Can you help me for custom permalink vanilla forum in centminmod?
Discussion in 'Forum software usage' started by Tri Wahyu Budi Utomo, Feb 4, 2016.
    59,738
    8:06 AM
    not sure i understand the question ?
  2. Tri Wahyu Budi Utomo
    Tri Wahyu Budi Utomo New Member
    19
    5:06 AM
    Nginx 1.9.10
    MariaDB 10.0.x
    could you provide the solution in addition to vanilla forums which I can use to make a forum? a free and nice as well as support centminmod?
    59,738
    8:06 AM
    Unfortunately, I can not provide solution to every web app out there, I only do for web apps I use myself as I don't have the time to do it. Best is to get other members and other vanilla users to help. But you first need an official working example of Vanilla rewrite rules to work with that we can transpose over to Centmin Mod Nginx vhost.
    Example of other users working out their own Nginx rewrite rules on IP.Board IP.Board - IPB v4.1.x Files | Centmin Mod Community But you need a working set of Nginx rules/settings as I do not know anything about Vanilla myself. So best to ask on their forums first for examples nginx - Vanilla Forums
    59,738
    8:06 AM
    Did a quick browse of their forums' nginx tag at nginx - Vanilla Forums
    maybe try this for /forum based install
    # vanilla
    #server {
    #            listen   80;
    #            server_name domain.com;
      # ssi  on;
      # access_log /home/nginx/domains/domain.com/log/access.log combined buffer=32k;
         #try_files $uri $uri/ /index.php?q=$request_uri;
    # Forum locations
      location /forum {
          try_files $uri $uri/ @forum;
    # rewrite
      location @forum {
        #pretty urls
          rewrite ^/forum/(.+)$ /forum/index.php?p=$1 last;
       # Stop things from executing in the uploads directory
      location ~* ^/forum/uploads/.*.(html|htm|shtml|php)$ {
          types { }
          default_type text/plain;
      # Keep nosey people from discivering categories by number
      location ~* /forum/categories/([0-9]|[1-9][0-9]|[1-9][0-9][0-9])$ {
          return 404;
  5. Tri Wahyu Budi Utomo
    19
    5:06 AM
    Nginx 1.9.10
    MariaDB 10.0.x
    but, i have install on subdomain. forum.digitalponsel.com . now i using permalink from vanilla, because can't solved my problem .
    59,738
    8:06 AM
    just edit your subdomain site's nginx vhost http /usr/local/nginx/conf/conf.d/yourdomain.com.conf with the changed one above
    so edit /usr/local/nginx/conf/conf.d/forum.digitalponsel.com.conf with the suggested changes and do a search and replace for domain.com to forum.digitalponsel.com
    then restart nginx and php-fpm services for any vhost changes to take effect
    service nginx restart
    service php-fpm restart
    or via cmd shortcut
    nprestart
  7. Tri Wahyu Budi Utomo
    19
    5:06 AM
    Nginx 1.9.10
    MariaDB 10.0.x
    ok thank you very much. and now clear and solved ! :D
  8. Tri Wahyu Budi Utomo
    19
    5:06 AM
    Nginx 1.9.10
    MariaDB 10.0.x
    one again, robots.txt 404 not found sir. can you give me rule nginx ?
    59,738
    8:06 AM
    just add robots.txt to your web root /home/nginx/domains/domain.com/public
  10. Tri Wahyu Budi Utomo
    19
    5:06 AM
    Nginx 1.9.10
    MariaDB 10.0.x
    OK thank you :D
  11. fullclick
    fullclick New Member
    11
    CASINO ONLINE UY TÍN 247
    5:06 AM
    1.21
    10.3
