Upgrade centmin does not work anymore
Discussion in 'Install & Upgrades or Pre-Install Questions' started by upgrade81, May 20, 2018.
  1. upgrade81
    184
    Italy
    9:57 PM
    1.13.8
    after launching a cmupdate "with an error" below:
    cmupdate
    Detected Centmin Mod Github Remote Repo Changes
    setting up fresh /usr/local/src/centminmod code base to match
    Cloning into 'centminmod'...
    fatal: unable to access 'https://github.com/centminmod/centminmod.git/': Could not resolve host: github.com; Unknown error
    Completed. Fresh /usr/local/src/centminmod code base in place
    To run centmin.sh again, you need to change into directory: /usr/local/src/centminmod
    cd /usr/local/src/centminmod
    Centmin no longer exists. the directory is non-existent
    centmin
    /usr/bin/centmin: line 2: pushd: /usr/local/src/centminmod: No such file or directory
    bash: centmin.sh: No such file or directory
    WTF?
    ping google.com
    ping: google.com: Name or service not known
  2. upgrade81
    184
    Italy
    9:57 PM
    1.13.8
    37,710
    8,255
    6:57 AM
    you network connectivity in your VPS is down or not 100% working what do you get from these commands
    ping -c4 github.com
    ping -c6 github.com
    ensure you have working DNS resolvers
    cat /etc/resolv.conf
    for example i use cloudflare and google public DNS resolvers in /etc/resolv.conf
    options rotate
    options timeout:1
    nameserver 1.1.1.1
    nameserver 8.8.8.8
    If you can't ping and have working DNS resolvers in /etc/resolv.conf, contact your web host.
    Once fixed and have network connectivity to internet, you can re-setup fresh copy of Centmin Mod local code via commands below by wiping /usr/local/src/centminmod as outlined similar to update guide here for older than .07 releases.
    replace branchname with branch you want either 123.08stable or 123.09beta01
    branchname=123.09beta01
    cd /usr/local/src
    rm -rf centminmod*
    cd centminmod
    ./centmin.sh
