90.7  87.3  95.4   2.4
     11.|-- vultr-ic-319646-atl-b21.c.telia.net  0.0%    10   90.5  91.7  88.9  96.3   2.1
     12.|-- vl901-ds1-b5-r7.atl2.choopa.net     80.0%    10   91.8  92.9  91.8  94.0   1.4
     13.|-- 108.61.193.166.vultr.com            10.0%    10   90.0  89.3  87.2  92.2   1.8
    mtr --report -w 200 --report-cycles=10 fl-us-ping.vultr.com
    Start: Mon Dec 12 23:34:58 2016
      1.|-- rbx1-3b-a9.fr.eu           0.0%    10    2.7   3.5   1.7   5.3   0.8
      4.|-- be100-1041.ldn-1-a9.uk.eu  0.0%    10    4.1   4.2   4.0   4.5   0.0
      6.|-- ldn-bb3-link.telia.net     0.0%    10    4.0   4.0   4.0   4.0   0.0
      7.|-- prs-bb3-link.telia.net     0.0%    10   83.6  84.1  83.6  85.7   0.6
      8.|-- prs-b2-link.telia.net      0.0%    10   14.9  14.6  14.2  15.7   0.3
      9.|-- prs-bb2-link.telia.net     0.0%    10   33.5  27.8  14.7  82.8  22.3
     10.|-- ash-bb4-link.telia.net     0.0%    10   83.8  87.9  83.1 117.0  10.3
     11.|-- ash-b1-link.telia.net      0.0%    10   84.1  85.0  84.1  86.5   0.7
     12.|-- 104.156.244.232           10.0%    10  114.0 114.9 112.1 117.1   1.5
    mtr --report -w 200 --report-cycles=10 nj-us-ping.vultr.com
    Start: Mon Dec 12 23:35:13 2016
      1.|-- rbx1-3b-a9.fr.eu                 0.0%    10    3.6   3.3   1.7   4.3   0.6
      2.|-- be11-146.rbx-g2-a9.fr.eu         0.0%    10    0.3   0.3   0.2   0.3   0.0
      4.|-- be100-1042.ldn-5-a9.uk.eu        0.0%    10    4.2   4.3   4.1   4.5   0.0
      5.|-- be100-1298.nwk-5-a9.nj.us        0.0%    10   72.3  72.0  71.8  72.3   0.0
      6.|-- po5.nwk-20-6k.nj.us             50.0%    10   72.7  84.1  72.6 114.3  18.2
      7.|-- po6.nyk-5-6k.ny.us               0.0%    10   71.5  75.0  71.4 101.4   9.4
      8.|-- nyiix.gi3-6.cr1.nyc1.choopa.net  0.0%    10   82.2  76.9  73.0  85.8   4.5
      9.|-- vl50-br1.pnj1.choopa.net         0.0%    10   72.1  74.9  72.1  81.2   3.4
     10.|-- vl139-c4-3-b5-2.pnj1.choopa.net  0.0%    10   74.2  74.6  74.2  75.6   0.0
     12.|-- 108.61.149.182.vultr.com         0.0%    10   72.2  72.2  72.1  72.3   0.0
    mtr --report -w 200 --report-cycles=10 fra-de-ping.vultr.com
    Start: Mon Dec 12 23:35:29 2016
      1.|-- rbx1-3b-a9.fr.eu                     0.0%    10    4.0   3.3   0.9   6.4   1.6
      4.|-- be100-1041.ldn-1-a9.uk.eu            0.0%    10    4.5   4.2   4.1   4.5   0.0
      7.|-- prs-bb3-link.telia.net               0.0%    10   13.8  13.8  13.7  14.0   0.0
      8.|-- ffm-bb3-link.telia.net               0.0%    10   13.8  13.9  13.8  14.3   0.0
      9.|-- ffm-b12-link.telia.net               0.0%    10   13.9  13.9  13.8  13.9   0.0
     10.|-- vultr-ic-312911-ffm-b12.c.telia.net  0.0%    10  105.2  23.6  13.9 105.2  28.7
     12.|-- 108.61.210.117.vultr.com             0.0%    10   13.9  13.9  13.9  14.1   0.0
    mtr --report -w 200 --report-cycles=10 ams-nl-ping.vultr.com
    Start: Mon Dec 12 23:35:44 2016
      1.|-- rbx1-3b-a9.fr.eu           0.0%    10    4.5   2.9   0.9   4.8   1.4
      2.|-- be11-315.rbx-g1-a9.fr.eu   0.0%    10    0.3   0.3   0.2   0.4   0.0
      4.|-- be100-1048.ams-1-a9.nl.eu  0.0%    10    5.7   5.8   5.6   6.1   0.0
      5.|-- 80.249.212.38              0.0%    10  208.7  88.3   6.2 345.8 119.0
      7.|-- 108.61.198.102.vultr.com   0.0%    10    6.1   6.1   6.0   6.2   0.0
    mtr --report -w 200 --report-cycles=10 lon-gb-ping.vultr.com
    Start: Mon Dec 12 23:35:59 2016
      1.|-- rbx1-3b-a9.fr.eu              0.0%    10    2.3   3.9   1.5   7.1   1.4
      2.|-- be11-315.rbx-g2-a9.fr.eu      0.0%    10    0.4   0.3   0.3   0.4   0.0
      4.|-- be100-1042.ldn-5-a9.uk.eu     0.0%    10    4.4   4.3   4.1   4.5   0.0
      5.|-- vl32-br1-cer.lon3.choopa.net  0.0%    10  102.1 287.2 102.1 721.4 182.1
      7.|-- 108.61.196.101.vultr.com      0.0%    10    4.3   4.3   4.2   4.5   0.0
    mtr --report -w 200 --report-cycles=10 par-fr-ping.vultr.com
    Start: Mon Dec 12 23:36:14 2016
      1.|-- rbx1-3b-a9.fr.eu                    0.0%    10    7.3   3.7   1.0   7.3   1.8
      2.|-- be11-146.rbx-g2-a9.fr.eu            0.0%    10    0.3   0.3   0.3   0.3   0.0
      4.|-- be100-1042.ldn-5-a9.uk.eu           0.0%    10    4.4   4.4   4.3   4.5   0.0
      5.|-- be100-2.ldn-1-a9.uk.eu              0.0%    10    4.2   4.2   4.1   4.7   0.0
      7.|-- ldn-bb3-link.telia.net              0.0%    10    4.0   4.2   4.0   5.6   0.3
      8.|-- prs-bb3-link.telia.net              0.0%    10   14.1  13.9  13.8  14.1   0.0
      9.|-- prs-b7-link.telia.net               0.0%    10   14.6  14.6  14.6  14.7   0.0
     10.|-- vultr-ic-312910-prs-b7.c.telia.net  0.0%    10   15.1  15.4  15.0  17.8   0.7
     12.|-- 108.61.209.127.vultr.com            0.0%    10   15.0  15.0  15.0  15.1   0.0
    mtr --report -w 200 --report-cycles=10 VersaWeb Las Vegas
    Start: Mon Dec 12 23:36:29 2016
      1.|-- rbx1-3b-a9.fr.eu                                 0.0%    10    4.6   3.6   0.9   5.7   1.8
      3.|-- 10.95.64.0                                       0.0%    10    4.8   5.0   4.8   5.4   0.0
      4.|-- be100-1041.ldn-1-a9.uk.eu                        0.0%    10    4.0   4.2   4.0   4.5   0.0
      5.|-- ge-3-3-0.mpr1.lhr3.uk.above.net                  0.0%    10    3.9   4.0   3.9   4.4   0.0
      6.|-- ae6.mpr3.lhr3.uk.zip.zayo.com                    0.0%    10    4.2   4.7   4.2   8.9   1.3
      7.|-- ae27.cs1.lhr15.uk.eth.zayo.com                   0.0%    10  131.6 131.7 131.6 132.5   0.0
      8.|-- ae0.cs1.lhr11.uk.eth.zayo.com                    0.0%    10  130.8 130.8 130.7 130.9   0.0
      9.|-- ae5.cs1.lga5.us.eth.zayo.com                     0.0%    10  131.0 136.2 131.0 177.4  14.5
     10.|-- ae3.cs1.ord2.us.eth.zayo.com                     0.0%    10  130.5 131.4 130.5 138.4   2.4
     11.|-- ae0.cs2.ord2.us.eth.zayo.com                     0.0%    10  131.1 133.4 131.1 139.5   3.5
     12.|-- ae5.cs2.den5.us.eth.zayo.com                     0.0%    10  130.8 130.9 130.8 131.0   0.0
     13.|-- 64.125.30.117                                    0.0%    10  109.7 109.9 109.6 111.7   0.5
     14.|-- ae8.mpr3.las1.us.zip.zayo.com                    0.0%    10  130.6 130.6 130.6 130.8   0.0
     15.|-- 64.124.179.234.IPYX-127309-003-ZYO.zip.zayo.com  0.0%    10  132.9 133.0 132.9 133.8   0.0
     16.|-- core1.las1.as53340.net                           0.0%    10  133.1 136.0 133.1 143.2   3.4
     17.|-- 192.228.109.86                                   0.0%    10  133.1 134.3 133.0 145.7   3.9
     18.|-- lg.las1.ultravps.net                             0.0%    10  133.9 133.9 133.9 134.0   0.0
    mtr --report -w 200 --report-cycles=10 VersaWeb Seattle
    Start: Mon Dec 12 23:36:47 2016
      1.|-- rbx1-3b-a9.fr.eu                 0.0%    10    3.3   3.7   2.5   5.7   0.7
      3.|-- 10.95.64.2                       0.0%    10   27.8   7.1   4.6  27.8   7.3
      4.|-- be100-1042.ldn-5-a9.uk.eu        0.0%    10    4.3   4.3   4.1   4.6   0.0
      5.|-- be100-2.ldn-1-a9.uk.eu           0.0%    10    4.2   4.2   4.1   4.5   0.0
      6.|-- ge-3-3-0.mpr1.lhr3.uk.above.net  0.0%    10    4.0   4.0   4.0   4.1   0.0
      7.|-- ae6.mpr3.lhr3.uk.zip.zayo.com    0.0%    10    4.2   4.3   4.2   4.4   0.0
      8.|-- ae27.cs1.lhr15.uk.eth.zayo.com   0.0%    10  131.1 138.7 131.1 175.6  16.3
      9.|-- ae0.cs1.lhr11.uk.eth.zayo.com    0.0%    10  130.5 132.6 130.5 138.4   2.8
     10.|-- ae5.cs1.lga5.us.eth.zayo.com     0.0%    10  130.4 134.3 130.2 170.7  12.8
     11.|-- ae3.cs1.ord2.us.eth.zayo.com     0.0%    10  130.0 133.5 130.0 163.8  10.6
     12.|-- ae2.cs1.sea1.us.eth.zayo.com     0.0%    10  130.2 131.7 130.2 144.5   4.5
     13.|-- ae27.mpr1.sea1.us.zip.zayo.com   0.0%    10  130.7 130.4 130.2 131.6   0.0
     14.|-- 216.200.123.154                  0.0%    10  145.5 145.4 145.0 147.1   0.5
     15.|-- 76.164.234.1                     0.0%    10  143.4 143.8 143.4 146.5   0.8
    mtr --report -w 200 --report-cycles=10 OVH Canada
    Start: Mon Dec 12 23:37:03 2016
      1.|-- rbx1-3b-a9.fr.eu             0.0%    10    2.7   4.1   2.7   5.7   0.7
      2.|-- be11-146.rbx-g2-a9.fr.eu     0.0%    10    0.3   0.3   0.3   0.4   0.0
      3.|-- vl1305.bhs-g2-a75-lo2.qc.ca  0.0%    10   80.3  80.3  80.2  80.3   0.0
      4.|-- be50-7.bhs-3a-a9.qc.ca      10.0%    10  331.9 344.8 325.9 380.5  19.9
      5.|-- bhs.proof.ovh.net            0.0%    10   80.3  80.4  80.3  80.5   0.0
    Check system entropy pool availability
    entropy_avail: 4067
    entropy_avail: 4067
    entropy_avail: 4067
    entropy_avail: 4067
    OpenSSL System Benchmark
    OpenSSL 1.0.1e-fips 11 Feb 2013
    openssl speed rsa4096 rsa2048 ecdsap256 sha256 sha1 md5 rc4 aes-256-cbc aes-128-cbc -multi 8
    built on: Sun Nov  6 03:45:24 UTC 2016
    options:bn(64,64) md2(int) rc4(16x,int) des(idx,cisc,16,int) aes(partial) idea(int) blowfish(idx)
    compiler: gcc -fPIC -DOPENSSL_PIC -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DKRB5_MIT -m64 -DL_ENDIAN -DTERMIO -Wall -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches   -m64 -mtune=generic -Wa,--noexecstack -DPURIFY -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DWHIRLPOOL_ASM -DGHASH_ASM
    md5             271441.95k   809739.05k  1875700.48k  2760608.77k  3202058.92k
    sha1            278140.75k   806981.93k  1738336.09k  2442428.76k  2768825.00k
    rc4            1393815.07k  2636680.66k  3377283.16k  3654612.99k  3811592.87k
    aes-128 cbc     466663.29k   492691.71k   510453.50k   509688.15k   509668.01k
    aes-256 cbc     341422.75k   356828.95k   363636.14k   364145.32k   365060.10k
    sha256          198598.17k   437167.55k   736941.74k   885556.57k   923451.39k
    rsa 2048 bits 0.000396s 0.000012s   2524.8  83225.9
    rsa 4096 bits 0.002957s 0.000046s    338.2  21957.0
     256 bit ecdsa (nistp256)   0.0000s   0.0001s  34447.8   8331.1
    openssl speed -evp aes256 -multi 8
    evp             999997.49k  1110157.89k  1147077.03k  1150451.37k  1149886.46k
    openssl speed -evp aes128 -multi 8
    evp            1333945.82k  1528347.61k  1587643.99k  1602812.93k  1593333.08k
    Centmin Mod Nginx static LibreSSL Benchmark
    ./centminmodbench.sh: line 672: version: command not found
    ./centminmodbench.sh: line 676: speed: command not found
    ./centminmodbench.sh: line 681: speed: command not found
    ./centminmodbench.sh: line 686: speed: command not found
    Running mysqlslap
    mysqlslap --auto-generate-sql --auto-generate-sql-add-autoincrement --auto-generate-sql-secondary-indexes=5 --number-int-cols=5 --number-char-cols=5 --number-of-queries=25000 --auto-generate-sql-unique-query-number=40 --auto-generate-sql-unique-write-number=40 --auto-generate-sql-write-number=1000 --concurrency=64 --iterations=10 --engine=myisam
    Benchmark
        Running for engine myisam
        Average number of seconds to run all queries: 1.534 seconds
        Minimum number of seconds to run all queries: 1.500 seconds
        Maximum number of seconds to run all queries: 1.566 seconds
        Number of clients running queries: 64
        Average number of queries per client: 390
    Dropping the database is potentially a very bad thing to do.
    Any data stored in the database will be destroyed.
    Do you really want to drop the 'test' database [y/N] Database "test" dropped
    System PHP Info
    CPU: 8 x Intel(R) Xeon(R) CPU E5504 @ 2.00GHz
    Mem:          16036        1116       13664          66        1255       14533
    Low:          16036        2372       13664
    Swap:          5118           0        5118
    PHP 5.6.29 (cli) (built: Dec 12 2016 12:24:24)
    Zend Engine v2.6.0, Copyright (c) 1998-2016 Zend Technologies
        with Zend OPcache v7.0.6-dev, Copyright (c) 1999-2016, by Zend Technologies
    /etc/centminmod/php.d/mailparse.ini,
    [PHP Modules]
    bcmath
    bz2
    calendar
    Core
    ctype
    curl
    date
    dom
    enchant
    ereg
    exif
    fileinfo
    filter
    ftp
    gd
    geoip
    gettext
    gmp
    hash
    iconv
    igbinary
    imagick
    imap
    intl
    json
    ldap
    libxml
    mailparse
    mbstring
    mcrypt
    memcache
    memcached
    mhash
    mysql
    mysqli
    mysqlnd
    openssl
    pcntl
    pcre
    PDO
    pdo_mysql
    pdo_sqlite
    Phar
    posix
    pspell
    readline
    redis
    Reflection
    session
    shmop
    SimpleXML
    snmp
    soap
    sockets
    SPL
    sqlite3
    standard
    sysvmsg
    sysvsem
    sysvshm
    tidy
    tokenizer
    xml
    xmlreader
    xmlrpc
    xmlwriter
    xsl
    Zend OPcache
    zip
    zlib
    [Zend Modules]
    Zend OPcache
    Run PHP test Zend/bench.php
    simple             0.179
    simplecall         0.164
    simpleucall        0.173
    simpleudcall       0.176
    mandel             0.440
    mandel2            0.644
    ackermann(7)       0.201
    ary(50000)         0.031
    ary2(50000)        0.029
    ary3(2000)         0.244
    fibo(30)           0.543
    hash1(50000)       0.052
    hash2(500)         0.048
    heapsort(20000)    0.132
    matrix(20)         0.132
    nestedloop(12)     0.297
    sieve(30)          0.147
    strcat(200000)     0.018
    Total              3.650
    real: 3.72s user: 3.67s sys: 0.04s cpu: 99% maxmem: 30876 KB cswaits: 2
    simple             0.179
    simplecall         0.164
    simpleucall        0.173
    simpleudcall       0.176
    mandel             0.440
    mandel2            0.643
    ackermann(7)       0.201
    ary(50000)         0.031
    ary2(50000)        0.029
    ary3(2000)         0.245
    fibo(30)           0.604
    hash1(50000)       0.052
    hash2(500)         0.048
    heapsort(20000)    0.133
    matrix(20)         0.131
    nestedloop(12)     0.296
    sieve(30)          0.146
    strcat(200000)     0.019
    Total              3.708
    real: 3.77s user: 3.73s sys: 0.04s cpu: 100% maxmem: 30880 KB cswaits: 1
    simple             0.179
    simplecall         0.167
    simpleucall        0.172
    simpleudcall       0.179
    mandel             0.440
    mandel2            0.649
    ackermann(7)       0.201
    ary(50000)         0.032
    ary2(50000)        0.030
    ary3(2000)         0.268
    fibo(30)           0.620
    hash1(50000)       0.052
    hash2(500)         0.048
    matrix(20)         0.132
    sieve(30)          0.146
    Total              3.764
    real: 3.83s user: 3.79s sys: 0.03s cpu: 99% maxmem: 30880 KB cswaits: 1
    bench.php results from 3 runs
    3.650
    3.708
    3.764
    bench.php avg: 3.7073
    Avg: real: 3.77s user: 3.73s sys: 0.04s cpu: 99.33% maxmem: 30878.67KB cswaits: 1.33
    created results log at /home/phpbench_logs/bench_121216-222826.log
    server PHP info log at /home/phpbench_logs/bench_phpinfo_121216-222826.log
    Run PHP test Zend/micro_bench.php
    empty_loop         0.281
    func()             0.543    0.262
    undef_func()       0.568    0.287
    int_func()         0.506    0.225
    $x = self::$x      0.584    0.303
    self::$x = 0       0.677    0.396
    isset(self::$x)    0.466    0.185
    empty(self::$x)    0.481    0.200
    $x = Foo::$x       0.456    0.175
    Foo::$x = 0        0.622    0.341
    isset(Foo::$x)     0.413    0.132
    empty(Foo::$x)     0.457    0.176
    self::f()          0.711    0.430
    Foo::f()           0.627    0.346
    $x = $this->x      0.463    0.182
    $this->x = 0       0.518    0.237
    $this->x += 2      0.459    0.178
    ++$this->x         0.411    0.130
    --$this->x         0.397    0.116
    $this->x++         0.425    0.144
    $this->x--         0.429    0.148
    isset($this->x)    0.402    0.121
    empty($this->x)    0.445    0.164
    $this->f()         0.729    0.448
    $x = Foo::TEST     0.459    0.178
    new Foo()          1.180    0.899
    $x = TEST          0.352    0.071
    $x = $_GET         0.466    0.185
    $x = $GLOBALS['v'] 0.595    0.314
    $x = $hash['v']    0.472    0.191
    $x = $str[0]       0.626    0.345
    $x = $a ?: null    0.427    0.146
    $x = $f ?: tmp     0.556    0.275
    $x = $f ? $f : $a  0.453    0.172
    $x = $f ? $f : tmp 0.557    0.276
    Total             18.214
    real: 18.27s user: 18.26s sys: 0.01s cpu: 99% maxmem: 18912 KB cswaits: 2
    empty_loop         0.247
    func()             0.573    0.326
    undef_func()       0.574    0.326
    int_func()         0.506    0.259
    $x = self::$x      0.585    0.337
    self::$x = 0       0.672    0.424
    isset(self::$x)    0.469    0.221
    empty(self::$x)    0.486    0.239
    $x = Foo::$x       0.459    0.212
    Foo::$x = 0        0.621    0.374
    isset(Foo::$x)     0.423    0.175
    empty(Foo::$x)     0.445    0.198
    self::f()          0.704    0.456
    Foo::f()           0.631    0.384
    $x = $this->x      0.466    0.219
    $this->x = 0       0.543    0.296
    $this->x += 2      0.473    0.226
    ++$this->x         0.382    0.135
    --$this->x         0.379    0.131
    $this->x++         0.443    0.195
    $this->x--         0.429    0.181
    isset($this->x)    0.421    0.174
    empty($this->x)    0.448    0.201
    $this->f()         0.712    0.465
    $x = Foo::TEST     0.464    0.217
    new Foo()          1.155    0.908
    $x = TEST          0.359    0.111
    $x = $_GET         0.464    0.217
    $x = $GLOBALS['v'] 0.610    0.363
    $x = $hash['v']    0.494    0.247
    $x = $str[0]       0.624    0.377
    $x = $a ?: null    0.432    0.185
    $x = $f ?: tmp     0.572    0.324
    $x = $f ? $f : $a  0.469    0.222
    $x = $f ? $f : tmp 0.576    0.329
    Total             18.309
    real: 18.37s user: 18.35s sys: 0.02s cpu: 99% maxmem: 18912 KB cswaits: 1
    empty_loop         0.254
    func()             0.571    0.317
    undef_func()       0.567    0.314
    int_func()         0.506    0.252
    $x = self::$x      0.585    0.331
    self::$x = 0       0.675    0.421
    isset(self::$x)    0.475    0.222
    empty(self::$x)    0.470    0.216
    $x = Foo::$x       0.456    0.202
    Foo::$x = 0        0.623    0.369
    isset(Foo::$x)     0.419    0.165
    empty(Foo::$x)     0.448    0.194
    self::f()          0.700    0.446
    Foo::f()           0.636    0.383
    $x = $this->x      0.466    0.213
    $this->x = 0       0.543    0.290
    $this->x += 2      0.472    0.219
    ++$this->x         0.402    0.148
    --$this->x         0.403    0.150
    $this->x++         0.452    0.198
    $this->x--         0.444    0.190
    isset($this->x)    0.425    0.171
    empty($this->x)    0.442    0.188
    $this->f()         0.716    0.462
    $x = Foo::TEST     0.455    0.202
    new Foo()          1.133    0.879
    $x = TEST          0.371    0.117
    $x = $_GET         0.474    0.220
    $x = $GLOBALS['v'] 0.598    0.344
    $x = $hash['v']    0.483    0.229
    $x = $str[0]       0.614    0.361
    $x = $a ?: null    0.432    0.178
    $x = $f ?: tmp     0.569    0.315
    $x = $f ? $f : $a  0.467    0.213
    $x = $f ? $f : tmp 0.566    0.312
    Total             18.311
    real: 18.37s user: 18.35s sys: 0.01s cpu: 99% maxmem: 18912 KB cswaits: 1
    micro_bench.php results from 3 runs
    18.214
    18.309
    18.311
    micro_bench.php avg: 18.2780
    Avg: real: 18.34s user: 18.32s sys: 0.01s cpu: 99.00% maxmem: 18912.00KB cswaits: 1.33
    created results log at /home/phpbench_logs/bench_micro_121216-222826.log
    Building UnixBench
    Download UnixBench-5.1.3.tar.gz ...
    2016-12-12 23:43:33 URL:https://codeload.github.com/kdlucas/byte-unixbench/tar.gz/v5.1.3 [145908/145908] -> "UnixBench-5.1.3.tar.gz" [1]
    Download done.
    UnixBench-5.1.3.tar.gz valid file.
    2016-12-12 23:43:33 URL:https://gist.githubusercontent.com/centminmod/7bea01c6698377d1345a/raw/unixbench.patch [1306/1306] -> "unixbench.patch" [1]
    gcc -o ./pgms/arithoh -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Darithoh ./src/arith.c
    gcc -o ./pgms/register -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum='register int' ./src/arith.c
    gcc -o ./pgms/short -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=short ./src/arith.c
    Checking distribution of files
    gcc -o ./pgms/int -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=int ./src/arith.c
    gcc -o ./pgms/long -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=long ./src/arith.c
    gcc -o ./pgms/float -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=float ./src/arith.c
    ./pgms  exists
    gcc -o ./pgms/double -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=double ./src/arith.c
    ./src  exists
    ./testdir  exists
    gcc -o ./pgms/hanoi -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/hanoi.c
    gcc -o ./pgms/syscall -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/syscall.c
    gcc -o ./pgms/context1 -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/context1.c
    gcc -o ./pgms/pipe -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/pipe.c
    gcc -o ./pgms/spawn -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/spawn.c
    gcc -o ./pgms/execl -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/execl.c
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_1.c
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DREG=register -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_1.c -o dhry_1_reg.o
    gcc -o ./pgms/looper -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/looper.c
    ./src/syscall.c: In function ‘main’:
    ./src/syscall.c:93:21: warning: null argument where non-null required (argument 2) [-Wnonnull]
                         execl("/bin/true", (char *) 0);
    In file included from ./src/execl.c:34:0:
    ./src/big.c: In function ‘getwork’:
    ./src/big.c:452:11: warning: variable ‘c’ set but not used [-Wunused-but-set-variable]
         char  c;
    gcc -o ./pgms/fstime -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/fstime.c
    gcc -o ./pgms/whetstone-double -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -DDP -DUNIX -DUNIXBENCH ./src/whets.c -lm
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_2.c
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DREG=register -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_2.c -o dhry_2_reg.o
    gcc -o ./pgms/dhry2 -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/dhry_1.o ./src/dhry_2.o
    gcc -o ./pgms/dhry2reg -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/dhry_1_reg.o ./src/dhry_2_reg.o
    cd ./src; rm -f dhry_1.o dhry_2.o
    cd ./src; rm -f dhry_1_reg.o dhry_2_reg.o
    patching file Run
    Hunk #1 succeeded at 106 (offset 1 line).
    Hunk #2 succeeded at 1329 (offset 1 line).
    Running UnixBench
    make all
    make[1]: Entering directory `/home/centminmodbench/byte-unixbench-5.1.3/UnixBench'
    ./pgms  exists
    ./src  exists
    ./testdir  exists
    ./tmp  exists
    ./results  exists
    make[1]: Leaving directory `/home/centminmodbench/byte-unixbench-5.1.3/UnixBench'
    sh: 3dinfo: command not found
       Version 5.1.3                      Based on the Byte Magazine Unix Benchmark
       Multi-CPU version                  Version 5 revisions by Ian Smith,
                                          Sunnyvale, CA, USA
       January 13, 2011                   johantheghost at yahoo period com
    1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
    1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
    1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
    1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
    1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
    1 x Process Creation  1 2 3
    1 x Execl Throughput  1 2 3
    1 x Shell Scripts (1 concurrent)  1 2 3
    1 x Shell Scripts (8 concurrent)  1 2 3
    1 x Shell Scripts (16 concurrent)  1 2 3
    8 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
    8 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
    8 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
    8 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
    8 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
    8 x Process Creation  1 2 3
    8 x Execl Throughput  1 2 3
    8 x Shell Scripts (1 concurrent)  1 2 3
    8 x Shell Scripts (8 concurrent)  1 2 3
    8 x Shell Scripts (16 concurrent)  1 2 3
       BYTE UNIX Benchmarks (Version 5.1.3)
       System: hostname: GNU/Linux
       OS: GNU/Linux -- 3.10.0-514.2.2.el7.x86_64 -- #1 SMP Tue Dec 6 23:06:41 UTC 2016
       Machine: x86_64 (x86_64)
       Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
       CPU 0: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (4000.1 bogomips)
              Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
       CPU 1: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (4000.1 bogomips)
       CPU 2: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (4000.1 bogomips)
       CPU 3: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (4000.1 bogomips)
       CPU 4: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (3999.4 bogomips)
       CPU 5: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (3999.4 bogomips)
       CPU 6: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (3999.4 bogomips)
       CPU 7: Intel(R) Xeon(R) CPU E5504 @ 2.00GHz (3999.4 bogomips)
       23:43:33 up  1:26,  1 user,  load average: 1.20, 2.49, 3.25; runlevel 3
    Benchmark Run: Mon Dec 12 2016 23:43:33 - 00:07:58
    8 CPUs in system; running 1 parallel copy of tests
    Dhrystone 2 using register variables       21304297.2 lps   (10.0 s, 7 samples)
    Double-Precision Whetstone                     2590.5 MWIPS (10.0 s, 7 samples)
    Execl Throughput                               2007.0 lps   (29.9 s, 2 samples)
    Pipe Throughput                              990806.3 lps   (10.0 s, 7 samples)
    Pipe-based Context Switching                 173293.3 lps   (10.0 s, 7 samples)
    Process Creation                               4281.2 lps   (30.0 s, 2 samples)
    Shell Scripts (1 concurrent)                   4265.2 lpm   (60.0 s, 2 samples)
    Shell Scripts (16 concurrent)                  1360.1 lpm   (60.0 s, 2 samples)
    Shell Scripts (8 concurrent)                   2268.5 lpm   (60.0 s, 2 samples)
    System Call Overhead                        1342624.7 lps   (10.0 s, 7 samples)
    System Benchmarks Partial Index              BASELINE       RESULT    INDEX
    Dhrystone 2 using register variables         116700.0   21304297.2   1825.6
    Double-Precision Whetstone                       55.0       2590.5    471.0
    Execl Throughput                                 43.0       2007.0    466.8
    Pipe Throughput                               12440.0     990806.3    796.5
    Pipe-based Context Switching                   4000.0     173293.3    433.2
    Process Creation                                126.0       4281.2    339.8
    Shell Scripts (1 concurrent)                     42.4       4265.2   1005.9
    Shell Scripts (16 concurrent)                     ---       1360.1      ---
    Shell Scripts (8 concurrent)                      6.0       2268.5   3780.8
    System Call Overhead                          15000.0    1342624.7    895.1
    System Benchmarks Index Score (Partial Only)                          815.9
    Benchmark Run: Tue Dec 13 2016 00:07:58 - 00:32:32
    8 CPUs in system; running 8 parallel copies of tests
    Dhrystone 2 using register variables      163981829.7 lps   (10.0 s, 7 samples)
    Double-Precision Whetstone                    20708.8 MWIPS (10.0 s, 7 samples)
    Execl Throughput                              13601.0 lps   (29.8 s, 2 samples)
    Pipe Throughput                             7890673.8 lps   (10.0 s, 7 samples)
    Pipe-based Context Switching                1712501.2 lps   (10.0 s, 7 samples)
    Process Creation                              49640.9 lps   (30.0 s, 2 samples)
    Shell Scripts (1 concurrent)                  24628.3 lpm   (60.0 s, 2 samples)
    Shell Scripts (16 concurrent)                  1742.6 lpm   (60.1 s, 2 samples)
    Shell Scripts (8 concurrent)                   3478.1 lpm   (60.1 s, 2 samples)
    System Call Overhead                        4119002.6 lps   (10.0 s, 7 samples)
    Dhrystone 2 using register variables         116700.0  163981829.7  14051.6
    Double-Precision Whetstone                       55.0      20708.8   3765.2
    Execl Throughput                                 43.0      13601.0   3163.0
    Pipe Throughput                               12440.0    7890673.8   6343.0
    Pipe-based Context Switching                   4000.0    1712501.2   4281.3
    Process Creation                                126.0      49640.9   3939.8
    Shell Scripts (1 concurrent)                     42.4      24628.3   5808.6
    Shell Scripts (16 concurrent)                     ---       1742.6      ---
    Shell Scripts (8 concurrent)                      6.0       3478.1   5796.8
    System Call Overhead                          15000.0    4119002.6   2746.0
    System Benchmarks Index Score (Partial Only)                         4909.0
    centminmodbench.sh completed
    centminmodbench.sh Total Run Time: 7420.727334570 seconds
    [/CODE]
    11:27 PM
    Nice and slow 100Mbps ! :)
    thanks for sharing :)
  5. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    3:27 PM
    Ya, believe it or not i'm still running 5Mbps internet at home in Canada, and I'm sure the national average for non-businesses is fairly low as well
    11:27 PM
    Well 5Mbps is the international average broadband speed right now :)
  7. SFLC
    SFLC Active Member
    223
    59
    The Canadas
    3:27 PM
    Assuming you isolate developed countries it all comes down to the price, I pay 30 CAD per month for 5Mbps and my neighbour who has 50Mbps pays 175 CAD, since I don't do much up/downloading there's no point in upgrading.
    11:27 PM
  9. Ariq Naufal
    Ariq Naufal New Member
    8:27 PM
    1.14.0
    Hello, i want to review my KS-9 Server - Intel W3520 - 16GB DDR3 ECC 1333 MHz - 2x240GB SSD (raid1)
    with centminmodbench.sh
    centminmodbench.sh 0.9.7
    http://bench.centminmod.com
    written by: George Liu (eva2000)
    http://centminmod.com
    System Information
    4.9.142-xxxx-std-ipv6-64
    CentOS Linux release 7.6.1810 (Core)
    Architecture:          x86_64
    CPU(s):                8
    On-line CPU(s) list:   0-7
    Thread(s) per core:    2
    Core(s) per socket:    4
    Socket(s):             1
    NUMA node(s):          1
    CPU family:            6
    Model:                 26
    Model name:            Intel(R) Xeon(R) CPU           W3530  @ 2.80GHz
    Stepping:              5
    CPU MHz:               1600.000
    CPU max MHz:           2800.0000
    CPU min MHz:           1600.0000
    BogoMIPS:              5600.02
    Virtualization:        VT-x
    L1d cache:             32K
    L1i cache:             32K
    L2 cache:              256K
    L3 cache:              8192K
    NUMA node0 CPU(s):     0-7
    Flags:                 fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm dca sse4_1 sse4_2 popcnt lahf_lm ssbd ibrs ibpb stibp kaiser tpr_shadow vnmi flexpriority ept vpid dtherm ida flush_l1d
    CPU Flags
    CPU NODE SOCKET CORE L1d:L1i:L2:L3 ONLINE MAXMHZ    MINMHZ
    0   0    0      0    0:0:0:0       yes    2800.0000 1600.0000
    1   0    0      1    1:1:1:0       yes    2800.0000 1600.0000
    2   0    0      2    2:2:2:0       yes    2800.0000 1600.0000
    3   0    0      3    3:3:3:0       yes    2800.0000 1600.0000
    4   0    0      0    0:0:0:0       yes    2800.0000 1600.0000
    5   0    0      1    1:1:1:0       yes    2800.0000 1600.0000
    6   0    0      2    2:2:2:0       yes    2800.0000 1600.0000
    7   0    0      3    3:3:3:0       yes    2800.0000 1600.0000
    Mem:          16093         137       14924           9        1031       15618
    Low:          16093        1169       14924
    Swap:          1021           0        1021
    devtmpfs        7.9G     0  7.9G   0% /dev
    tmpfs           7.9G     0  7.9G   0% /dev/shm
    tmpfs           7.9G   10M  7.9G   1% /run
    tmpfs           7.9G     0  7.9G   0% /sys/fs/cgroup
    /dev/md1         20G  1.4G   17G   8% /
    /dev/md2        201G   60M  190G   1% /home
    tmpfs           1.6G     0  1.6G   0% /run/user/0
    disk ioping tests
    2018-12-05 08:49:26 URL:https://storage.googleapis.com/google-code-archive-downloads/v2/code.google.com/ioping/ioping-0.8.tar.gz [10590/10590] -> "ioping-0.8.tar.gz" [1]
    Download done.
    ioping-0.8.tar.gz valid file.
    Running IOPing I/O benchmark...
    cc -std=gnu99 -g -Wall -Wextra -pedantic -DVERSION=\"0.8\" -c -o ioping.o ioping.c
    cc -o ioping ioping.o -std=gnu99 -g -Wall -Wextra -pedantic  -lm
    IOPing I/O: ./ioping -c 10 .
    4.0 KiB from . (ext4 /dev/md2): request=1 time=87 us
    4.0 KiB from . (ext4 /dev/md2): request=2 time=185 us
    4.0 KiB from . (ext4 /dev/md2): request=3 time=185 us
    4.0 KiB from . (ext4 /dev/md2): request=4 time=147 us
    4.0 KiB from . (ext4 /dev/md2): request=5 time=147 us
    4.0 KiB from . (ext4 /dev/md2): request=6 time=239 us
    4.0 KiB from . (ext4 /dev/md2): request=7 time=235 us
    4.0 KiB from . (ext4 /dev/md2): request=8 time=236 us
    4.0 KiB from . (ext4 /dev/md2): request=9 time=257 us
    4.0 KiB from . (ext4 /dev/md2): request=10 time=255 us
    --- . (ext4 /dev/md2) ioping statistics ---
    10 requests completed in 9.0 s, 5.1 k iops, 19.8 MiB/s
    min/avg/max/mdev = 87 us / 197 us / 257 us / 53 us
    IOPing seek rate: ./ioping -RD .
    20.0 k requests completed in 3.0 s, 6.8 k iops, 26.6 MiB/s
    min/avg/max/mdev = 73 us / 146 us / 303 us / 26 us
    IOPing sequential: ./ioping -RL .
    1.9 k requests completed in 3.0 s, 641 iops, 160.4 MiB/s
    min/avg/max/mdev = 1.1 ms / 1.6 ms / 130.0 ms / 3.6 ms
    IOPing cached: ./ioping -RC .
    2.0 M requests completed in 3.0 s, 723.6 k iops, 2.8 GiB/s
    min/avg/max/mdev = 0 us / 1 us / 233 us / 0 us
    disk DD tests
    dd if=/dev/zero of=sb-io-test bs=1M count=1k conv=fdatasync
    1024+0 records in
    1024+0 records out
    1073741824 bytes (1.1 GB) copied, 5.15034 s, 208 MB/s
    dd if=/dev/zero of=sb-io-test bs=64k count=16k conv=fdatasync
    16384+0 records in
    16384+0 records out
    1073741824 bytes (1.1 GB) copied, 5.0443 s, 213 MB/s
    dd if=/dev/zero of=sb-io-test bs=1M count=1k oflag=dsync
    1024+0 records in
    1024+0 records out
    1073741824 bytes (1.1 GB) copied, 6.06523 s, 177 MB/s
    dd if=/dev/zero of=sb-io-test bs=64k count=16k oflag=dsync
    16384+0 records in
    16384+0 records out
    1073741824 bytes (1.1 GB) copied, 14.9571 s, 71.8 MB/s
    disk FIO tests
    2018-12-05 08:50:19 URL:https://raw.githubusercontent.com/Crowd9/Benchmark/master/fio-2.0.9.tar.gz [275092/275092] -> "fio-2.0.9.tar.gz" [1]
    Download done.
    fio-2.0.9.tar.gz valid file.
    Running FIO benchmark...
    FIO_VERSION = fio-2.0.9
        DEP .depend
        CC gettime.o
        CC fio.o
        CC ioengines.o
        CC init.o
        CC stat.o
        CC log.o
        CC time.o
        CC filesetup.o
        CC eta.o
        CC verify.o
        CC memory.o
        CC io_u.o
        CC parse.o
        CC mutex.o
        CC options.o
        CC rbtree.o
        CC smalloc.o
        CC filehash.o
        CC profile.o
        CC debug.o
        CC lib/rand.o
        CC lib/num2str.o
        CC lib/ieee754.o
        CC crc/crc16.o
        CC crc/sha512.o
        CC crc/crc7.o
        CC crc/sha1.o
        CC crc/crc32c.o
        CC crc/crc32.o
        CC crc/crc32c-intel.o
        CC crc/sha256.o
        CC crc/md5.o
        CC crc/crc64.o
        CC engines/cpu.o
        CC engines/mmap.o
        CC engines/sync.o
        CC engines/null.o
        CC engines/net.o
        CC memalign.o
        CC server.o
        CC client.o
        CC iolog.o
        CC backend.o
        CC libfio.o
        CC flow.o
        CC diskutil.o
        CC fifo.o
        CC blktrace.o
        CC helpers.o
        CC cgroup.o
        CC trim.o
        CC engines/libaio.o
        CC engines/posixaio.o
        CC engines/sg.o
        CC engines/splice.o
        CC engines/syslet-rw.o
        CC engines/guasi.o
        CC engines/binject.o
        CC engines/rdma.o
        CC profiles/tiobench.o
        CC fio
    FIO random reads:
    randomreads: (g=0): rw=randread, bs=4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.0.9
    Starting 1 process
    randomreads: Laying out IO file(s) (1 file(s) / 1024MB)
    randomreads: (groupid=0, jobs=1): err= 0: pid=6018: Wed Dec  5 08:50:32 2018
      read : io=1024.3MB, bw=273989KB/s, iops=68497 , runt=  3828msec
      cpu          : usr=15.57%, sys=84.24%, ctx=339, majf=0, minf=70
      IO depths    : 1=0.1%, 2=0.1%, 4=0.1%, 8=0.1%, 16=0.1%, 32=0.1%, >=64=100.0%
         submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
         complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%
         issued    : total=r=262207/w=0/d=0, short=r=0/w=0/d=0
    Run status group 0 (all jobs):
       READ: io=1024.3MB, aggrb=273988KB/s, minb=273988KB/s, maxb=273988KB/s, mint=3828msec, maxt=3828msec
    Disk stats (read/write):
        md2: ios=254334/0, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=131103/3, aggrmerge=0/0, aggrticks=21820/0, aggrin_queue=21816, aggrutil=96.45%
      sdb: ios=126842/3, merge=0/0, ticks=20956/0, in_queue=20972, util=96.45%
      sda: ios=135365/3, merge=0/0, ticks=22684/0, in_queue=22660, util=96.35%
    FIO random writes:
    randomwrites: (g=0): rw=randwrite, bs=4K-4K/4K-4K, ioengine=libaio, iodepth=64
    fio-2.0.9
    Starting 1 process
    randomwrites: (groupid=0, jobs=1): err= 0: pid=6022: Wed Dec  5 08:50:38 2018
      write: io=1024.3MB, bw=166692KB/s, iops=41673 , runt=  6292msec
      cpu          : usr=8.20%, sys=90.22%, ctx=2132, majf=0, minf=7
         issued    : total=r=0/w=262207/d=0, short=r=0/w=0/d=0
      WRITE: io=1024.3MB, aggrb=166692KB/s, minb=166692KB/s, maxb=166692KB/s, mint=6292msec, maxt=6292msec
        md2: ios=0/256184, merge=0/0, ticks=0/0, in_queue=0, util=0.00%, aggrios=0/262214, aggrmerge=0/5, aggrticks=0/27544, aggrin_queue=27506, aggrutil=97.70%
      sdb: ios=0/262214, merge=0/5, ticks=0/29280, in_queue=29268, util=97.70%
      sda: ios=0/262214, merge=0/5, ticks=0/25808, in_queue=25744, util=97.70%
    ramdisk DD tests - memory bandwidth
    dd if=/dev/zero of=sb-io-test bs=128k count=1k conv=fdatasync
    1024+0 records in
    1024+0 records out
    134217728 bytes (134 MB) copied, 0.0790473 s, 1.7 GB/s
    dd if=/dev/zero of=sb-io-test bs=8k count=16k conv=fdatasync
    16384+0 records in
    16384+0 records out
    134217728 bytes (134 MB) copied, 0.120048 s, 1.1 GB/s
    dd if=/dev/zero of=sb-io-test bs=128k count=1k oflag=dsync
    1024+0 records in
    1024+0 records out
    134217728 bytes (134 MB) copied, 0.060402 s, 2.2 GB/s
    dd if=/dev/zero of=sb-io-test bs=8k count=16k oflag=dsync
    16384+0 records in
    16384+0 records out
    134217728 bytes (134 MB) copied, 0.0890499 s, 1.5 GB/s
    ramdisk ioping tests - memory bandwidth
    2018-12-05 08:50:39 URL:https://storage.googleapis.com/google-code-archive-downloads/v2/code.google.com/ioping/ioping-0.8.tar.gz [10590/10590] -> "ioping-0.8.tar.gz" [1]
    Download done.
    Running IOPing I/O ramdisk benchmark...
    4.0 KiB from . (tmpfs tmpfs): request=1 time=4 us
    4.0 KiB from . (tmpfs tmpfs): request=2 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=3 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=4 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=5 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=6 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=7 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=8 time=4 us
    4.0 KiB from . (tmpfs tmpfs): request=9 time=5 us
    4.0 KiB from . (tmpfs tmpfs): request=10 time=5 us
    --- . (tmpfs tmpfs) ioping statistics ---
    10 requests completed in 9.0 s, 208.3 k iops, 813.8 MiB/s
    min/avg/max/mdev = 4 us / 4 us / 5 us / 0 us
    IOPing seek rate: ./ioping -R .
    977.4 k requests completed in 3.0 s, 720.4 k iops, 2.7 GiB/s
    min/avg/max/mdev = 1 us / 1 us / 72 us / 0 us
    40.3 k requests completed in 3.0 s, 20.8 k iops, 5.1 GiB/s
    min/avg/max/mdev = 44 us / 48 us / 135 us / 4 us
    2.0 M requests completed in 3.0 s, 709.3 k iops, 2.7 GiB/s
    min/avg/max/mdev = 1 us / 1 us / 82 us / 0 us
    Running bandwidth benchmark...
    Download from Cachefly (http://cachefly.cachefly.net/100mb.test)
    Download Cachefly: 11.2MB/s
    USA bandwidth tests...
    Download from Linode, Atlanta, GA, USA (http://speedtest.atlanta.linode.com/100MB-atlanta.bin)
    Download Linode, Atlanta, GA, USA: 10.5MB/s
    Download from Linode, Dallas, TX, USA (http://speedtest.dallas.linode.com/100MB-dallas.bin)
    Download Linode, Dallas, TX, USA: 10.2MB/s
    Download from Leaseweb, Manassas, VA, USA (http://mirror.us.leaseweb.net/speedtest/100mb.bin)
    Download Leaseweb, Manassas, VA, USA: 10.6MB/s
    Download from Softlayer, Seattle, WA, USA (http://speedtest.sea01.softlayer.com/downloads/test100.zip)
    Download Softlayer, Seattle, WA, USA: 9.16MB/s
    Download from Softlayer, San Jose, CA, USA (http://speedtest.sjc01.softlayer.com/downloads/test100.zip)
    Download Softlayer, San Jose, CA, USA: 9.43MB/s
    Download from Softlayer, Washington, DC, USA (http://speedtest.wdc01.softlayer.com/downloads/test100.zip)
    Download Softlayer, Washington, DC, USA: 8.94MB/s
    Download from VersaWeb, Las Vegas, Nevada (http://lg.las1.as53340.net/100MB.test)
    Download VersaWeb, Las Vegas, Nevada: 2.47MB/s
    Download from OVH, BHS, Canada (http://bhs.proof.ovh.net/files/100Mio.dat)
    Download OVH, BHS, Canada: 10.4MB/s
    Download from Vultr, Los Angeles, California (http://lax-ca-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Los Angeles, California: 9.74MB/s
    Download from Vultr, Seattle, Washington (http://wa-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Seattle, Washington: 9.48MB/s
    Download from Vultr, Dallas, Texas (http://tx-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Dallas, Texas: 10.1MB/s
    Download from Vultr, Chicago, Illinois (http://il-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Chicago, Illinois: 9.91MB/s
    Download from Vultr, Atlanta, Georgia (http://ga-us-ping.vultr.com/vultr.com.100MB.bin)
    Download Vultr, Atlanta, Georgia: 10.0MB/s
    Download Vultr, Miami, Florida: 10.2MB/s
    Download Vultr, New York / New Jersey: 10.7MB/s
    Asia bandwidth tests...
    Download Linode, Tokyo, JP: 5.09MB/s
    Download Softlayer, Singapore: 8.66MB/s
    Download Vultr, Tokyo, Japan: 9.26MB/s
    Europe bandwidth tests...
    Download Linode, London, UK: 11.2MB/s
    Download OVH, Paris, France: 11.2MB/s
    Download SmartDC, Rotterdam, Netherlands: 11.2MB/s
    Download Vultr, Amsterdam, Netherlands: 11.2MB/s
    Download Vultr, London, UK: 11.2MB/s
    Download Vultr, Paris, France: 11.2MB/s
    Australia bandwidth tests...
    Download Vultr, Sydney, Australia: 7.04MB/s
    PING cachefly.cachefly.net (205.234.175.175) 56(84) bytes of data.
    64 bytes from vip1.G-anycast1.cachefly.net (205.234.175.175): icmp_seq=1 ttl=59 time=6.14 ms
    64 bytes from vip1.G-anycast1.cachefly.net (205.234.175.175): icmp_seq=2 ttl=59 time=6.14 ms
    64 bytes from vip1.G-anycast1.cachefly.net (205.234.175.175): icmp_seq=3 ttl=59 time=6.16 ms
    --- cachefly.cachefly.net ping statistics ---
    rtt min/avg/max/mdev = 6.141/6.152/6.168/0.011 ms
    64 bytes from 108.61.212.117.vultr.com (108.61.212.117): icmp_seq=1 ttl=45 time=275 ms
    64 bytes from 108.61.212.117.vultr.com (108.61.212.117): icmp_seq=2 ttl=45 time=275 ms
    64 bytes from 108.61.212.117.vultr.com (108.61.212.117): icmp_seq=3 ttl=45 time=275 ms
    rtt min/avg/max/mdev = 275.674/275.696/275.730/0.606 ms
    64 bytes from 108.61.201.151.vultr.com (108.61.201.151): icmp_seq=1 ttl=51 time=225 ms
    64 bytes from 108.61.201.151.vultr.com (108.61.201.151): icmp_seq=2 ttl=51 time=225 ms
    64 bytes from 108.61.201.151.vultr.com (108.61.201.151): icmp_seq=3 ttl=51 time=225 ms
    rtt min/avg/max/mdev = 225.010/225.045/225.091/0.033 ms
    64 bytes from 108.61.219.200.vultr.com (108.61.219.200): icmp_seq=1 ttl=53 time=131 ms
    64 bytes from 108.61.219.200.vultr.com (108.61.219.200): icmp_seq=2 ttl=53 time=132 ms
    64 bytes from 108.61.219.200.vultr.com (108.61.219.200): icmp_seq=3 ttl=53 time=131 ms
    rtt min/avg/max/mdev = 131.442/131.654/132.020/0.492 ms
    64 bytes from 108.61.194.105.vultr.com (108.61.194.105): icmp_seq=1 ttl=51 time=164 ms
    64 bytes from 108.61.194.105.vultr.com (108.61.194.105): icmp_seq=2 ttl=51 time=164 ms
    64 bytes from 108.61.194.105.vultr.com (108.61.194.105): icmp_seq=3 ttl=51 time=164 ms
    rtt min/avg/max/mdev = 164.974/164.980/164.984/0.004 ms
    64 bytes from 108.61.224.175.vultr.com (108.61.224.175): icmp_seq=1 ttl=50 time=108 ms
    64 bytes from 108.61.224.175.vultr.com (108.61.224.175): icmp_seq=2 ttl=50 time=108 ms
    64 bytes from 108.61.224.175.vultr.com (108.61.224.175): icmp_seq=3 ttl=50 time=108 ms
    rtt min/avg/max/mdev = 108.617/108.637/108.659/0.017 ms
    64 bytes from 107.191.51.12.vultr.com (107.191.51.12): icmp_seq=1 ttl=55 time=94.7 ms
    64 bytes from 107.191.51.12.vultr.com (107.191.51.12): icmp_seq=2 ttl=55 time=94.5 ms
    64 bytes from 107.191.51.12.vultr.com (107.191.51.12): icmp_seq=3 ttl=55 time=94.7 ms
    rtt min/avg/max/mdev = 94.580/94.707/94.793/0.091 ms
    64 bytes from 108.61.193.166.vultr.com (108.61.193.166): icmp_seq=1 ttl=53 time=91.7 ms
    64 bytes from 108.61.193.166.vultr.com (108.61.193.166): icmp_seq=2 ttl=53 time=91.6 ms
    64 bytes from 108.61.193.166.vultr.com (108.61.193.166): icmp_seq=3 ttl=53 time=91.7 ms
    3 packets transmitted, 3 received, 0% packet loss, time 2000ms
    rtt min/avg/max/mdev = 91.644/91.704/91.767/0.252 ms
    64 bytes from 104.156.244.232 (104.156.244.232): icmp_seq=1 ttl=53 time=104 ms
    64 bytes from 104.156.244.232 (104.156.244.232): icmp_seq=2 ttl=53 time=103 ms
    64 bytes from 104.156.244.232 (104.156.244.232): icmp_seq=3 ttl=53 time=104 ms
    rtt min/avg/max/mdev = 103.949/104.018/104.064/0.375 ms
    64 bytes from 108.61.149.182.vultr.com (108.61.149.182): icmp_seq=1 ttl=53 time=72.3 ms
    64 bytes from 108.61.149.182.vultr.com (108.61.149.182): icmp_seq=2 ttl=53 time=72.4 ms
    64 bytes from 108.61.149.182.vultr.com (108.61.149.182): icmp_seq=3 ttl=53 time=72.3 ms
    rtt min/avg/max/mdev = 72.351/72.386/72.429/0.222 ms
    64 bytes from 108.61.210.117.vultr.com (108.61.210.117): icmp_seq=1 ttl=53 time=16.8 ms
    64 bytes from 108.61.210.117.vultr.com (108.61.210.117): icmp_seq=2 ttl=53 time=16.7 ms
    64 bytes from 108.61.210.117.vultr.com (108.61.210.117): icmp_seq=3 ttl=53 time=16.8 ms
    3 packets transmitted, 3 received, 0% packet loss, time 2003ms
    rtt min/avg/max/mdev = 16.783/16.848/16.882/0.156 ms
    64 bytes from 108.61.198.102.vultr.com (108.61.198.102): icmp_seq=1 ttl=56 time=6.00 ms
    64 bytes from 108.61.198.102.vultr.com (108.61.198.102): icmp_seq=2 ttl=56 time=6.01 ms
    64 bytes from 108.61.198.102.vultr.com (108.61.198.102): icmp_seq=3 ttl=56 time=6.05 ms
    rtt min/avg/max/mdev = 6.001/6.023/6.053/0.067 ms
    64 bytes from 108.61.196.101.vultr.com (108.61.196.101): icmp_seq=1 ttl=56 time=4.47 ms
    64 bytes from 108.61.196.101.vultr.com (108.61.196.101): icmp_seq=2 ttl=56 time=4.56 ms
    64 bytes from 108.61.196.101.vultr.com (108.61.196.101): icmp_seq=3 ttl=56 time=4.43 ms
    rtt min/avg/max/mdev = 4.438/4.492/4.563/0.075 ms
    64 bytes from 108.61.209.127.vultr.com (108.61.209.127): icmp_seq=1 ttl=52 time=17.2 ms
    64 bytes from 108.61.209.127.vultr.com (108.61.209.127): icmp_seq=2 ttl=52 time=17.1 ms
    64 bytes from 108.61.209.127.vultr.com (108.61.209.127): icmp_seq=3 ttl=52 time=17.2 ms
    rtt min/avg/max/mdev = 17.132/17.224/17.293/0.067 ms
    From 192.228.109.50 icmp_seq=1 Time to live exceeded
    From 192.228.109.50 icmp_seq=2 Time to live exceeded
    From 192.228.109.50 icmp_seq=3 Time to live exceeded
    3 packets transmitted, 0 received, +3 errors, 100% packet loss, time 2002ms
    64 bytes from 76.164.234.1: icmp_seq=1 ttl=52 time=176 ms
    64 bytes from 76.164.234.1: icmp_seq=2 ttl=52 time=176 ms
    64 bytes from 76.164.234.1: icmp_seq=3 ttl=52 time=176 ms
    rtt min/avg/max/mdev = 176.579/176.709/176.787/0.092 ms
    Pings (OVH Canada):
    64 bytes from bhs.proof.ovh.net (192.99.19.165): icmp_seq=1 ttl=58 time=77.4 ms
    64 bytes from bhs.proof.ovh.net (192.99.19.165): icmp_seq=2 ttl=58 time=77.4 ms
    64 bytes from bhs.proof.ovh.net (192.99.19.165): icmp_seq=3 ttl=58 time=77.4 ms
    3 packets transmitted, 3 received, 0% packet loss, time 2002ms
    rtt min/avg/max/mdev = 77.412/77.437/77.472/0.322 ms
    Pings (10gbps.io Frankfurt):
    PING 195.181.174.20 (195.181.174.20) 56(84) bytes of data.
    64 bytes from 195.181.174.20: icmp_seq=1 ttl=57 time=12.4 ms
    64 bytes from 195.181.174.20: icmp_seq=2 ttl=57 time=12.5 ms
    64 bytes from 195.181.174.20: icmp_seq=3 ttl=57 time=12.5 ms
    --- 195.181.174.20 ping statistics ---
    rtt min/avg/max/mdev = 12.429/12.504/12.580/0.143 ms
    Pings (10gbps.io London):
    PING 185.59.221.20 (185.59.221.20) 56(84) bytes of data.
    64 bytes from 185.59.221.20: icmp_seq=1 ttl=57 time=21.6 ms
    64 bytes from 185.59.221.20: icmp_seq=2 ttl=57 time=21.8 ms
    64 bytes from 185.59.221.20: icmp_seq=3 ttl=57 time=21.8 ms
    --- 185.59.221.20 ping statistics ---
    rtt min/avg/max/mdev = 21.693/21.788/21.842/0.183 ms
    Pings (10gbps.io Paris):
    PING 185.93.2.193 (185.93.2.193) 56(84) bytes of data.
    64 bytes from 185.93.2.193: icmp_seq=1 ttl=58 time=4.06 ms
    64 bytes from 185.93.2.193: icmp_seq=2 ttl=58 time=4.42 ms
    64 bytes from 185.93.2.193: icmp_seq=3 ttl=58 time=4.25 ms
    --- 185.93.2.193 ping statistics ---
    rtt min/avg/max/mdev = 4.061/4.248/4.428/0.149 ms
    Pings (10gbps.io Singapore):
    PING 203.174.85.38 (203.174.85.38) 56(84) bytes of data.
    64 bytes from 203.174.85.38: icmp_seq=1 ttl=57 time=175 ms
    64 bytes from 203.174.85.38: icmp_seq=2 ttl=57 time=178 ms
    64 bytes from 203.174.85.38: icmp_seq=3 ttl=57 time=175 ms
    --- 203.174.85.38 ping statistics ---
    rtt min/avg/max/mdev = 175.085/176.201/178.200/1.416 ms
    Pings (10gbps.io Stockholm):
    PING 185.76.9.10 (185.76.9.10) 56(84) bytes of data.
    64 bytes from 185.76.9.10: icmp_seq=1 ttl=57 time=32.3 ms
    64 bytes from 185.76.9.10: icmp_seq=2 ttl=57 time=32.4 ms
    64 bytes from 185.76.9.10: icmp_seq=3 ttl=57 time=32.4 ms
    --- 185.76.9.10 ping statistics ---
    3 packets transmitted, 3 received, 0% packet loss, time 2001ms
    rtt min/avg/max/mdev = 32.336/32.423/32.496/0.218 ms
    Pings (10gbps.io Moscow):
    PING 87.245.204.20 (87.245.204.20) 56(84) bytes of data.
    64 bytes from 87.245.204.20: icmp_seq=1 ttl=55 time=47.3 ms
    64 bytes from 87.245.204.20: icmp_seq=2 ttl=55 time=47.4 ms
    64 bytes from 87.245.204.20: icmp_seq=3 ttl=55 time=47.4 ms
    --- 87.245.204.20 ping statistics ---
    rtt min/avg/max/mdev = 47.398/47.458/47.492/0.255 ms
    Pings (10gbps.io Miami):
    PING 195.181.162.195 (195.181.162.195) 56(84) bytes of data.
    64 bytes from 195.181.162.195: icmp_seq=1 ttl=56 time=114 ms
    64 bytes from 195.181.162.195: icmp_seq=2 ttl=56 time=114 ms
    64 bytes from 195.181.162.195: icmp_seq=3 ttl=56 time=114 ms
    --- 195.181.162.195 ping statistics ---
    rtt min/avg/max/mdev = 114.239/114.351/114.489/0.294 ms
    Start: Wed Dec  5 08:56:53 2018
    HOST: ns366161                                        Loss%   Snt   Last   Avg  Best  Wrst StDev
      1.|-- vss-1b-6k.fr.eu                                  0.0%    10    0.6  26.2   0.6 217.7  68.0
      2.|-- 10.95.68.194                                     0.0%    10    0.5   0.5   0.5   0.5   0.0
      3.|-- 10.95.66.78                                      0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.2                                       0.0%    10    3.4   1.9   1.4   3.4   0.5
      5.|-- be100-1050.ams-5-a9.nl.eu                        0.0%    10    6.2   6.0   5.8   6.2   0.0
      7.|-- be2520.ccr42.ams03.atlas.cogentco.com            0.0%    10    6.1   6.2   6.1   6.5   0.0
      8.|-- be2447.rcr21.b021535-1.ams03.atlas.cogentco.com  0.0%    10    7.0   7.0   6.9   7.1   0.0
     10.|-- vip1.G-anycast1.cachefly.net                     0.0%    10    6.1   6.1   6.1   6.2   0.0
    Start: Wed Dec  5 08:57:09 2018
      1.|-- vss-1-6k.fr.eu                                  0.0%    10    0.7   5.9   0.7  51.5  16.0
      2.|-- 2001:41d0:0:5:3::80                             0.0%    10    0.5   0.5   0.5   0.5   0.0
      3.|-- 2001:41d0:0:5:2::8                              0.0%    10    0.7   0.8   0.7   0.9   0.0
      4.|-- be100.rbx-g1-nc5.fr.eu                         80.0%    10    4.6   3.0   1.5   4.6   2.0
      5.|-- be100-1048.ams-1-a9.nl.eu                      70.0%    10    6.2   6.2   6.1   6.3   0.0
      6.|-- cogent.as174.nl.eu                              0.0%    10    6.3   6.2   6.1   6.3   0.0
      7.|-- be2520.ccr42.ams03.atlas.cogentco.com          50.0%    10    6.6   6.6   6.4   6.8   0.0
      8.|-- be2440.agr21.ams03.atlas.cogentco.com          10.0%    10    6.5   6.8   6.5   7.0   0.0
      9.|-- 2001:978:3::fa                                  0.0%    10    6.2   9.2   6.1  34.4   8.8
     10.|-- if-ae-2-2.tcore2.av2-amsterdam.ipv6.as6453.net  0.0%    10    7.9   7.9   7.9   8.0   0.0
     11.|-- if-ae-14-2.tcore2.l78-london.ipv6.as6453.net    0.0%    10   10.9   8.9   8.0  11.4   1.1
     12.|-- if-ae-2-2.tcore1.l78-london.ipv6.as6453.net     0.0%    10    8.0   8.0   8.0   8.1   0.0
     13.|-- if-ae-10-2.tcore2.aeq-ashburn.ipv6.as6453.net   0.0%    10   82.3  82.2  82.1  82.3   0.0
     14.|-- if-ae-2-2.tcore1.aeq-ashburn.ipv6.as6453.net    0.0%    10   82.8  82.8  82.7  82.8   0.0
     15.|-- if-ae-21-2.tcore2.a56-atlanta.ipv6.as6453.net   0.0%    10   93.0  93.7  92.7  97.2   1.5
     16.|-- if-ae-43-2.tcore1.a56-atlanta.ipv6.as6453.net   0.0%    10   92.8  92.8  92.7  93.0   0.0
     17.|-- 2001:5a0:a00:500::96                            0.0%    10   95.6  95.6  95.5  95.7   0.0
     18.|-- 2600:3c02:4444:6::2                             0.0%    10   96.6  96.6  96.4  96.7   0.0
     19.|-- 2600:3c02::4b                                   0.0%    10   93.0  93.0  92.9  93.1   0.0
    Start: Wed Dec  5 08:57:38 2018
      1.|-- vss-1-6k.fr.eu                0.0%    10   22.8  20.4   0.7 173.4  54.2
      2.|-- 2001:41d0:0:5:3::80           0.0%    10    0.5   0.5   0.5   0.6   0.0
      3.|-- 2001:41d0:0:5:2::5a           0.0%    10    0.9   0.8   0.7   0.9   0.0
      4.|-- be100.rbx-g1-nc5.fr.eu       50.0%    10    1.6  33.3   1.5  81.6  43.5
      7.|-- be100-1039.ash-1-a9.va.us    40.0%    10   76.0  76.0  75.7  76.1   0.0
      8.|-- dfw-da2-bb1-a9.tx.us          0.0%    10  106.6 108.0 106.6 110.5   1.2
      9.|-- be100-2.dfw-da2-bb2-a9.tx.us  0.0%    10  106.7 106.6 106.6 106.7   0.0
     10.|-- eqix-ix-da-ipv6.linode.com    0.0%    10  111.7 115.6 111.7 132.8   8.0
     11.|-- 2600:3c00:2222:15::2          0.0%    10  112.7 112.3 112.1 112.7   0.0
     12.|-- speedtest.dallas.linode.com   0.0%    10  113.4 113.4 113.3 113.4   0.0
    Start: Wed Dec  5 08:57:58 2018
      1.|-- vss-1-6k.fr.eu             0.0%    10   68.2  99.4   0.7 834.6 259.9
      2.|-- 2001:41d0:0:5:3::c0        0.0%    10    0.5   0.5   0.5   0.6   0.0
      3.|-- 2001:41d0:0:5:2::60        0.0%    10    0.8   0.8   0.7   0.9   0.0
      4.|-- be1-112.sbg-g1-a9.fr.eu   80.0%    10    1.7   1.7   1.7   1.7   0.0
      5.|-- be100-1042.ldn-5-a9.uk.eu 90.0%    10    4.9   4.9   4.9   4.9   0.0
      6.|-- be100-1298.nwk-5-a9.nj.us 90.0%    10   70.7  70.7  70.7  70.7   0.0
      7.|-- be100-1007.ash-5-a9.va.us 70.0%    10   75.9  76.1  75.9  76.3   0.0
      8.|-- ash2.us.leaseweb.net       0.0%    10   75.8  78.8  75.6 106.2   9.6
      9.|-- 2a03:2280::18             40.0%    10   77.4  76.8  76.6  77.4   0.0
     10.|-- 2a03:2280:39::7            0.0%    10   78.8  78.9  78.7  79.7   0.0
     11.|-- 2604:9a00::108:59:15:247   0.0%    10   78.6  78.6  78.5  78.7   0.0
     12.|-- 2604:9a00:2010:a0b8::5     0.0%    10   76.6  76.6  76.5  76.6   0.0
    Start: Wed Dec  5 08:58:15 2018
      1.|-- vss-1-6k.fr.eu                                                     0.0%    10    0.9  11.5   0.7  53.1  21.9
      2.|-- 2001:41d0:0:5:3::c0                                                0.0%    10    0.6   0.5   0.5   0.6   0.0
      3.|-- 2001:41d0:0:5:2::5c                                                0.0%    10    1.0   0.8   0.6   1.0   0.0
      4.|-- be100.rbx-g1-nc5.fr.eu                                            40.0%    10    1.9   2.2   1.5   3.3   0.4
      5.|-- be100-1048.ams-1-a9.nl.eu                                         60.0%    10    6.1   6.5   5.9   7.9   0.6
      6.|-- bbr01.eq01.ams01.networklayer.com                                  0.0%    10   16.6   7.1   5.9  16.6   3.3
      7.|-- aa30.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    6.8   6.8   6.6   7.1   0.0
      8.|-- 3c10.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    9.1   9.1   8.9   9.4   0.0
      9.|-- 8550.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    9.1  11.7   9.0  23.2   5.3
     10.|-- d450.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    9.4   9.4   9.3   9.8   0.0
     11.|-- e210.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   76.3  76.7  76.2  79.3   0.9
     12.|-- a320.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  102.5 100.6 100.1 102.5   0.7
     13.|-- 5220.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   98.9  99.0  98.3 102.8   1.3
     14.|-- ee20.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  152.9 153.3 152.9 155.1   0.5
     15.|-- 1630.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  151.1 152.6 151.1 159.7   2.8
     16.|-- f100.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  152.6 152.6 152.6 152.6   0.0
     17.|-- po2.fcr01.sr01.sea01.networklayer.com                              0.0%    10  151.5 156.2 151.5 170.3   7.6
     18.|-- softlayer.com                                                      0.0%    10  151.2 151.2 151.2 151.2   0.0
    Start: Wed Dec  5 08:58:34 2018
      1.|-- vss-1-6k.fr.eu                                                     0.0%    10    0.7   3.1   0.6  20.4   6.1
      2.|-- 2001:41d0:0:5:3::c0                                                0.0%    10    0.5   0.5   0.4   0.6   0.0
      3.|-- 2001:41d0:0:5:2::a                                                 0.0%    10    0.9   0.8   0.6   0.9   0.0
      4.|-- be100.rbx-g1-nc5.fr.eu                                            80.0%    10    1.5   1.6   1.5   1.7   0.0
      5.|-- be100-1048.ams-1-a9.nl.eu                                         30.0%    10    5.9   6.1   5.9   6.3   0.0
      6.|-- bbr01.eq01.ams01.networklayer.com                                  0.0%    10    6.3   6.1   6.0   6.5   0.0
      7.|-- aa30.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    6.8   7.0   6.6   8.5   0.5
      8.|-- 3c10.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    9.5  10.1   9.0  12.9   1.4
      9.|-- 5240.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   10.5  10.7   8.7  21.2   3.8
     10.|-- 8140.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    9.1  10.0   9.0  18.0   2.7
     11.|-- e210.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   75.9  76.1  75.9  76.5   0.0
     12.|-- a320.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   99.9  99.8  99.7  99.9   0.0
     13.|-- 5220.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   98.2  98.3  98.0  98.6   0.0
     14.|-- 8320.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  147.7 147.8 147.7 148.2   0.0
     15.|-- 3620.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  148.3 148.1 147.8 148.5   0.0
     16.|-- 5520.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  147.8 147.9 147.7 149.0   0.0
     17.|-- 1b10.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  149.7 148.4 147.9 149.7   0.3
     18.|-- 2607:f0d0:2100:1::3                                                0.0%    10  146.1 146.1 146.0 146.2   0.0
     19.|-- softlayer.com                                                      0.0%    10  146.2 146.1 146.0 146.2   0.0
    Start: Wed Dec  5 08:58:52 2018
      1.|-- vss-1-6k.fr.eu                                                     0.0%    10    0.8   2.9   0.7  21.5   6.5
      3.|-- 2001:41d0:0:5:2::60                                                0.0%    10    0.9   0.8   0.6   0.9   0.0
      4.|-- be1-112.sbg-g1-a9.fr.eu                                           30.0%    10    1.5   2.2   1.5   4.5   0.9
      5.|-- be100-1050.ams-5-a9.nl.eu                                         30.0%    10    5.8   6.0   5.8   6.4   0.0
      6.|-- bbr01.eq01.ams01.networklayer.com                                  0.0%    10    6.4   6.0   5.9   6.4   0.0
      7.|-- 8a30.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    6.8   6.8   6.6   7.3   0.0
      8.|-- ed20.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   82.3  82.1  81.9  82.3   0.0
      9.|-- 1a20.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   89.7  82.4  80.6  89.7   3.2
     10.|-- 1400.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   81.5  81.5  81.4  81.6   0.0
     11.|-- po1.fcr01.sr01.wdc01.networklayer.com                              0.0%    10   81.1  81.1  81.0  81.1   0.0
     12.|-- softlayer.com                                                      0.0%    10   80.1  80.1  80.1  80.2   0.0
    Start: Wed Dec  5 08:59:08 2018
      1.|-- vss-1-6k.fr.eu                   0.0%    10    0.7  10.2   0.6  79.3  24.4
      3.|-- 2001:41d0:0:5:2::5e              0.0%    10    0.8   0.8   0.6   0.9   0.0
      4.|-- be1-112.sbg-g1-a9.fr.eu          0.0%    10    1.5   1.9   1.5   2.6   0.0
      6.|-- be100-1345.ash-1-a9.va.us       30.0%    10   79.0  78.9  78.7  79.1   0.0
      7.|-- be100-1366.lax-la1-bb1-a9.ca.us  0.0%    10  136.6 136.5 136.3 136.8   0.0
      8.|-- 2001:268:fc80:8::1               0.0%    10  134.3 134.3 134.3 134.3   0.0
      9.|-- 6lacGCS002.int-gw.kddi.ne.jp     0.0%    10  134.3 134.6 134.3 137.0   0.7
     10.|-- 2001:268:fb80:304::1            40.0%    10  239.2 239.7 239.2 241.0   0.4
     11.|-- 2001:268:fa00:27d::2             0.0%    10  241.4 241.9 241.3 246.2   1.4
     12.|-- 6cm-fcu204.int-gw.kddi.ne.jp     0.0%    10  251.5 247.1 239.5 252.0   4.6
     13.|-- 2001:268:f702:6d::2              0.0%    10  241.6 241.9 241.4 244.6   0.9
     14.|-- speedtest.tokyo.linode.com       0.0%    10  239.4 239.4 239.3 239.5   0.0
    Start: Wed Dec  5 08:59:34 2018
      1.|-- vss-1-6k.fr.eu                                                     0.0%    10   29.0   6.4   0.7  29.0   8.5
      3.|-- 2001:41d0:0:5:2::60                                                0.0%    10    0.8   0.8   0.8   1.0   0.0
      4.|-- ???                                                               100.0    10    0.0   0.0   0.0   0.0   0.0
      5.|-- be100-1050.ams-5-a9.nl.eu                                         40.0%    10    6.0   6.0   5.9   6.1   0.0
      6.|-- bbr01.eq01.ams01.networklayer.com                                  0.0%    10    6.2   6.1   5.9   6.2   0.0
      7.|-- aa30.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10    6.8   7.3   6.6  11.5   1.4
      8.|-- c210.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   11.1  11.1  10.7  13.4   0.7
      9.|-- 3910.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10   10.7  12.8  10.4  28.9   5.7
     10.|-- 4020.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  163.7 162.6 162.3 163.7   0.3
     11.|-- 0020.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  161.4 159.9 159.6 161.4   0.5
     12.|-- 3020.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  159.5 159.6 159.5 159.6   0.0
     13.|-- 3c00.0000.0000.0000.2000.2000.0d0f.7062.ip6.static.sl-reverse.com  0.0%    10  160.0 160.0 159.9 160.1   0.0
     14.|-- 5.00.0000.ip4.static.sl-reverse.com                               10.0%    10  159.8 160.1 159.7 161.2   0.0
     15.|-- 2.00.0000.ip4.static.sl-reverse.com                                0.0%    10  159.6 159.7 159.6 159.7   0.0
    Start: Wed Dec  5 08:59:55 2018
      1.|-- vss-1-6k.fr.eu               0.0%    10    9.6  62.5   0.7 451.6 145.0
      3.|-- 2001:41d0:0:5:2::8           0.0%    10    1.0   0.8   0.6   1.0   0.0
      4.|-- be100.rbx-g1-nc5.fr.eu      70.0%    10    2.3   1.8   1.5   2.3   0.0
      5.|-- be100-1048.ams-1-a9.nl.eu   50.0%    10    6.2   6.0   5.9   6.2   0.0
      6.|-- 2001:7f8:1::a506:3949:1      0.0%    10    8.3   8.6   8.2  10.6   0.7
      7.|-- 2a01:7e00:7777:12::2         0.0%    10    9.0   8.9   8.7   9.2   0.0
      8.|-- speedtest.london.linode.com  0.0%    10    8.6   8.5   8.3   9.0   0.0
    Start: Wed Dec  5 09:00:14 2018
      1.|-- vss-1-6k.fr.eu                   0.0%    10    0.7  28.7   0.7 209.2  65.9
      4.|-- be100.rbx-g1-nc5.fr.eu          50.0%    10    1.6   1.8   1.5   2.8   0.0
      5.|-- be100-1048.ams-1-a9.nl.eu       80.0%    10    6.1   6.0   5.9   6.1   0.0
      6.|-- 100ge.ams-ix.i3d.net             0.0%    10    6.0   5.9   5.8   6.0   0.0
      7.|-- 30ge.ar0-cr1.nikhef.ams.i3d.net  0.0%    10    7.0   7.3   7.0   8.0   0.0
      8.|-- 2a00:1630:1fff::1507:3           0.0%    10    7.1   7.5   7.1   9.2   0.7
      9.|-- hosted-by.i3d.net                0.0%    10    7.1   7.2   7.1   7.3   0.0
    Start: Wed Dec  5 09:00:32 2018
      1.|-- vss-1b-6k.fr.eu                               0.0%    10    0.7 185.5   0.7 1191. 396.3
      2.|-- 10.95.68.130                                  0.0%    10    0.5   0.5   0.4   0.7   0.0
      3.|-- 10.95.66.74                                   0.0%    10    0.5   0.5   0.5   0.5   0.0
      4.|-- 10.95.64.2                                    0.0%    10    1.6   1.9   1.4   4.1   0.7
      5.|-- be100-1042.ldn-5-a9.uk.eu                     0.0%    10    6.5  13.0   4.4  51.2  16.7
      6.|-- be100-1298.nwk-5-a9.nj.us                     0.0%    10   72.3  72.3  72.2  72.5   0.0
      7.|-- be100-1007.ash-5-a9.va.us                     0.0%    10   76.8  77.0  76.8  77.2   0.0
      8.|-- be100-1367.lax-la1-bb1-a9.ca.us               0.0%    10  132.5 132.7 132.5 132.9   0.0
      9.|-- vocus-connect-pty.as4826.any2ix.coresite.com  0.0%    10  132.6 132.8 132.5 133.9   0.3
     10.|-- bundle-150.cor01.lax01.ca.vocus.net           0.0%    10  286.7 286.8 286.7 287.2   0.0
     11.|-- 100g-0-1-0-0.cor01.sjc01.ca.vocus.net         0.0%    10  290.2 290.3 290.2 290.5   0.0
     12.|-- BE-200.cor02.syd04.nsw.VOCUS.net.au           0.0%    10  283.0 282.4 282.1 283.0   0.0
     13.|-- bundle-110.bdr01.syd04.nsw.vocus.net.au       0.0%    10  285.7 285.7 285.4 286.8   0.0
     14.|-- static-75.7.255.49.in-addr.VOCUS.net.au       0.0%    10  282.6 285.0 280.8 298.5   6.5
     15.|-- ???                                          100.0    10    0.0   0.0   0.0   0.0   0.0
     16.|-- 180.189.25.6                                 30.0%    10  285.2 288.5 285.1 307.8   8.5
     18.|-- ???                                          100.0    10    0.0   0.0   0.0   0.0   0.0
     19.|-- 108.61.212.117.vultr.com                      0.0%    10  275.8 275.9 275.7 276.2   0.0
    Start: Wed Dec  5 09:00:56 2018
      1.|-- vss-1b-6k.fr.eu                             0.0%    10    1.8   1.7   0.6   5.5   1.2
      2.|-- 10.95.68.130                                0.0%    10    0.5   0.4   0.4   0.5   0.0
      3.|-- 10.95.66.64                                 0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.0                                  0.0%    10    1.4  19.6   1.4  46.8  18.1
      5.|-- be100-1041.ldn-1-a9.uk.eu                   0.0%    10    4.7   4.5   4.2   4.9   0.0
      7.|-- ldn-bb3-link.telia.net                      0.0%    10    4.5   4.8   4.2   8.1   1.1
      8.|-- ldn-b7-link.telia.net                       0.0%    10    4.6   4.7   4.1   8.3   1.2
      9.|-- ntt-ic-339488-ldn-b7.c.telia.net            0.0%    10    4.8   4.6   4.2   4.9   0.0
     10.|-- ae-3.r24.londen12.uk.bb.gin.ntt.net         0.0%    10    4.6   4.8   4.5   6.0   0.0
     11.|-- ae-5.r24.nycmny01.us.bb.gin.ntt.net         0.0%    10   72.0  72.0  71.9  72.1   0.0
     12.|-- ae-4.r22.sttlwa01.us.bb.gin.ntt.net        90.0%    10  133.3 133.3 133.3 133.3   0.0
     13.|-- ae-13.r30.tokyjp05.jp.bb.gin.ntt.net        0.0%    10  224.4 224.5 224.3 224.8   0.0
     14.|-- ae-2.r02.tokyjp05.jp.bb.gin.ntt.net         0.0%    10  222.9 222.9 222.8 223.2   0.0
     15.|-- ce-0-14-0-1.r02.tokyjp05.jp.ce.gin.ntt.net  0.0%    10  238.2 227.6 225.5 238.2   4.2
     17.|-- vl516-ds1-b5-r2605.tyo1.choopa.net          0.0%    10  224.4 224.6 224.3 225.7   0.3
     19.|-- 108.61.201.151.vultr.com                    0.0%    10  225.6 225.1 225.0 225.6   0.0
    Start: Wed Dec  5 09:01:19 2018
      1.|-- vss-1b-6k.fr.eu                                   0.0%    10    1.6   2.2   0.7   8.0   2.2
      2.|-- 10.95.68.130                                      0.0%    10    0.5   0.5   0.4   0.8   0.0
      3.|-- 10.95.66.66                                       0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.0                                        0.0%    10    1.7   1.5   1.3   1.7   0.0
      5.|-- be100-1041.ldn-1-a9.uk.eu                         0.0%    10    4.3   4.5   4.3   4.8   0.0
      6.|-- be100-1295.nwk-1-a9.nj.us                         0.0%    10   70.7  70.7  70.5  70.9   0.0
      7.|-- be100-1039.ash-1-a9.va.us                         0.0%    10   75.9  75.9  75.7  76.1   0.0
      8.|-- be100-1366.lax-la1-bb1-a9.ca.us                   0.0%    10  133.4 133.3 133.1 133.5   0.0
      9.|-- clan-servers-hosting.as20473.any2ix.coresite.com 70.0%    10  133.6 137.6 133.6 145.5   6.9
     12.|-- 108.61.219.200.vultr.com                          0.0%    10  131.3 131.4 131.3 131.6   0.0
    Start: Wed Dec  5 09:01:36 2018
      1.|-- vss-1b-6k.fr.eu                  0.0%    10    8.5  25.3   0.6 136.3  45.2
      2.|-- 10.95.68.130                     0.0%    10    0.4   0.4   0.4   0.5   0.0
      3.|-- 10.95.66.72                      0.0%    10    0.5   0.5   0.5   0.5   0.0
      4.|-- 10.95.64.2                       0.0%    10    1.7   8.6   1.4  71.4  22.1
      5.|-- be100-1044.gsw-1-a9.fr.eu        0.0%    10    5.7   4.7   4.1   5.7   0.5
      6.|-- be100-1345.ash-1-a9.va.us        0.0%    10   78.9  78.8  78.7  79.1   0.0
      7.|-- be100-1366.lax-la1-bb1-a9.ca.us  0.0%    10  136.6 136.5 136.2 136.6   0.0
      8.|-- be100-1365.sjo-sv5-bb1-a9.ca.us  0.0%    10  146.3 146.1 145.7 146.3   0.0
      9.|-- be1.sea-1-6k.wa.us               0.0%    10  164.8 164.9 164.7 166.8   0.6
     10.|-- six-a.sea2.choopa.net           90.0%    10  164.6 164.6 164.6 164.6   0.0
     11.|-- 10.69.0.50                       0.0%    10  166.3 179.6 166.1 299.3  42.1
     12.|-- ???                             100.0    10    0.0   0.0   0.0   0.0   0.0
     13.|-- 108.61.194.105.vultr.com         0.0%    10  164.9 165.0 164.9 165.0   0.0
    Start: Wed Dec  5 09:01:53 2018
      1.|-- vss-1b-6k.fr.eu                      0.0%    10    3.8   1.8   0.6   4.0   1.1
      3.|-- 10.95.66.72                          0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.2                           0.0%    10    1.5   1.4   1.2   1.5   0.0
      5.|-- be100-1042.ldn-5-a9.uk.eu            0.0%    10   35.2  10.7   4.3  35.2   9.9
      6.|-- be100-2.ldn-1-a9.uk.eu               0.0%    10    4.7   4.6   4.3   5.2   0.0
      7.|-- ???                                 100.0    10    0.0   0.0   0.0   0.0   0.0
      8.|-- ldn-bb3-link.telia.net               0.0%    10  109.5 110.1 109.4 111.5   0.5
      9.|-- ash-bb3-link.telia.net              20.0%    10  112.4 113.7 112.0 123.9   4.1
     10.|-- atl-b22-link.telia.net               0.0%    10   91.3  91.9  91.3  93.4   0.6
     11.|-- dls-b22-link.telia.net               0.0%    10  109.6 109.9 109.5 111.8   0.6
     12.|-- vultr-ic-318447-dls-b22.c.telia.net  0.0%    10  132.6 113.7 111.5 132.6   6.7
     13.|-- ???                                 100.0    10    0.0   0.0   0.0   0.0   0.0
     14.|-- ???                                 100.0    10    0.0   0.0   0.0   0.0   0.0
     15.|-- 108.61.224.175.vultr.com             0.0%    10  108.7 108.7 108.5 108.8   0.0
    Start: Wed Dec  5 09:02:09 2018
      1.|-- vss-1b-6k.fr.eu                     0.0%    10  275.1  47.2   0.5 275.1  92.2
      2.|-- 10.95.68.130                        0.0%    10    0.5   0.5   0.4   0.5   0.0
      3.|-- 10.95.66.64                         0.0%    10    0.5   0.5   0.5   0.5   0.0
      4.|-- 10.95.64.0                          0.0%    10    1.2   1.9   1.2   4.2   0.7
      5.|-- be100-1041.ldn-1-a9.uk.eu           0.0%    10    5.0   4.6   4.3   5.0   0.0
      6.|-- be100-2.ldn-5-a9.uk.eu              0.0%    10    4.9   4.8   4.4   5.2   0.0
      7.|-- be100-1298.nwk-5-a9.nj.us           0.0%    10   72.5  72.7  72.2  75.3   0.7
      8.|-- be100-1323.bhs-g2-nc5.qc.ca         0.0%    10   81.2  79.9  79.3  81.2   0.3
      9.|-- be100-1324.chi-5-a9.il.us           0.0%    10   95.3  95.3  94.9  95.5   0.0
     10.|-- 20473.chi.equinix.com               0.0%    10   96.8 109.6  96.4 144.8  19.4
     11.|-- vl820-ds1-b5-gj178.chi2.choopa.net  0.0%    10   97.0  97.0  96.9  97.0   0.0
     13.|-- 107.191.51.12.vultr.com             0.0%    10   94.8  94.8  94.6  94.9   0.0
    Start: Wed Dec  5 09:02:26 2018
      1.|-- vss-1b-6k.fr.eu                      0.0%    10  332.7  51.7   0.6 332.7 105.5
      3.|-- 10.95.66.74                          0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.2                           0.0%    10    1.4   1.6   1.4   2.2   0.0
      5.|-- be100-1042.ldn-5-a9.uk.eu            0.0%    10    4.2  12.0   4.2  30.5   9.0
      6.|-- be100-2.ldn-1-a9.uk.eu               0.0%    10    4.6   4.6   4.4   4.9   0.0
      8.|-- ldn-bb3-link.telia.net               0.0%    10   90.3  90.4  90.2  91.8   0.3
      9.|-- ash-bb3-link.telia.net              50.0%    10   81.6  81.8  81.6  82.2   0.0
     10.|-- atl-b21-link.telia.net               0.0%    10   92.5  92.5  92.5  92.5   0.0
     11.|-- vultr-ic-319646-atl-b21.c.telia.net  0.0%    10   91.7  91.9  91.7  92.6   0.0
     14.|-- 108.61.193.166.vultr.com             0.0%    10   91.7  91.8  91.7  91.8   0.0
    Start: Wed Dec  5 09:02:42 2018
      1.|-- vss-1b-6k.fr.eu                     0.0%    10    0.5  13.4   0.5  74.6  25.3
      2.|-- 10.95.68.194                        0.0%    10    0.5   0.5   0.4   0.6   0.0
      3.|-- 10.95.66.76                         0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.2                          0.0%    10    1.5   1.9   1.3   4.0   0.9
      5.|-- be100-1042.ldn-5-a9.uk.eu           0.0%    10    4.8   4.7   4.2   4.8   0.0
      6.|-- be100-2.ldn-1-a9.uk.eu              0.0%    10    4.6   4.6   4.3   5.0   0.0
      8.|-- ldn-bb4-link.telia.net              0.0%    10  103.3 103.8 103.1 108.9   1.7
      9.|-- ash-bb4-link.telia.net              0.0%    10   78.3  80.0  78.2  95.4   5.4
     10.|-- mai-b1-link.telia.net               0.0%    10  105.9 105.9 105.7 106.1   0.0
     11.|-- vultr-ic-318945-mai-b1.c.telia.net  0.0%    10  103.9 105.1 103.7 112.8   2.7
     14.|-- 104.156.244.232                     0.0%    10  104.0 104.0 103.9 104.2   0.0
    Start: Wed Dec  5 09:02:58 2018
      1.|-- vss-1b-6k.fr.eu                  0.0%    10    1.8  15.3   0.7  82.8  25.4
      2.|-- 10.95.68.130                     0.0%    10    0.4   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.0                       0.0%    10    1.6   1.7   1.5   2.6   0.0
      5.|-- be100-1041.ldn-1-a9.uk.eu        0.0%    10    4.7   4.6   4.2   5.0   0.0
      6.|-- be100-2.ldn-5-a9.uk.eu           0.0%    10   28.5  34.3  16.6  62.2  12.6
      7.|-- be100-1298.nwk-5-a9.nj.us        0.0%    10   72.5  72.3  72.1  72.5   0.0
      8.|-- nyiix.gi3-6.cr1.nyc1.choopa.net  0.0%    10   72.2  72.1  72.0  72.8   0.0
      9.|-- vl42-br2.pnj1.choopa.net         0.0%    10  109.1  84.7  71.4 147.1  24.8
     10.|-- vl140-c4-3-b5-2.pnj1.choopa.net  0.0%    10   76.0  74.2  73.5  76.0   0.8
     11.|-- ???                             100.0    10    0.0   0.0   0.0   0.0   0.0
     12.|-- 108.61.149.182.vultr.com         0.0%    10   72.3  72.4  72.3  72.4   0.0
    Start: Wed Dec  5 09:03:14 2018
      1.|-- vss-1b-6k.fr.eu                      0.0%    10    3.9   9.7   0.5  86.0  26.8
      2.|-- 10.95.68.130                         0.0%    10    0.5   0.4   0.3   0.5   0.0
      3.|-- 10.95.66.64                          0.0%    10    0.5   0.4   0.4   0.5   0.0
      4.|-- 10.95.64.0                           0.0%    10    1.8   1.8   1.4   2.4   0.0
      5.|-- be100-1041.ldn-1-a9.uk.eu            0.0%    10    4.6   4.6   4.4   4.8   0.0
      6.|-- ???                                 100.0    10    0.0   0.0   0.0   0.0   0.0
      7.|-- ldn-bb4-link.telia.net               0.0%    10   16.9  17.1  16.9  17.8   0.0
      8.|-- prs-bb4-link.telia.net               0.0%    10   18.1  17.2  16.8  18.1   0.0
      9.|-- ffm-bb4-link.telia.net               0.0%    10   17.0  17.1  16.9  17.4   0.0
     10.|-- ffm-b12-link.telia.net               0.0%    10   16.8  18.2  16.7  22.3   2.1
     11.|-- vultr-ic-312911-ffm-b12.c.telia.net 10.0%    10   16.9  17.6  16.8  20.3   1.3
     14.|-- 108.61.210.117.vultr.com             0.0%    10   16.9  17.0  16.6  17.8   0.0
    Start: Wed Dec  5 09:03:30 2018
      1.|-- vss-1b-6k.fr.eu            0.0%    10    0.6  64.6   0.6 412.2 133.0
      2.|-- 10.95.68.194               0.0%    10    0.5   0.4   0.4   0.5   0.0
      4.|-- 10.95.64.2                 0.0%    10   69.4  29.1   1.2  89.4  35.0
      5.|-- be100-1050.ams-5-a9.nl.eu  0.0%    10    6.9   6.8   5.9  10.5   1.4
      6.|-- 80.249.212.38              0.0%    10    6.5  11.7   6.4  17.6   4.0
      9.|-- 108.61.198.102.vultr.com   0.0%    10    6.0   6.0   5.9   6.1   0.0
    Start: Wed Dec  5 09:03:46 2018
      1.|-- vss-1b-6k.fr.eu               0.0%    10    0.6  18.1   0.5  86.9  32.4
      3.|-- 10.95.66.78                   0.0%    10    0.5   0.4   0.4   0.5   0.0
      4.|-- 10.95.64.2                    0.0%    10    1.5   1.9   1.2   4.2   0.8
      5.|-- be100-1042.ldn-5-a9.uk.eu     0.0%    10    4.8   4.7   4.4   5.0   0.0
      6.|-- vl32-br1-cer.lon3.choopa.net 70.0%    10    5.4   6.0   5.4   7.1   0.7
      9.|-- 108.61.196.101.vultr.com      0.0%    10    4.4   4.4   4.2   4.4   0.0
    Start: Wed Dec  5 09:04:01 2018
      1.|-- vss-1b-6k.fr.eu            0.0%    10    0.6   9.0   0.6  51.3  15.7
      4.|-- 10.95.64.0                 0.0%    10    1.4   1.6   1.4   1.9   0.0
      5.|-- be100-1041.ldn-1-a9.uk.eu  0.0%    10    4.5   4.6   4.5   4.8   0.0
      7.|-- ldn-bb3-link.telia.net     0.0%    10   17.1  16.8  16.3  18.0   0.3
      8.|-- prs-bb3-link.telia.net     0.0%    10   17.1  17.1  17.0  17.1   0.0
      9.|-- prs-b7-link.telia.net      0.0%    10   16.3  16.8  16.2  19.0   0.7
     10.|-- ???                       100.0    10    0.0   0.0   0.0   0.0   0.0
     13.|-- 108.61.209.127.vultr.com   0.0%    10   17.1  17.3  17.0  18.6   0.3
    Start: Wed Dec  5 09:04:17 2018
      1.|-- vss-1b-6k.fr.eu                  0.0%    10    0.6   0.8   0.5   1.5   0.0
      2.|-- 10.95.68.194                     0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.2                       0.0%    10   28.8  18.0   1.4  32.4  14.2
      5.|-- be100-1044.gsw-1-a9.fr.eu        0.0%    10    4.5   4.3   4.0   4.5   0.0
      6.|-- be100-1345.ash-1-a9.va.us        0.0%    10   79.0  78.8  78.6  79.1   0.0
      7.|-- be100-1366.lax-la1-bb1-a9.ca.us  0.0%    10  136.3 136.3 136.1 136.6   0.0
      8.|-- any2ix.coresite.com              0.0%    10  135.3 135.3 135.2 135.8   0.0
      9.|-- 192.228.109.129                  0.0%    10  143.9 145.4 143.8 151.4   2.5
     10.|-- 192.228.109.50                   0.0%    10  143.9 145.5 143.9 152.7   3.0
     11.|-- 192.228.109.49                  10.0%    10  144.7 146.6 142.2 153.1   4.3
     12.|-- 192.228.109.50                   0.0%    10  143.9 146.1 143.9 152.6   2.9
     13.|-- 192.228.109.49                   0.0%    10  153.0 145.2 142.2 153.4   4.5
     14.|-- 192.228.109.50                   0.0%    10  149.8 146.9 143.9 153.4   3.9
     15.|-- 192.228.109.49                   0.0%    10  142.3 144.3 142.2 152.2   3.3
     16.|-- 192.228.109.50                   0.0%    10  143.9 145.2 143.9 151.9   2.6
     17.|-- 192.228.109.49                   0.0%    10  144.1 145.8 142.2 152.2   3.9
     18.|-- 192.228.109.50                   0.0%    10  144.3 145.8 144.0 151.9   2.6
     19.|-- 192.228.109.49                   0.0%    10  152.2 144.9 142.2 152.5   4.2
     20.|-- 192.228.109.50                   0.0%    10  147.9 146.4 143.9 152.3   3.4
     21.|-- 192.228.109.49                   0.0%    10  142.4 144.0 142.3 151.4   3.0
     22.|-- 192.228.109.50                   0.0%    10  144.1 145.1 144.0 151.3   2.4
     23.|-- 192.228.109.49                   0.0%    10  142.3 145.1 142.3 151.4   3.8
     24.|-- 192.228.109.50                   0.0%    10  144.0 146.8 143.9 156.0   4.0
     25.|-- 192.228.109.49                   0.0%    10  150.7 144.4 142.3 150.7   3.2
     26.|-- 192.228.109.50                   0.0%    10  145.2 146.9 144.0 155.0   4.0
     27.|-- 192.228.109.49                   0.0%    10  142.4 143.7 142.3 150.7   2.7
     28.|-- 192.228.109.50                   0.0%    10  153.3 147.1 144.1 155.2   4.4
     29.|-- 192.228.109.49                   0.0%    10  142.4 144.9 142.4 150.8   3.4
     30.|-- 192.228.109.50                   0.0%    10  144.0 146.3 144.0 154.2   3.4
    mtr --report -w 200 --report-cycles=10 VersaWeb Seattle
    Start: Wed Dec  5 09:04:35 2018
      1.|-- vss-1b-6k.fr.eu                  0.0%    10    0.6  16.9   0.5 162.9  51.3
      2.|-- 10.95.68.194                     0.0%    10    0.5   0.4   0.3   0.5   0.0
      3.|-- 10.95.66.78                      0.0%    10    0.5   0.5   0.5   0.5   0.0
      4.|-- 10.95.64.2                       0.0%    10   55.6  14.6   1.4  55.6  17.2
      5.|-- be100-1044.gsw-1-a9.fr.eu        0.0%    10    4.5   4.4   4.0   4.6   0.0
      6.|-- be100-1345.ash-1-a9.va.us        0.0%    10   78.8  78.9  78.7  79.1   0.0
      7.|-- be100-1366.lax-la1-bb1-a9.ca.us  0.0%    10  136.3 136.4 136.2 136.7   0.0
      8.|-- any2ix.coresite.com              0.0%    10  135.4 135.4 135.2 136.3   0.0
      9.|-- 192.228.109.129                  0.0%    10  143.9 145.2 143.8 150.1   2.2
     10.|-- 192.228.109.121                  0.0%    10  149.2 146.0 142.2 153.2   4.2
     11.|-- 192.228.109.78                   0.0%    10  174.9 175.3 174.8 176.8   0.6
     12.|-- 76.164.234.1                     0.0%    10  176.8 177.1 176.8 178.9   0.6
    Start: Wed Dec  5 09:04:52 2018
      1.|-- vss-1-6k.fr.eu           0.0%    10    0.7  33.0   0.7 200.8  63.8
      3.|-- 2001:41d0:0:5:2::a       0.0%    10    0.8   0.8   0.8   0.9   0.0
      4.|-- vl1304.bhs-d1-a75.qc.ca  0.0%    10   77.6  77.7  77.6  77.8   0.0
      5.|-- 2001:41d0:0:50::6:809    0.0%    10   77.5  77.5  77.5  77.5   0.0
      6.|-- 2001:41d0:0:50::2:4049   0.0%    10  302.2 100.3  77.8 302.2  70.9
      7.|-- 2607:5300:60:44a5::1     0.0%    10   79.1  79.2  79.1  79.2   0.0
    mtr --report -w 200 --report-cycles=10 10gbps.io Frankfurt:
    Start: Wed Dec  5 09:05:07 2018
      1.|-- vss-1b-6k.fr.eu                 0.0%    10    0.5   4.4   0.5  36.6  11.3
      2.|-- 10.95.68.130                    0.0%    10    0.5   0.5   0.5   0.5   0.0
      3.|-- 10.95.66.74                     0.0%    10    0.5   0.5   0.4   0.7   0.0
      4.|-- 10.95.64.2                      0.0%    10    3.0   1.8   1.4   3.0   0.3
      5.|-- be100-1044.gsw-1-a9.fr.eu       0.0%    10    4.4   4.2   4.1   4.5   0.0
      6.|-- be100-2.th2-1-a9.fr.eu          0.0%    10    4.9   4.6   4.4   4.9   0.0
      8.|-- vl1337.frb-ar-core-1.cdn77.com  0.0%    10   12.5  12.5  12.5  12.5   0.0
      9.|-- frankfurt-20.cdn77.com          0.0%    10   12.6  12.6  12.6  12.6   0.0
    mtr --report -w 200 --report-cycles=10 10gbps.io London:
    Start: Wed Dec  5 09:05:22 2018
      1.|-- vss-1b-6k.fr.eu                 0.0%    10    3.9   4.5   0.6  14.7   4.8
      4.|-- 10.95.64.0                      0.0%    10    1.2   6.0   1.2  46.6  14.2
      5.|-- be100-1043.th2-1-a9.fr.eu       0.0%    10    4.5   4.5   4.3   4.7   0.0
      7.|-- vl1339.lon-ar-core-1.cdn77.com  0.0%    10   21.8  21.8  21.8  21.9   0.0
      8.|-- london-20.cdn77.com             0.0%    10   21.8  23.7  21.8  40.1   5.7
    mtr --report -w 200 --report-cycles=10 10gbps.io Paris:
    Start: Wed Dec  5 09:05:38 2018
      1.|-- vss-1b-6k.fr.eu             0.0%    10    4.9  28.7   0.6 206.2  66.1
      4.|-- 10.95.64.0                  0.0%    10    1.6   1.6   1.4   2.2   0.0
      5.|-- be100-1043.th2-1-a9.fr.eu   0.0%    10    4.3   4.4   4.3   4.7   0.0
      7.|-- paris-kvm-1.datapacket.com  0.0%    10    4.5   4.3   4.2   4.5   0.0
    mtr --report -w 200 --report-cycles=10 10gbps.io Singapore:
    Start: Wed Dec  5 09:05:53 2018
      1.|-- vss-1b-6k.fr.eu                 0.0%    10    0.5  13.7   0.4 128.4  40.3
      3.|-- 10.95.66.68                     0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.0                      0.0%    10    1.6   1.6   1.5   1.8   0.0
      5.|-- be100-1046.fra-1-a9.de.eu       0.0%    10   12.7  12.5  12.2  12.7   0.0
      6.|-- de-cix.fra.ne.com.sg           20.0%    10  203.0 207.8 203.0 240.7  13.3
      8.|-- singapore-latency-38.cdn77.com  0.0%    10  183.8 184.1 183.7 186.5   0.7
    mtr --report -w 200 --report-cycles=10 10gbps.io Stockholm:
    Start: Wed Dec  5 09:06:10 2018
      1.|-- vss-1b-6k.fr.eu                 0.0%    10    0.9   1.2   0.4   3.9   0.9
      3.|-- 10.95.66.70                     0.0%    10    0.5   0.5   0.4   0.5   0.0
      4.|-- 10.95.64.0                      0.0%    10    1.7   4.3   1.4  23.2   6.7
      5.|-- be100-1043.th2-1-a9.fr.eu       0.0%    10    4.4   4.5   4.3   4.8   0.0
      7.|-- vl1337.fra-ar-core-1.cdn77.com  0.0%    10   32.6  32.5  32.5  32.6   0.0
      8.|-- stockholm-10.cdn77.com          0.0%    10   32.5  32.5  32.5  32.5   0.0
    mtr --report -w 200 --report-cycles=10 10gbps.io Moscow:
    Start: Wed Dec  5 09:06:25 2018
      1.|-- vss-1b-6k.fr.eu                 0.0%    10   78.2  19.4   0.6  78.2  31.3
      4.|-- 10.95.64.2                      0.0%    10    2.2   9.1   1.5  33.1  11.5
      5.|-- be100-1050.ams-5-a9.nl.eu       0.0%    10    5.7   6.0   5.7   6.2   0.0
      6.|-- be100-1167.var-5-a9.pl.eu       0.0%    10   26.6  26.8  26.6  27.1   0.0
      8.|-- xe4100-3.RT.M9.MSK.RU.retn.net  0.0%    10   45.1  46.0  45.0  50.4   1.8
      9.|-- ae1-3.RT.MR.MSK.RU.retn.net     0.0%    10   47.4  47.4  47.4  47.5   0.0
     10.|-- moscow-20.cdn77.com             0.0%    10   47.5  47.5  47.5  47.6   0.0
    mtr --report -w 200 --report-cycles=10 10gbps.io Miami:
    Start: Wed Dec  5 09:06:41 2018
      1.|-- vss-1b-6k.fr.eu                        0.0%    10   46.6   5.3   0.4  46.6  14.5
      4.|-- 10.95.64.2                             0.0%    10    1.5   1.7   1.4   2.0   0.0
      5.|-- be100-1042.ldn-5-a9.uk.eu              0.0%    10    4.8   5.0   4.2   8.1   0.9
      7.|-- ldn-bb4-link.telia.net                 0.0%    10  105.0 106.0 103.2 127.5   7.6
      8.|-- ash-bb4-link.telia.net                 0.0%    10   76.7  77.8  76.6  82.9   1.8
      9.|-- mai-b1-link.telia.net                  0.0%    10  104.4 104.3 104.2 104.9   0.0
     10.|-- datacamp-ic-337374-mai-b1.c.telia.net  0.0%    10  114.2 114.2 114.2 114.2   0.0
     11.|-- miami-kvm-1.datapacket.com             0.0%    10  114.5 114.4 114.4 114.5   0.0
    Check system entropy pool availability
    entropy_avail: 2995
    entropy_avail: 2997
    entropy_avail: 2998
    entropy_avail: 2999
    OpenSSL System Benchmark
    OpenSSL 1.0.2k-fips  26 Jan 2017
    openssl speed -multi 8 rsa4096 rsa2048 ecdsap256 sha256 sha1 md5 rc4 aes-256-cbc aes-128-cbc
    Forked child 0
    Forked child 1
    Forked child 2
    +DT:md5:3:16
    Forked child 3
    +DT:md5:3:16
    +DT:md5:3:16
    Forked child 4
    +DT:md5:3:16
    Forked child 5
    +DT:md5:3:16
    Forked child 6
    +DT:md5:3:16
    +DT:md5:3:16
    +DT:md5:3:16
    +R:4261167:md5:3.000000
    +DT:md5:3:64
    +R:4307137:md5:3.000000
    +DT:md5:3:64
    +R:4276038:md5:3.000000
    +DT:md5:3:64
    +R:4302679:md5:3.000000
    +DT:md5:3:64
    +R:4261704:md5:3.000000
    +DT:md5:3:64
    +R:4305840:md5:3.000000
    +DT:md5:3:64
    +R:4276803:md5:3.000000
    +DT:md5:3:64
    +R:4303077:md5:3.000000
    +DT:md5:3:64
    +R:3566413:md5:3.000000
    +DT:md5:3:256
    +R:3579054:md5:3.000000
    +DT:md5:3:256
    +R:3563925:md5:3.000000
    +DT:md5:3:256
    +R:3579419:md5:3.000000
    +DT:md5:3:256
    +R:3566588:md5:3.000000
    +DT:md5:3:256
    +R:3577088:md5:3.000000
    +DT:md5:3:256
    +R:3564279:md5:3.000000
    +DT:md5:3:256
    +R:3579252:md5:3.000000
    +DT:md5:3:256
    +R:2225402:md5:3.000000
    +DT:md5:3:1024
    +R:2236720:md5:3.000000
    +DT:md5:3:1024
    +R:2229269:md5:3.000000
    +DT:md5:3:1024
    +R:2236351:md5:3.000000
    +DT:md5:3:1024
    +R:2225367:md5:3.000000
    +DT:md5:3:1024
    +R:2236066:md5:3.000000
    +DT:md5:3:1024
    +R:2229225:md5:3.000000
    +DT:md5:3:1024
    +R:2236279:md5:3.000000
    +DT:md5:3:1024
    +R:892896:md5:3.000000
    +DT:md5:3:8192
    +R:894808:md5:3.000000
    +DT:md5:3:8192
    +R:893315:md5:3.000000
    +DT:md5:3:8192
    +R:893961:md5:3.000000
    +DT:md5:3:8192
    +R:892891:md5:3.000000
    +DT:md5:3:8192
    +R:894347:md5:3.000000
    +DT:md5:3:8192
    +R:893355:md5:3.000000
    +DT:md5:3:8192
    +R:893955:md5:3.000000
    +DT:md5:3:8192
    +R:135183:md5:3.000000
    +R:134891:md5:3.000000
    +DT:sha1:3:16
    +DT:sha1:3:16
    +R:135225:md5:3.000000
    +DT:sha1:3:16
    +R:135180:md5:3.000000
    +DT:sha1:3:16
    +R:134889:md5:3.000000
    +DT:sha1:3:16
    +R:135131:md5:3.000000
    +DT:sha1:3:16
    +R:135232:md5:3.000000
    +DT:sha1:3:16
    +R:135166:md5:3.000000
    +DT:sha1:3:16
    +R:4310377:sha1:3.000000
    +DT:sha1:3:64
    +R:4324112:sha1:3.000000
    +DT:sha1:3:64
    +R:4328762:sha1:3.000000
    +DT:sha1:3:64
    +R:4330531:sha1:3.000000
    +DT:sha1:3:64
    +R:4310392:sha1:3.000000
    +DT:sha1:3:64
    +R:4326178:sha1:3.000000
    +DT:sha1:3:64
    +R:4324265:sha1:3.000000
    +DT:sha1:3:64
    +R:4330255:sha1:3.000000
    +DT:sha1:3:64
    +R:3032057:sha1:3.000000
    +R:3058386:sha1:3.000000
    +DT:sha1:3:256
    +R:3056327:sha1:3.000000
    +DT:sha1:3:256
    +DT:sha1:3:256
    +R:3049398:sha1:3.000000
    +DT:sha1:3:256
    +R:3058423:sha1:3.000000
    +DT:sha1:3:256
    +R:3055017:sha1:3.000000
    +DT:sha1:3:256
    +R:3032173:sha1:3.000000
    +DT:sha1:3:256
    +R:3049172:sha1:3.000000
    +DT:sha1:3:256
    +R:1625789:sha1:3.000000
    +R:1632398:sha1:3.000000
    +DT:sha1:3:1024
    +DT:sha1:3:1024
    +R:1637221:sha1:3.000000
    +DT:sha1:3:1024
    +R:1628109:sha1:3.000000
    +DT:sha1:3:1024
    +R:1637203:sha1:3.000000
    +DT:sha1:3:1024
    +R:1631428:sha1:3.000000
    +DT:sha1:3:1024
    +R:1625861:sha1:3.000000
    +DT:sha1:3:1024
    +R:1627986:sha1:3.000000
    +DT:sha1:3:1024
    +R:574098:sha1:3.000000
    +R:571425:sha1:3.000000
    +R:573722:sha1:3.000000
    +DT:sha1:3:8192
    +DT:sha1:3:8192
    +DT:sha1:3:8192
    +R:567256:sha1:3.000000
    +DT:sha1:3:8192
    +R:562359:sha1:3.000000
    +DT:sha1:3:8192
    +R:565086:sha1:3.000000
    +DT:sha1:3:8192
    +R:570925:sha1:3.000000
    +DT:sha1:3:8192
    +R:568705:sha1:3.000000
    +DT:sha1:3:8192
    +R:81453:sha1:3.000000
    +R:81209:sha1:3.000000
    +DT:sha256:3:16
    +DT:sha256:3:16
    +R:81350:sha1:3.000000
    +DT:sha256:3:16
    +R:81145:sha1:3.000000
    +DT:sha256:3:16
    +R:81451:sha1:3.000000
    +DT:sha256:3:16
    +R:81155:sha1:3.000000
    +DT:sha256:3:16
    +R:81356:sha1:3.000000
    +DT:sha256:3:16
    +R:81136:sha1:3.000000
    +DT:sha256:3:16
    +R:3874273:sha256:3.000000
    +R:3876629:sha256:3.000000
    +DT:sha256:3:64
    +DT:sha256:3:64
    +R:3875176:sha256:3.000000
    +DT:sha256:3:64
    +R:3877617:sha256:3.000000
    +DT:sha256:3:64
    +R:3874137:sha256:3.000000
    +DT:sha256:3:64
    +R:3874451:sha256:3.000000
    +DT:sha256:3:64
    +R:3875361:sha256:3.000000
    +DT:sha256:3:64
    +R:3877294:sha256:3.000000
    +DT:sha256:3:64
    +R:2149724:sha256:3.000000
    +DT:sha256:3:256
    +R:2153052:sha256:3.000000
    +DT:sha256:3:256
    +R:2150821:sha256:3.000000
    +DT:sha256:3:256
    +R:2155444:sha256:3.000000
    +DT:sha256:3:256
    +R:2149688:sha256:3.000000
    +DT:sha256:3:256
    +R:2151033:sha256:3.000000
    +DT:sha256:3:256
    +R:2151136:sha256:3.000000
    +DT:sha256:3:256
    +R:2155279:sha256:3.000000
    +DT:sha256:3:256
    +R:927100:sha256:3.000000
    +R:925692:sha256:3.000000
    +DT:sha256:3:1024
    +DT:sha256:3:1024
    +R:925998:sha256:3.000000
    +DT:sha256:3:1024
    +R:926969:sha256:3.000000
    +DT:sha256:3:1024
    +DT:sha256:3:1024
    +R:926058:sha256:3.000000
    +DT:sha256:3:1024
    +R:926720:sha256:3.000000
    +DT:sha256:3:1024
    +R:926881:sha256:3.000000
    +DT:sha256:3:1024
    +R:282508:sha256:3.000000
    +DT:sha256:3:8192
    +R:282436:sha256:3.000000
    +DT:sha256:3:8192
    +R:282590:sha256:3.000000
    +DT:sha256:3:8192
    +R:282406:sha256:3.000000
    +DT:sha256:3:8192
    +DT:sha256:3:8192
    +R:282601:sha256:3.000000
    +DT:sha256:3:8192
    +R:282280:sha256:3.000000
    +DT:sha256:3:8192
    +R:282380:sha256:3.000000
    +DT:sha256:3:8192
    +R:37747:sha256:3.000000
    +R:37785:sha256:3.000000
    +DT:rc4:3:16
    +R:37744:sha256:3.000000
    +DT:rc4:3:16
    +DT:rc4:3:16
    +R:37745:sha256:3.000000
    +DT:rc4:3:16
    +R:37784:sha256:3.000000
    +DT:rc4:3:16
    +R:37746:sha256:3.000000
    +DT:rc4:3:16
    +R:37730:sha256:3.000000
    +DT:rc4:3:16
    +R:37741:sha256:3.000000
    +DT:rc4:3:16
    +R:19524465:rc4:3.000000
    +DT:rc4:3:64
    +R:19524639:rc4:3.000000
    +DT:rc4:3:64
    +R:19520022:rc4:3.000000
    +DT:rc4:3:64
    +R:19521224:rc4:3.000000
    +DT:rc4:3:64
    +R:19524007:rc4:3.000000
    +DT:rc4:3:64
    +R:19510847:rc4:3.000000
    +DT:rc4:3:64
    +R:19520332:rc4:3.000000
    +DT:rc4:3:64
    +R:19518851:rc4:3.000000
    +DT:rc4:3:64
    +R:10380346:rc4:3.000000
    +R:10373196:rc4:3.000000
    +DT:rc4:3:256
    +R:10371988:rc4:3.000000
    +DT:rc4:3:256
    +DT:rc4:3:256
    +R:10379038:rc4:3.000000
    +DT:rc4:3:256
    +R:10373438:rc4:3.000000
    +DT:rc4:3:256
    +R:10372895:rc4:3.000000
    +DT:rc4:3:256
    +R:10376505:rc4:3.000000
    +DT:rc4:3:256
    +R:10377678:rc4:3.000000
    +DT:rc4:3:256
    +R:3499677:rc4:3.000000
    +R:3501728:rc4:3.000000
    +DT:rc4:3:1024
    +DT:rc4:3:1024
    +R:3500784:rc4:3.000000
    +DT:rc4:3:1024
    +R:3498602:rc4:3.000000
    +DT:rc4:3:1024
    +R:3501730:rc4:3.000000
    +R:3501187:rc4:3.000000
    +DT:rc4:3:1024
    +DT:rc4:3:1024
    +R:3497663:rc4:3.000000
    +DT:rc4:3:1024
    +R:3498333:rc4:3.000000
    +DT:rc4:3:1024
    +R:957436:rc4:3.000000
    +DT:rc4:3:8192
    +R:957506:rc4:3.000000
    +R:957364:rc4:3.000000
    +DT:rc4:3:8192
    +DT:rc4:3:8192
    +R:957374:rc4:3.000000
    +DT:rc4:3:8192
    +R:957430:rc4:3.000000
    +R:957483:rc4:3.000000
    +DT:rc4:3:8192
    +DT:rc4:3:8192
    +R:957074:rc4:3.000000
    +DT:rc4:3:8192
    +R:957245:rc4:3.000000
    +DT:rc4:3:8192
    +R:123417:rc4:3.000000
    +R:123423:rc4:3.000000
    +DT:aes-128 cbc:3:16
    +R:123431:rc4:3.000000
    +R:123425:rc4:3.000000
    +R:123426:rc4:3.000000
    +R:123352:rc4:3.000000
    +R:123416:rc4:3.000000
    +R:7984532:aes-128 cbc:3.000000
    +DT:aes-128 cbc:3:64
    +R:7973934:aes-128 cbc:3.000000
    +R:7976586:aes-128 cbc:3.000000
    +R:7970091:aes-128 cbc:3.000000
    +R:7984700:aes-128 cbc:3.000000
    +R:7977161:aes-128 cbc:3.000000
    +R:7967978:aes-128 cbc:3.000000
    +R:7969582:aes-128 cbc:3.000000
    +R:2099042:aes-128 cbc:3.000000
    +R:2110591:aes-128 cbc:3.000000
    +DT:aes-128 cbc:3:256
    +R:2106471:aes-128 cbc:3.000000
    +R:2104796:aes-128 cbc:3.000000
    +R:2098353:aes-128 cbc:3.000000
    +R:2110706:aes-128 cbc:3.000000
    +R:2105403:aes-128 cbc:3.000000
    +R:2104620:aes-128 cbc:3.000000
    +R:533031:aes-128 cbc:3.000000
    +R:532424:aes-128 cbc:3.000000
    +R:531700:aes-128 cbc:3.000000
    +DT:aes-128 cbc:3:1024
    +R:531716:aes-128 cbc:3.000000
    +R:531735:aes-128 cbc:3.000000
    +R:533027:aes-128 cbc:3.000000
    +R:532219:aes-128 cbc:3.000000
    +R:531663:aes-128 cbc:3.000000
    +R:133394:aes-128 cbc:3.000000
    +R:133186:aes-128 cbc:3.000000
    +DT:aes-128 cbc:3:8192
    +R:133292:aes-128 cbc:3.000000
    +R:133031:aes-128 cbc:3.000000
    +R:133298:aes-128 cbc:3.000000
    +R:133393:aes-128 cbc:3.000000
    +R:133103:aes-128 cbc:3.000000
    +R:133020:aes-128 cbc:3.000000
    +R:16651:aes-128 cbc:3.000000
    +R:16669:aes-128 cbc:3.000000
    +DT:aes-256 cbc:3:16
    +R:16649:aes-128 cbc:3.000000
    +R:16650:aes-128 cbc:3.000000
    +R:16647:aes-128 cbc:3.000000
    +R:16645:aes-128 cbc:3.000000
    +R:16646:aes-128 cbc:3.000000
    +R:5773830:aes-256 cbc:3.000000
    +R:5760641:aes-256 cbc:3.000000
    +DT:aes-256 cbc:3:64
    +R:5773680:aes-256 cbc:3.000000
    +R:5774058:aes-256 cbc:3.000000
    +R:5765667:aes-256 cbc:3.000000
    +R:5773820:aes-256 cbc:3.000000
    +R:5757511:aes-256 cbc:3.000000
    +R:5765202:aes-256 cbc:3.000000
    +R:1499490:aes-256 cbc:3.010000
    +DT:aes-256 cbc:3:256
    +R:1499699:aes-256 cbc:3.000000
    +R:1500413:aes-256 cbc:3.000000
    +R:1500502:aes-256 cbc:3.000000
    +R:1500307:aes-256 cbc:3.000000
    +R:1499490:aes-256 cbc:3.000000
    +R:1499302:aes-256 cbc:3.000000
    +R:1500171:aes-256 cbc:3.000000
    +R:379547:aes-256 cbc:3.000000
    +DT:aes-256 cbc:3:1024
    +R:379452:aes-256 cbc:3.000000
    +R:379242:aes-256 cbc:3.000000
    +R:379259:aes-256 cbc:3.000000
    +R:379572:aes-256 cbc:3.000000
    +R:379549:aes-256 cbc:3.000000
    +R:379267:aes-256 cbc:3.000000
    +R:379541:aes-256 cbc:3.000000
    +R:94970:aes-256 cbc:3.000000
    +R:94530:aes-256 cbc:3.000000
    +DT:aes-256 cbc:3:8192
    +R:94200:aes-256 cbc:3.000000
    +R:93910:aes-256 cbc:3.000000
    +R:93802:aes-256 cbc:3.000000
    +R:94567:aes-256 cbc:3.000000
    +R:94798:aes-256 cbc:3.000000
    +R:94290:aes-256 cbc:3.000000
    +R:11921:aes-256 cbc:3.000000
    +R:11923:aes-256 cbc:3.000000
    +R:11893:aes-256 cbc:3.000000
    +R:11915:aes-256 cbc:3.000000
    +R:11913:aes-256 cbc:3.000000
    +DTP:2048:private:rsa:10
    +R1:2598:2048:10.00
    +DTP:2048:public:rsa:10
    +R1:2598:2048:10.01
    +R1:2598:2048:10.01
    +R1:2600:2048:10.01
    +R1:2593:2048:10.00
    +R1:2592:2048:10.00
    +R1:2598:2048:10.00
    +R1:2596:2048:10.01
    +R2:87396:2048:10.00
    +R2:87392:2048:10.00
    +R2:87386:2048:10.00
    +R2:87409:2048:10.00
    +R2:87475:2048:10.00
    +R2:87332:2048:10.00
    +R2:87398:2048:10.00
    +R2:87479:2048:10.00
    +DTP:4096:private:rsa:10
    +R1:355:4096:10.00
    +DTP:4096:public:rsa:10
    +R1:355:4096:10.00
    +R1:355:4096:10.01
    +R1:355:4096:10.01
    +R1:355:4096:10.01
    +R1:355:4096:10.02
    +R1:355:4096:10.01
    +R1:355:4096:10.01
    +R2:23337:4096:10.00
    +DTP:256:sign:ecdsa:10
    +R2:23258:4096:10.00
    +R2:23291:4096:10.00
    +R2:23347:4096:10.00
    +R2:23323:4096:10.00
    +R2:23362:4096:10.00
    +R5:67623:256:10.00
    +DTP:256:verify:ecdsa:10
    +R5:67608:256:10.00
    +R5:67623:256:10.00
    +R5:67623:256:10.00
    +R5:67621:256:10.00
    +R5:67620:256:10.00
    +R5:67603:256:10.00
    +R5:67603:256:10.00
    +R6:27213:256:10.00
    +R6:27347:256:10.00
    +R6:27106:256:10.00
    +R6:27129:256:10.00
    +R6:27249:256:10.00
    +R6:27310:256:10.00
    +R6:27301:256:10.00
    +R6:27318:256:10.00
    Forked child 7
    Got: +H:16:64:256:1024:8192 from 0
    Got: +F:3:md5:22726224.00:76083477.33:189900970.67:304775168.00:368342357.33 from 0
    Got: +F:5:sha1:22988677.33:65245568.00:139709525.33:195830442.67:222420992.00 from 0
    Got: +F:7:rc4:104130480.00:221294848.00:298814122.67:326804821.33:337027072.00 from 0
    Got: +F:16:aes-128 cbc:42584170.67:44779562.67:45485312.00:45531818.67:45517482.67 from 0
    Got: +F:18:aes-256 cbc:30793760.00:31882843.85:32388010.67:32266240.00:32552277.33 from 0
    Got: +F:23:sha256:20662789.33:45860778.67:78992384.00:96429397.33:103178240.00 from 0
    Got: +F2:2:2048:0.003849:0.000114 from 0
    Got: +F2:3:4096:0.028225:0.000428 from 0
    Got: +F4:3:256:0.000148:0.000366 from 0
    Got: +H:16:64:256:1024:8192 from 1
    Got: +F:3:md5:22971397.33:76353152.00:190866773.33:305427797.33:369139712.00 from 1
    Got: +F:5:sha1:23086730.67:65201642.67:139297962.67:195958784.00:221754709.33 from 1
    Got: +F:7:rc4:104131408.00:221447381.33:298639104.00:326828714.67:337048917.33 from 1
    Got: +F:16:aes-128 cbc:42527648.00:44938048.00:45433514.67:45460821.33:45468330.67 from 1
    Got: +F:18:aes-256 cbc:30723418.67:31993578.67:32379904.00:32416426.67:32557738.67 from 1
    Got: +F:23:sha256:20675354.67:45931776.00:79112533.33:96404821.33:103074474.67 from 1
    Got: +F2:2:2048:0.003850:0.000114 from 1
    Got: +F2:3:4096:0.028169:0.000429 from 1
    Got: +F4:3:256:0.000148:0.000367 from 1
    Got: +H:16:64:256:1024:8192 from 2
    Got: +F:3:md5:22805536.00:76030400.00:190230954.67:304918186.67:369254400.00 from 2
    Got: +F:5:sha1:23061930.67:64683882.67:138733994.67:195046400.00:222139733.33 from 2
    Got: +F:7:rc4:104106784.00:221269077.33:298733568.00:326780245.33:337010688.00 from 2
    Got: +F:16:aes-128 cbc:42541792.00:45025941.33:45371733.33:45497002.67:45462869.33 from 2
    Got: +F:18:aes-256 cbc:30792960.00:32008810.67:32361984.00:32153600.00:32475818.67 from 2
    Got: +F:23:sha256:20667605.33:45884181.33:79018496.00:96457386.67:103066282.67 from 2
    Got: +F2:2:2048:0.003853:0.000114 from 2
    Got: +F2:3:4096:0.028197:0.000429 from 2
    Got: +F4:3:256:0.000148:0.000366 from 2
    Got: +H:16:64:256:1024:8192 from 3
    Got: +F:3:md5:22947621.33:76360938.67:190835285.33:305138688.00:369131520.00 from 3
    Got: +F:5:sha1:23096165.33:65053824.00:138931968.00:193623381.33:221579946.67 from 3
    Got: +F:7:rc4:104113194.67:221419477.33:298547370.67:326783658.67:337032533.33 from 3
    Got: +F:16:aes-128 cbc:42507152.00:44902314.67:45373098.67:45407914.67:45457408.00 from 3
    Got: +F:18:aes-256 cbc:30750224.00:32006549.33:32390144.00:32017749.33:32535893.33 from 3
    Got: +F:23:sha256:20680624.00:45982805.33:79101354.67:96394581.33:103069013.33 from 3
    Got: +F2:2:2048:0.003856:0.000114 from 3
    Got: +F2:3:4096:0.028197:0.000429 from 3
    Got: +F4:3:256:0.000148:0.000369 from 3
    Got: +H:16:64:256:1024:8192 from 4
    Got: +F:3:md5:22729088.00:76087210.67:189897984.00:304773461.33:368336896.00 from 4
    Got: +F:5:sha1:22988757.33:65246357.33:139707989.33:191951872.00:222415530.67 from 4
    Got: +F:7:rc4:104128037.33:221300010.67:298767957.33:326802773.33:337035264.00 from 4
    Got: +F:16:aes-128 cbc:42585066.67:44764864.00:45484970.67:45531477.33:45517482.67 from 4
    Got: +F:18:aes-256 cbc:30793706.67:31989120.00:32388181.33:32278869.33:32552277.33 from 4
    Got: +F:23:sha256:20662064.00:45860010.67:78992384.00:96429397.33:103175509.33 from 4
    Got: +F2:2:2048:0.003849:0.000114 from 4
    Got: +F2:3:4096:0.028197:0.000428 from 4
    Got: +F4:3:256:0.000148:0.000366 from 4
    Got: +H:16:64:256:1024:8192 from 5
    Got: +F:3:md5:22964480.00:76311210.67:190810965.33:305270442.67:368997717.33 from 5
    Got: +F:5:sha1:23072949.33:65173696.00:139215189.33:192882688.00:221607253.33 from 5
    Got: +F:7:rc4:104057850.67:221365440.00:298467242.67:326681258.67:336833194.67 from 5
    Got: +F:16:aes-128 cbc:42495882.67:44915264.00:45416021.33:45432490.67:45451946.67 from 5
    Got: +F:18:aes-256 cbc:30706725.33:31985109.33:32364117.33:32357717.33:32535893.33 from 5
    Got: +F:23:sha256:20663738.67:45890901.33:79080106.67:96351573.33:103028053.33 from 5
    Got: +F2:2:2048:0.003858:0.000115 from 5
    Got: +F2:3:4096:0.028169:0.000430 from 5
    Got: +F4:3:256:0.000148:0.000366 from 5
    Got: +H:16:64:256:1024:8192 from 6
    Got: +F:3:md5:22809616.00:76037952.00:190227200.00:304931840.00:369273514.67 from 6
    Got: +F:5:sha1:23062746.67:64686357.33:138740138.67:194875733.33:222156117.33 from 6
    Got: +F:7:rc4:104108437.33:221288426.67:298814293.33:326820864.00:337035264.00 from 6
    Got: +F:16:aes-128 cbc:42544858.67:45028394.67:45374720.00:45499050.67:45465600.00 from 6
    Got: +F:18:aes-256 cbc:30794976.00:32010709.33:32363434.67:32054613.33:32475818.67 from 6
    Got: +F:23:sha256:20668592.00:45888704.00:79023616.00:96461141.33:103071744.00 from 6
    Got: +F2:2:2048:0.003853:0.000114 from 6
    Got: +F2:3:4096:0.028197:0.000428 from 6
    Got: +F4:3:256:0.000148:0.000367 from 6
    Got: +H:16:64:256:1024:8192 from 7
    Got: +F:3:md5:22949744.00:76357376.00:190829141.33:305136640.00:369093290.67 from 7
    Got: +F:5:sha1:23094693.33:65049002.67:138921472.00:194117973.33:221555370.67 from 7
    Got: +F:7:rc4:104100538.67:221390464.00:298524416.00:326739626.67:337007957.33 from 7
    Got: +F:16:aes-128 cbc:42504437.33:44898560.00:45368576.00:45404160.00:45454677.33 from 7
    Got: +F:18:aes-256 cbc:30747744.00:32003648.00:32387498.67:32184320.00:32530432.00 from 7
    Got: +F:23:sha256:20678901.33:45979285.33:79093845.33:96385706.67:103058090.67 from 7
    Got: +F2:2:2048:0.003857:0.000114 from 7
    Got: +F2:3:4096:0.028197:0.000429 from 7
    Got: +F4:3:256:0.000148:0.000369 from 7
    built on: reproducible build, date unspecified
    options:bn(64,64) md2(int) rc4(16x,int) des(idx,cisc,16,int) aes(partial) idea(int) blowfish(idx)
    compiler: gcc -I. -I.. -I../include  -fPIC -DOPENSSL_PIC -DZLIB -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DKRB5_MIT -m64 -DL_ENDIAN -Wall -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches   -m64 -mtune=generic -Wa,--noexecstack -DPURIFY -DOPENSSL_IA32_SSE2 -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_MONT5 -DOPENSSL_BN_ASM_GF2m -DRC4_ASM -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DMD5_ASM -DAES_ASM -DVPAES_ASM -DBSAES_ASM -DWHIRLPOOL_ASM -DGHASH_ASM -DECP_NISTZ256_ASM
    md5             182903.71k   609621.72k  1523599.27k  2440372.22k  2951569.41k
    sha1            184452.65k   520340.33k  1113258.24k  1554287.27k  1775629.65k
    rc4             832876.73k  1770775.13k  2389308.07k  2614241.96k  2696030.89k
    aes-128 cbc     340291.01k   359252.95k   363307.95k   363764.74k   363795.80k
    aes-256 cbc     246103.51k   255880.37k   259023.27k   257729.54k   260216.15k
    sha256          165359.67k   367278.44k   632414.72k   771314.01k   824721.41k
    rsa 2048 bits 0.000482s 0.000014s   2076.2  70099.2
    rsa 4096 bits 0.003524s 0.000054s    283.8  18658.9
     256 bit ecdsa (nistp256)   0.0000s   0.0000s  54054.1  21798.6
    openssl speed -evp aes256 -multi 8
    Forked child 0
    Forked child 1
    +DT:aes-256-cbc:3:16
    Forked child 2
    Forked child 3
    Forked child 4
    Forked child 5
    Forked child 6
    +R:17163530:aes-256-cbc:3.000000
    +DT:aes-256-cbc:3:64
    +R:17189693:aes-256-cbc:3.000000
    +R:17296695:aes-256-cbc:3.000000
    +R:17073713:aes-256-cbc:3.000000
    +R:17298367:aes-256-cbc:3.000000
    +R:17176055:aes-256-cbc:3.000000
    +R:17073063:aes-256-cbc:3.000000
    +R:17150660:aes-256-cbc:3.000000
    +R:4995498:aes-256-cbc:3.000000
    +R:4996379:aes-256-cbc:3.000000
    +DT:aes-256-cbc:3:256
    +R:4996736:aes-256-cbc:3.000000
    +R:4995696:aes-256-cbc:3.000000
    +R:4996874:aes-256-cbc:3.000000
    +R:4997380:aes-256-cbc:3.000000
    +R:4996693:aes-256-cbc:3.000000
    +R:4996286:aes-256-cbc:3.000000
    +R:1294689:aes-256-cbc:3.000000
    +R:1295468:aes-256-cbc:3.000000
    +DT:aes-256-cbc:3:1024
    +R:1295435:aes-256-cbc:3.000000
    +R:1295458:aes-256-cbc:3.000000
    +R:1295562:aes-256-cbc:3.000000
    +R:1295652:aes-256-cbc:3.000000
    +R:1295499:aes-256-cbc:3.000000
    +R:326910:aes-256-cbc:3.000000
    +R:326888:aes-256-cbc:3.000000
    +DT:aes-256-cbc:3:8192
    +R:326897:aes-256-cbc:3.000000
    +R:326783:aes-256-cbc:3.000000
    +R:326919:aes-256-cbc:3.000000
    +R:326937:aes-256-cbc:3.000000
    +R:326909:aes-256-cbc:3.000000
    +R:326906:aes-256-cbc:3.000000
    +R:40968:aes-256-cbc:3.000000
    +R:40967:aes-256-cbc:3.000000
    +R:40950:aes-256-cbc:3.000000
    +R:40971:aes-256-cbc:3.000000
    +R:40974:aes-256-cbc:3.000000
    +R:40970:aes-256-cbc:3.000000
    +R:41057:aes-256-cbc:3.000000
    Forked child 7
    Got: +F:22:aes-256-cbc:91538826.67:106570624.00:110480128.00:111541930.67:111820800.00 from 0
    Got: +F:22:aes-256-cbc:91678362.67:106574848.00:110545749.33:111580842.67:111869952.00 from 1
    Got: +F:22:aes-256-cbc:92249040.00:106589418.67:110543786.67:111577770.67:111867221.33 from 2
    Got: +F:22:aes-256-cbc:91059802.67:106597034.67:110546602.67:111585280.00:111869952.00 from 3
    Got: +F:22:aes-256-cbc:92257957.33:106599978.67:110554624.00:111588352.00:111878144.00 from 4
    Got: +F:22:aes-256-cbc:91605626.67:106610773.33:110562304.00:111594496.00:111886336.00 from 5
    Got: +F:22:aes-256-cbc:91056336.00:106596117.33:110545749.33:111584938.67:111875413.33 from 6
    Got: +F:22:aes-256-cbc:91470186.67:106587434.67:110549248.00:111583914.67:112112981.33 from 7
    evp             732916.14k   852726.23k   884328.19k   892637.53k   895180.80k
    openssl speed -evp aes128 -multi 8
    Forked child 0
    Forked child 1
    Forked child 2
    +DT:aes-128-cbc:3:16
    Forked child 3
    Forked child 4
    Forked child 5
    Forked child 6
    +R:22377776:aes-128-cbc:3.000000
    +R:22611084:aes-128-cbc:3.000000
    +DT:aes-128-cbc:3:64
    +R:22387334:aes-128-cbc:3.000000
    +R:22350575:aes-128-cbc:3.000000
    +R:22365818:aes-128-cbc:3.000000
    +R:22612020:aes-128-cbc:3.000000
    +R:22386091:aes-128-cbc:3.000000
    +R:22348307:aes-128-cbc:3.000000
    +R:6813241:aes-128-cbc:3.000000
    +DT:aes-128-cbc:3:256
    +R:6813975:aes-128-cbc:3.000000
    +R:6813793:aes-128-cbc:3.000000
    +R:6813713:aes-128-cbc:3.000000
    +R:6811601:aes-128-cbc:3.000000
    +R:6814020:aes-128-cbc:3.000000
    +R:6813908:aes-128-cbc:3.000000
    +R:6813516:aes-128-cbc:3.000000
    +R:1790753:aes-128-cbc:3.000000
    +R:1790893:aes-128-cbc:3.000000
    +DT:aes-128-cbc:3:1024
    +R:1790604:aes-128-cbc:3.000000
    +R:1790725:aes-128-cbc:3.000000
    +R:1790812:aes-128-cbc:3.000000
    +R:1790007:aes-128-cbc:3.000000
    +R:1790742:aes-128-cbc:3.000000
    +R:1790648:aes-128-cbc:3.000000
    +R:453541:aes-128-cbc:3.000000
    +DT:aes-128-cbc:3:8192
    +R:453489:aes-128-cbc:3.000000
    +R:453464:aes-128-cbc:3.000000
    +R:453488:aes-128-cbc:3.000000
    +R:453241:aes-128-cbc:3.000000
    +R:453509:aes-128-cbc:3.000000
    +R:453485:aes-128-cbc:3.000000
    +R:453474:aes-128-cbc:3.000000
    +R:56890:aes-128-cbc:3.000000
    +R:56896:aes-128-cbc:3.000000
    +R:56886:aes-128-cbc:3.000000
    +R:56891:aes-128-cbc:3.000000
    +R:56863:aes-128-cbc:3.000000
    +R:56894:aes-128-cbc:3.000000
    Forked child 7
    Got: +F:22:aes-128-cbc:119348138.67:145360917.33:152822869.33:154808661.33:155364010.67 from 0
    Got: +F:22:aes-128-cbc:120592448.00:145349141.33:152798208.00:154782378.67:155336704.00 from 1
    Got: +F:22:aes-128-cbc:119399114.67:145364800.00:152810922.67:154790912.00:155347626.67 from 2
    Got: +F:22:aes-128-cbc:119203066.67:145359210.67:152808533.33:154790570.67:155350357.33 from 3
    Got: +F:22:aes-128-cbc:119284362.67:145314154.67:152747264.00:154706261.33:155273898.67 from 4
    Got: +F:22:aes-128-cbc:120597440.00:145365760.00:152815957.33:154797738.67:155358549.33 from 5
    Got: +F:22:aes-128-cbc:119392485.33:145363370.67:152809984.00:154789546.67:155358549.33 from 6
    Got: +F:22:aes-128-cbc:119190970.67:145355008.00:152801962.67:154785792.00:155350357.33 from 7
    evp             957008.03k  1162832.36k  1222415.70k  1238251.86k  1242740.05k
    Building UnixBench
    Download UnixBench-5.1.3.tar.gz ...
    2018-12-05 09:10:37 URL:https://codeload.github.com/kdlucas/byte-unixbench/tar.gz/v5.1.3 [145908] -> "UnixBench-5.1.3.tar.gz" [1]
    Download done.
    UnixBench-5.1.3.tar.gz valid file.
    2018-12-05 09:10:38 URL:https://gist.githubusercontent.com/centminmod/7bea01c6698377d1345a/raw/unixbench.patch [1306/1306] -> "unixbench.patch" [1]
    gcc -o ./pgms/arithoh -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Darithoh ./src/arith.c
    gcc -o ./pgms/register -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum='register int' ./src/arith.c
    gcc -o ./pgms/short -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=short ./src/arith.c
    Checking distribution of files
    gcc -o ./pgms/int -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=int ./src/arith.c
    gcc -o ./pgms/long -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=long ./src/arith.c
    gcc -o ./pgms/float -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=float ./src/arith.c
    gcc -o ./pgms/double -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -Ddatum=double ./src/arith.c
    ./pgms  exists
    ./src  exists
    ./testdir  exists
    gcc -o ./pgms/hanoi -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/hanoi.c
    gcc -o ./pgms/syscall -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/syscall.c
    gcc -o ./pgms/context1 -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/context1.c
    gcc -o ./pgms/pipe -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/pipe.c
    gcc -o ./pgms/spawn -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/spawn.c
    gcc -o ./pgms/execl -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/execl.c
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_1.c
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DREG=register -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_1.c -o dhry_1_reg.o
    gcc -o ./pgms/looper -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/looper.c
    ./src/syscall.c: In function ‘main’:
    ./src/syscall.c:93:21: warning: null argument where non-null required (argument 2) [-Wnonnull]
                         execl("/bin/true", (char *) 0);
    In file included from ./src/execl.c:34:0:
    ./src/big.c: In function ‘getwork’:
    ./src/big.c:452:11: warning: variable ‘c’ set but not used [-Wunused-but-set-variable]
         char  c;
    gcc -o ./pgms/fstime -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/fstime.c
    gcc -o ./pgms/whetstone-double -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall -DDP -DUNIX -DUNIXBENCH ./src/whets.c -lm
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_2.c
    cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DREG=register -DHZ= -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall dhry_2.c -o dhry_2_reg.o
    gcc -o ./pgms/dhry2 -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/dhry_1.o ./src/dhry_2.o
    gcc -o ./pgms/dhry2reg -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce-addr -ffast-math -Wall ./src/dhry_1_reg.o ./src/dhry_2_reg.o
    cd ./src; rm -f dhry_1.o dhry_2.o
    cd ./src; rm -f dhry_1_reg.o dhry_2_reg.o
    patching file Run
    Hunk #1 succeeded at 106 (offset 1 line).
    Hunk #2 succeeded at 1329 (offset 1 line).
    Running UnixBench
    make all
    make[1]: Entering directory `/home/centminmodbench/byte-unixbench-5.1.3/UnixBench'
    ./pgms  exists
    ./src  exists
    ./testdir  exists
    ./tmp  exists
    ./results  exists
    make[1]: Leaving directory `/home/centminmodbench/byte-unixbench-5.1.3/UnixBench'
    sh: 3dinfo: command not found
       Version 5.1.3                      Based on the Byte Magazine Unix Benchmark
       Multi-CPU version                  Version 5 revisions by Ian Smith,
                                          Sunnyvale, CA, USA
       January 13, 2011                   johantheghost at yahoo period com
    1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
    1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
    1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
    1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
    1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
    1 x Process Creation  1 2 3
    1 x Execl Throughput  1 2 3
    1 x Shell Scripts (1 concurrent)  1 2 3
    1 x Shell Scripts (8 concurrent)  1 2 3
    1 x Shell Scripts (16 concurrent)  1 2 3
    8 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
    8 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
    8 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
    8 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
    8 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
    8 x Process Creation  1 2 3
    8 x Execl Throughput  1 2 3
    8 x Shell Scripts (1 concurrent)  1 2 3
    8 x Shell Scripts (8 concurrent)  1 2 3
    8 x Shell Scripts (16 concurrent)  1 2 3
       BYTE UNIX Benchmarks (Version 5.1.3)
       System: ns366161: GNU/Linux
       OS: GNU/Linux -- 4.9.142-xxxx-std-ipv6-64 -- #484350 SMP Mon Dec 3 08:32:22 UTC 2018
       Machine: x86_64 (x86_64)
       Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
       CPU 0: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
              Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
       CPU 1: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       CPU 2: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       CPU 3: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       CPU 4: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       CPU 5: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       CPU 6: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       CPU 7: Intel(R) Xeon(R) CPU W3530 @ 2.80GHz (5600.0 bogomips)
       09:10:38 up 43 min,  1 user,  load average: 7.00, 3.57, 1.45; runlevel 3
    Benchmark Run: Rab Des 05 2018 09:10:38 - 09:34:44
    8 CPUs in system; running 1 parallel copy of tests
    Dhrystone 2 using register variables       29385360.5 lps   (10.0 s, 7 samples)
    Double-Precision Whetstone                     3633.8 MWIPS (10.0 s, 7 samples)
    Execl Throughput                               2075.1 lps   (30.0 s, 2 samples)
    Pipe Throughput                              626042.2 lps   (10.0 s, 7 samples)
    Pipe-based Context Switching                 108170.3 lps   (10.0 s, 7 samples)
    Process Creation                               4951.3 lps   (30.0 s, 2 samples)
    Shell Scripts (1 concurrent)                   3942.9 lpm   (60.0 s, 2 samples)
    Shell Scripts (16 concurrent)                  1650.0 lpm   (60.0 s, 2 samples)
    Shell Scripts (8 concurrent)                   2309.5 lpm   (60.0 s, 2 samples)
    System Call Overhead                         506075.6 lps   (10.0 s, 7 samples)
    System Benchmarks Partial Index              BASELINE       RESULT    INDEX
    Dhrystone 2 using register variables         116700.0   29385360.5   2518.0
    Double-Precision Whetstone                       55.0       3633.8    660.7
    Execl Throughput                                 43.0       2075.1    482.6
    Pipe Throughput                               12440.0     626042.2    503.2
    Pipe-based Context Switching                   4000.0     108170.3    270.4
    Process Creation                                126.0       4951.3    393.0
    Shell Scripts (1 concurrent)                     42.4       3942.9    929.9
    Shell Scripts (16 concurrent)                     ---       1650.0      ---
    Shell Scripts (8 concurrent)                      6.0       2309.5   3849.1
    System Call Overhead                          15000.0     506075.6    337.4
    System Benchmarks Index Score (Partial Only)                          719.8
    Benchmark Run: Rab Des 05 2018 09:34:44 - 09:58:52
    8 CPUs in system; running 8 parallel copies of tests
    Dhrystone 2 using register variables      125855860.2 lps   (10.0 s, 7 samples)
    Double-Precision Whetstone                    23711.6 MWIPS (10.0 s, 7 samples)
    Execl Throughput                              21540.2 lps   (30.0 s, 2 samples)
    Pipe Throughput                             3455986.6 lps   (10.0 s, 7 samples)
    Pipe-based Context Switching                 868658.6 lps   (10.0 s, 7 samples)
    Process Creation                              50295.3 lps   (30.0 s, 2 samples)
    Shell Scripts (1 concurrent)                  27742.4 lpm   (60.0 s, 2 samples)
    Shell Scripts (16 concurrent)                  1874.0 lpm   (60.1 s, 2 samples)
    Shell Scripts (8 concurrent)                   3730.6 lpm   (60.1 s, 2 samples)
    System Call Overhead                        2828178.6 lps   (10.0 s, 7 samples)
    Dhrystone 2 using register variables         116700.0  125855860.2  10784.6
    Double-Precision Whetstone                       55.0      23711.6   4311.2
    Execl Throughput                                 43.0      21540.2   5009.3
    Pipe Throughput                               12440.0    3455986.6   2778.1
    Pipe-based Context Switching                   4000.0     868658.6   2171.6
    Process Creation                                126.0      50295.3   3991.7
    Shell Scripts (1 concurrent)                     42.4      27742.4   6543.0
    Shell Scripts (16 concurrent)                     ---       1874.0      ---
    Shell Scripts (8 concurrent)                      6.0       3730.6   6217.7
    System Call Overhead                          15000.0    2828178.6   1885.5
    System Benchmarks Index Score (Partial Only)                         4226.4
    centminmodbench.sh completed
    can you help me to translate it @eva2000 xD , i want to post it to my blog.
    11:27 PM
    thanks for sharing @Ariq Naufal - translating and interpretation of the results is let to you. But you can read my VPS benchmark threads where some I use centminmodbench.sh script to test the VPS and give a summary or review of some of the results so you can get an idea - see tag at Virtual Private Server (VPS) hosting
