Nginx Centmin RTMP Nginx Module ?
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by Tythus, Mar 11, 2018.
  1. Tythus
    Tythus Premium Member Premium Member
    61
    9
    7:08 AM
    A while back I saw that this was enabled as standard however when running nginx -V I can't see the module has this been mainlined and is no longer an additional module or how would I go about adding this?
    44,425
    10,144
    4:08 PM
    The Nginx RTMP Module from GitHub - arut/nginx-rtmp-module: NGINX-based Media Streaming Server was supported but not enabled by default so controlled by variables. Needed for Nginx MP4 Module Module ngx_http_mp4_module and Nginx FLV Module Module ngx_http_flv_module
    NGINX_RTMP='n'
    NGINX_FLV='n'
    NGINX_MP4='n'
    Support was added in Centmin Mod 123.09beta01 back in Feb, 2016 but hasn't been tested with latest Nginx versions since. So no idea if it works with newer Nginx versions. Enabling means setting in persistent config file /etc/centminmod/custom_config.inc
    NGINX_RTMP='y'
    NGINX_FLV='y'
    NGINX_MP4='y'
    then running centmin.sh menu option 4 to recompile Nginx
    Once Nginx RTMP module installed, configuration in vhosts etc is left up to end users to figure out from official docs at GitHub - arut/nginx-rtmp-module: NGINX-based Media Streaming Server and above linked Nginx MP4/FLV modules.
    FYI, did a quick test install on Centmin Mod 123.09beta01 with Nginx 1.13.9 and it at least compiled fine
