upgrade PhpRedis version?
Discussion in 'Other Centmin Mod Installed software' started by fablab, Apr 14, 2021.
  1. fablab
    fablab New Member
    21
    5:22 AM
    1.25.3
    MariaDB-server-10.4.31-1.el7.centos.x86_64
    Hi!
    my setup:
    • Nginx Version Installed: 1.19.10
    • PHP Version Installed: 7.4.16
    • MariaDB MySQL Version Installed: 10.3.28
    I am using "Wordpress Redis Cache at Nginx Level" and Redis Object Cache WordPress plugin .... and it is FLYING! wow.
    thanks for putting all this together!
    I noticed that my server is using a 2 years old version of PhpRedis (5.1.1 vs 5.3.4 which seems to be the latest as per PECL :: Package :: redis ).
    It's all working as intended, so probably by Fear Of Missing Out as I read plenty of of "small improvements on the changelog ( PECL :: redis Changelog ) I am wondering why my set up is not upgraded.
    Is it on purpose ( some incompatibilities issues ? )
    Or am I supposed to run some manual scripts now to upgrade?
    via the centmin menu?
    thanks.
    fabrice.
    output of Redis Cache WordPress plugin
    and output of:
    php --ri redis
    I see some older versions of phpredis had been downloaded in the past...
    centminmod]#
    60,071
    12,574
    12:22 PM
    Running cmupdate and then centmin.sh menu option 13 sub menu option 2 will update PHP redis extension :) Or cmupdate and then running centmin.sh menu option 5 for PHP updates will auto update PHP redis extension too.
  3. fablab
    fablab New Member
    21
    5:22 AM
    1.25.3
    Thanks.
    did NOT work and left PhpRedis unchanged at 5.1.1
    but
    worked. Thanks for that !
    This makes me wonder if Option13 -> option 2 not picking up the PhpRedis extension upgrade might mean that I have other PHP extension out of date, and possibly vulnerable ??
  4. Rhodium
    Rhodium New Member
    26
    6
    4:22 AM
    I only get 5.3.2 in Option13 and the last is 5.3.4, is that correct?
    60,071
    12,574
    12:22 PM
  6. BamaStangGuy
    BamaStangGuy Active Member
    669
    192
    9:22 PM
    Just an FYI, nothing in here is getting me past:
    [00:37][root@web.bamapolitics.com ~]# php --ri redis | egrep "Redis Support|Redis Version"
    Redis Support => enabled
    Redis Version => 6.3.0RC1
    https://github.com/phpredis/phpredis/releases
    6.3.0 is the latest and I think I have run into a bug with RC1 but can not get it upgraded.
    @eva2000
  7. duderuud
    duderuud Active Member
    327
    98
    The Netherlands
    4:22 AM
    1.29 x
    11.4
    Same problem here...
    60,071
    12,574
    12:22 PM
    are you guys recompiling same PHP exact versions hoping to get new redis version?
    Centmin Mod skips recompile PHP extensions for minor versions i.e. PHP 8.4.x will skip PHP extension compiles as they usually aren't needed. Only time PHP extensions get recompiled for ones needing recompiling is
    1. change in PHP major versions i.e switching PHP 8.3 to 8.4 or 8.5 or PHP 8.5 to 8.4 or 8.3 etc OR
    2. persistent config /etc/centminmod/custom_config.inc with
    AUTODETECPHP_OVERRIDE='y'
    and then you run centmin.sh menu option 5 OR
    3. centmin.sh menu option 13 submenu option 2
    php --ri redis
    redis
    Redis Sentinel Version => 1.0
    Available serializers => php, json, igbinary
    Available compression => zstd, lz4
    redis.arrays.algorithm => no value => no value
    redis.arrays.auth => no value => no value
    redis.arrays.autorehash => 0 => 0
    redis.arrays.connecttimeout => 0 => 0
    redis.arrays.distributor => no value => no value
    redis.arrays.functions => no value => no value
    redis.arrays.hosts => no value => no value
    redis.arrays.index => 0 => 0
    redis.arrays.lazyconnect => 0 => 0
    redis.arrays.names => no value => no value
    redis.arrays.pconnect => 0 => 0
    redis.arrays.previous => no value => no value
    redis.arrays.readtimeout => 0 => 0
    redis.arrays.retryinterval => 0 => 0
    redis.arrays.consistent => 0 => 0
    redis.clusters.cache_slots => 0 => 0
    redis.clusters.auth => no value => no value
    redis.clusters.persistent => 0 => 0
    redis.clusters.read_timeout => 0 => 0
    redis.clusters.seeds => no value => no value
    redis.clusters.timeout => 0 => 0
    redis.pconnect.pooling_enabled => 1 => 1
    redis.pconnect.connection_limit => 0 => 0
    redis.pconnect.echo_check_liveness => 1 => 1
    redis.pconnect.pool_detect_dirty => 0 => 0
    redis.pconnect.pool_poll_timeout => 0 => 0
    redis.pconnect.pool_pattern => no value => no value
    redis.session.locking_enabled => 0 => 0
    redis.session.lock_expire => 0 => 0
    redis.session.lock_retries => 100 => 100
    redis.session.lock_wait_time => 20000 => 20000
    redis.session.lock_failure_readonly => 0 => 0
    redis.session.early_refresh => 0 => 0
    redis.session.compression => none => none
    redis.session.compression_level => 3 => 3
  9. duderuud
    327
    98
    The Netherlands
    4:22 AM
    1.29 x
    11.4
    I am running
    CMM option 13->2 still gives me
    60,071
    12,574
    12:22 PM
    what about centmin.sh menu option 5 recompile?
