Can't protect a folder using python script
Discussion in 'Nginx, PHP-FPM & MariaDB MySQL' started by pamamolf, Oct 5, 2014.
    4,003
    420
    6:32 AM
    Nginx-1.17.x
    Hi
    I am trying to protect a folder: /home/nginx/domains/mydomain.com/public/folderx/
    I just run:
    python /usr/local/nginx/conf/htpasswd.py -c -b /usr/local/nginx/conf/htpasswd admin passwordx
    Then i edit the vhost file of my domain: /usr/local/nginx/conf/conf.d/mydomain.com.conf
    and i try to add this inside:
    auth_basic "Private";
    auth_basic_user_file /usr/local/nginx/conf/htpasswd;
    This protect my site and not the folder...
    It seems that this is normal as i add it on:
    So i create another location under the } of the above code like:
    location /home/nginx/domains/mydomain.com/public/folderx/ {
    save and restart but doesn't work again :(
    What i am doing wrong?
    On both cases i was restart nginx and then test.
    I got the info from here:
    Nginx and vBulletin Connect 5 Vhost
    49,875
    11,486
    2:32 PM
    location context match is web root relative so not
    but
    location /folderx/
  3. pamamolf
    4,003
    420
    6:32 AM
    Nginx-1.17.x
    Ok i add this:
    location /folderx/ {
    Then i restart the nginx and again i can open the file.php inside the folderx :(
    I tested on another browser also...
    49,875
    11,486
    2:32 PM
    location ^~/folderx/ {
    manual Module ngx_http_core_module
  5. pamamolf
    4,003
    420
    6:32 AM
    Nginx-1.17.x
    Working :)
