centmin menu stuck, for several minutes now
Discussion in 'Install & Upgrades or Pre-Install Questions' started by rdan, Jan 13, 2020.
    1,185
    3:57 PM
    • When was last time updated Centmin Mod code base ? :cmupdate command
    What to do? How to debug this?
    Thanks Eva!
    # centmin
    /usr/local/src/centminmod ~
  2. rdan
    1,185
    3:57 PM
    Wooops it runs fine now.Sorry.
    45,172
    10,273
    5:57 PM
    centmin.sh menu has background tasks it does so could be why
    45,172
    10,273
    5:57 PM
    technically you could use cminfo's debug-menuexit command log to inspect both centmin.sh menu initial run and exit routines in verbose log when you run
    cminfo debug-menuexit
    The verbose debug log which may contain sensitive info is saved at /root/centminlogs/debug-menuexit.txt and it's date timestamped for each line, so you can see where the longer delays between command/line output happens
    Example of first few lines from debug-menuexit.txt log
    cat /root/centminlogs/debug-menuexit.txt
    2020-01-12 15:56:52 + export PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
    2020-01-12 15:56:52 + PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/root/bin
    2020-01-12 15:56:52 + export LC_ALL=en_US.UTF-8
    2020-01-12 15:56:52 + LC_ALL=en_US.UTF-8
    2020-01-12 15:56:52 + export LANG=en_US.UTF-8
    2020-01-12 15:56:52 + LANG=en_US.UTF-8
    2020-01-12 15:56:52 + export LANGUAGE=en_US.UTF-8
    2020-01-12 15:56:52 + LANGUAGE=en_US.UTF-8
    2020-01-12 15:56:52 + export LC_CTYPE=en_US.UTF-8
    2020-01-12 15:56:52 + LC_CTYPE=en_US.UTF-8
    2020-01-12 15:56:52 + EMAIL=
    2020-01-12 15:56:52 + PUSHOVER_EMAIL=
    2020-01-12 15:56:52 + ZONEINFO=Etc/UTC
    2020-01-12 15:56:52 + NGINX_IPV=n
    2020-01-12 15:56:52 + USEEDITOR=nano
    2020-01-12 15:56:52 + FORCE_IPVFOUR=y
    2020-01-12 15:56:52 + CUSTOMSERVERNAME=y
    2020-01-12 15:56:52 + CUSTOMSERVERSTRING='nginx centminmod'
    2020-01-12 15:56:52 + PHPFPMCONFDIR=/usr/local/nginx/conf/phpfpmd
    2020-01-12 15:56:52 + UNATTENDED=y
    2020-01-12 15:56:52 + CMVERSION_CHECK=n
    2020-01-12 15:56:52 + MENUEXIT_ALWAYS_YUMCHECK=y
    2020-01-12 15:56:52 + CMSDEBUG=n
    2020-01-12 15:56:52 ++ date +%d%m%y-%H%M%S
    2020-01-12 15:56:52 + DT=120120-155652
    2020-01-12 15:56:52 + branchname=123.09beta01
    2020-01-12 15:56:52 + SCRIPT_MAJORVER=1.2.3
    2020-01-12 15:56:52 + SCRIPT_MINORVER=09
    2020-01-12 15:56:52 + SCRIPT_INCREMENTVER=401
    2020-01-12 15:56:52 + SCRIPT_VERSIONSHORT=123.09beta01
    2020-01-12 15:56:52 + SCRIPT_VERSION=123.09beta01.b401
