Beta Branch Centmin Mod .08 beta3 + clang compiler ngx_pagespeed psol
Discussion in 'Beta release code' started by rdan, Jun 10, 2015.
    5:21 PM
    Same error even after:
    rm -rf /svr-setup/*
  2. rdan
    5:21 PM
    I think this is where the problem trigger:
    So not a 32 bit problem.
    12,576
    7:21 PM
    try deleting the old pagespeed files in /svr-setup first
    rm -rf /svr-setup/ngx_pagespeed-release*
    rm -rf /svr-setup/release-1.9.32*
    Yeah could be older centmin mod used ngx_pagespeed master branch code while latest .08 betas use tagged version branches
  4. rdan
    5:21 PM
    Same error Eva :/
  5. rdan
    5:21 PM
    On the ramnode VPS, I succeed because I disable ngx_pagespeed on it.
    So this problem is not really solve until now :(
    Can you please try my modified centmin.sh if that matters: gist:c4aeb019302c3c3eea92
    12,576
    7:21 PM
    hmm i haven't been able to reproduce this nginx pagespeed psol library compile error under clang :( Done dozen of installs and upgrades the past few days.
  7. rdan
    5:21 PM
    Why i'm having this both Ramnode 32 bit and OVH 64 bit :(
    12,576
    7:21 PM
    none of those changes would/should affect nginx psol compilation - the problem is related to how clang compiler is having issues with nginx pagespeed psol library compile for nginx.
    maybe try wiping the nginx 1.9.1 source files too so they get redownloaded as well
    rm -rf /svr-setup/nginx-1.9.1*
    then centmin.sh menu option 4 to recompile nginx with ngx_pagespeed enabled NGINX_PAGESPEED=y in centmin.sh
  9. rdan
    5:21 PM
    The same error Eva :(
  10. rdan
    5:21 PM
    Why Clang works fine with someone not for me :/
    12,576
    7:21 PM
    found and fixed your problem
    problem was you needed to update to .08 beta03 code fully as some files were not updated ;)
    differences between your copy and latest .08 beta03
    cd /usr/local/src
    diff -qr centmin-v1.2.3mod centmin-v1.2.3mod-orig/
    Files centmin-v1.2.3mod/centmin.sh and centmin-v1.2.3mod-orig/centmin.sh differ
    Only in centmin-v1.2.3mod: .git
    Files centmin-v1.2.3mod/inc/ccache.inc and centmin-v1.2.3mod-orig/inc/ccache.inc differ
    Files centmin-v1.2.3mod/inc/motd.inc and centmin-v1.2.3mod-orig/inc/motd.inc differ
    Files centmin-v1.2.3mod/inc/openssl_install.inc and centmin-v1.2.3mod-orig/inc/openssl_install.inc differ
    Files centmin-v1.2.3mod/inc/php_configure.inc and centmin-v1.2.3mod-orig/inc/php_configure.inc differ
    nginx recompiled successfully with ngx_pagespeed and all default .08 beta03 options :)
    tail -1 /root/centminlogs/centminmod_1.2.3-eva2000.08_110615-103259_nginx_upgrade.log
    Total Nginx Upgrade Time: 142.101556503 seconds
  12. rdan
    5:21 PM
    Thanks a lot for your time digging on it Eva. :)
    12,576
    7:21 PM
